Check the ifpci. its always the same at same board.
Nice to use for naming interfaces.. eg:
:global ifchannel "0"
:if ( [ :pick $product 0 ] = "SL" && [ :pick $product 1 ] = "5424" ) do={ :global ifnames none,Link,Left,Right,Link2,Sone5,Sone6,Sone7; :global ifpci 05:0f.0,05:0d.0,05:09.0,05:0b.0; :global ifband 5,5,5,5,5,5,5,5 }
:if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "5424-IP54" && ( [ :pick $product 2 ] = "3" || [ :pick $product 2 ] = "4" ) ) do={ :global ifpci 00:05.0,00:0a.0,00:0b.0,00:04.0 }
:if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "5424-IP54" && [ :pick $product 2 ] = "2" ) do={ :global ifpci 00:05.0,00:0a.0,00:0b.0 }
:if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "5424-IP54" && [ :pick $product 2 ] = "5" ) do={ :global ifpci 00:12.0,00:14.0,00:13.0 }
:if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "5424" && [ :pick $product 2 ] = "6" ) do={ :global ifpci 00:12.0,00:14.0,00:13.0 }
:if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "5424" && [ :pick $product 2 ] = "7" ) do={ :global ifpci 00:12.0,00:14.0,00:13.0 }
:if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "5424-IP24" && [ :pick $product 2 ] = "1" ) do={ :set ifpci 00:04.0,00:0a.0,00:0b.0; :set ifband 5,2,2; :set :if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "2414-IP24" && [ :pick $product 2 ] = "1" ) do={ :set ifpci 00:11.0,0,0,00:0d.0; :set ifband 2,2,2,2 }
:if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "5418-IP54" && [ :pick $product 2 ] = "1" ) do={ :set ifpci 00:11.0,0,0,00:0d.0; :set ifband 5,2,2,2 }
:if ( [ :pick $product 0 ] = "PM" && [ :pick $product 1 ] = "5418-IP24" && [ :pick $product 2 ] = "1" ) do={ :set ifpci 00:11.0,0,0,00:0d.0; :set ifband 5,5,5,5 }
:if ( [ :pick $product 0 ] = "PP" && [ :pick $product 1 ] = "5418" && [ :pick $product 2 ] = "4" ) do={ :set ifpci 00:01.0; :set ifpcialt 00:02.0; :set ifband 5 }
:if ( [ :pick $product 0 ] = "PP" && [ :pick $product 1 ] = "5424" && ( [ :pick $product 2 ] = "1" || [ :pick $product 2 ] = "3" || [ :pick $product 2 ] = "4" ) ) do={ :set ifpci 00:05.0 }
:if ( [ :pick $product 0 ] = "PP" && [ :pick $product 1 ] = "5424" && [ :pick $product 2 ] = "1XR" ) do={ :set ifpci 00:01.0 }
:if ( [ :pick $product 0 ] = "PP" && [ :pick $product 1 ] = "5424" && [ :pick $product 2 ] = "5SR" ) do={ :set ifpci 00:0c.0 }
:if ( [ :pick $product 0 ] = "PP" && [ :pick $product 1 ] = "5424" && [ :pick $product 2 ] = "5" ) do={ :global ifpci 00:12.0 }
:if ( [ :pick $product 0 ] = "PP" && [ :pick $product 1 ] = "5424" && [ :pick $product 2 ] = "6" ) do={ :global ifpci 00:12.0 }
:if ( [ :pick $product 0 ] = "PP" && [ :pick $product 1 ] = "5424" && [ :pick $product 2 ] = "7" ) do={ :global ifpci 00:12.0,0,0,00:14.0; :set ifband 5,2,2,2,2,2,2 }
:if ( [ :pick $product 0 ] = "WL" && [ :pick $product 1 ] = "1000" && [ :pick $product 2 ] = "1" ) do={ :set ifpci 00:0e.0,05:00.0,01:00.0; :set ifband 5,2,2 }
:if ( [ :pick $product 0 ] = "PX" && [ :pick $product 1 ] = "2400" [ :pick $product 2 ] = "1" ) do={ :set ifpci 00:00.0,00:00.0,00:00.0,00:0c.0; :set ifband 2,2,2,2 }
/ interface wireless {
:foreach i in=[ find ] do={ set $i security-profile=default }
:foreach x in=[ find interface-type=virtual-AP ] do={ remove $x }
:local ifn [ :find $ifpci [ info get $i pci-info ] ]
:local ifa ( $mynetwork + ( $ifnetsize * $ifn ) + 1 )
:local ifs $ifslink; :local ifb [ :pick 5ghz-turbo,5ghz,5ghz-10mhz,5ghz-5mhz [ :find 40,20,10,5 $ifwlink ] ];
:if ( [ :tonum [ :pick $ifband $ifn ] ] = 2 ) do={ :set ifs $ifs2ghz; :set ifb [ :pick 2.4ghz-g-turbo,2.4ghz-onlyg,2.4ghz-b/g,2.4ghz-b,2ghz-10mhz,2ghz-5mhz [ :find 40,22,20,21,10,5 $ifw2ghz ] ] }
:if ( $ifn > 1 && [ :tonum [ :pick $ifband $ifn ] ] = 5 ) do={ :set ifs $ifs5ghz; :set ifb [ :pick 5ghz-turbo,5ghz,5ghz-10mhz,5ghz-5mhz [ :find 40,20,10,5 $ifw5ghz ] ] }
set $i name=[ :pick $ifnames $ifn ] frequency-mode=superchannel mode=ap-bridge ssid=$ifa radio-name=$ifa area=$ifa band=$ifb frequency=[ :tonum [ :pick [ :toarray $ifs ] 0 ] ] scan-list=$ifs country=[ :pick $country 0 ] security-profile=default hide-ssid=yes default-forwarding=no default-authentication=yes periodic-calibration=enabled preamble-mode=long proprietary-extensions=pre-2.9.25 rate-set=default ack-timeout=dynamic arp=enabled supported-rates-b="" basic-rates-b="" supported-rates-a/g=18Mbps basic-rates-a/g=18Mbps disabled=no
:if ( $ifn > 1 ) do={ add name=( "u" . [ :pick $ifnames $ifn ] ) master-interface=$i ssid=INSTALL area=$ifa arp=disabled default-forwarding=no proprietary-extensions=pre-2.9.25 hide-ssid=yes security-profile=default disabled=[ get $i disabled ] } else={ set $i disabled=no }
