Routerboard not fragmenting packets... or so I think
I have a location with a routerboard 230. Currently running 3.22 software. I’m having speed issues with it. I have other Mikrotik hardware in this town without issues, so it seems to be in this box. So far, I have figured out that maybe the traffic from access points behind it aren’t being fragmented. I tested this by doing pings to my main noc here with varying packet sizes. Anything over 1500 bytes ( the current MTU ) will just give an error ( packet too large and cannot be fragmented). Other devices just ping as usual and only quit if I check the don’t fragment checkbox.
Before I replace hardware on a perfectly working box other than this issue, I thought maybe someone can enlighten me. I have been working on this issue for a while and the ping issue is the only thing I have come up with.
Tom
Try using a Mangle rule on the forward chain to reset the don’t fragment flag for each packet and check if you are getting the same error from the client.
Thanks leonset for the response.
I do have the problem solved, I replaced the rb-230 with a rb-450 with version 5 software, problem solved. I don’t know if it was software or hardware, guess I’ll never know. I probably won’t upgrade that rb-230 past the version 3 that is on it.
Thanks.
Tom
