Routerboard performance :) ?
Okey. Here are few questions that needs answers :slight_smile:.
  1. I’ve got couple of RB 512 and 532 with licenses level 4 and 5 and upgrade to 2.9.12.
    2nd I need to make a link (5 km) for optic backup and 2nd route for now (I need more trafic and the optic won’t be upgrade very fast).
    I use 2 RB512 + SR5s. I’ve got:
    signal-strength: -49dBm
    noise-floor: -95dBm
    signal-to-noise: 46dB
    tx-ccq: 98%
    Nstream is enabled 5ghz-turbo.
    I used to work with x86 PCs, soo I think main problem is with CPU power on RB.
    I can transfer max 25 mbits (real trafic). And max 4000 packets per second.
Can you give me advices ?
3. I know that I can overclock MIPS CPU to 400 MHz, but there is caution that proccessor could not work very well. What is the main reason? Temperature, not enought voltage, or just the CPU could be from bad shipment (I haven’t try it yet). Have you try to user radiator or vent for heat dispartion? Will the RB with 64 RAM work better (I see that in resources the cpu is over 85 % but the ram isn’t used at all).
4. The link is WDSed :slight_smile:. Will it work better with routing?
10x in advance :slight_smile:
Well, actually I think that you won’t get more out of RB500 than you have. NStreme is quite CPU-intensive…
Some tests I did yesterday with a pair of RIC/522 running 5 GHz (non-turbo), NStreme and WPA2 with AES encryption gave a max. UDP throughput of between 22 and 26 MBit/s. The CPU was maxed out and clearly the limiting factor in this setup.
If you need more bandwidth (especially using NStreme), I think that you will have to go for more CPU power (like a Pentium-M or such…).
Best regards,
Christian Meis
Do you think I’ll get more without nstream on non-turbo ?
I have not really tested this, but will try to do so tomorrow when I’m in the office again…
Best regards,
Christian Meis
How do you get the noise floor and what’s CCQ?
2.9.12
but but but … :slight_smile:
http://wiki.mikrotik.com/wiki/Image:350mbps.jpg
:confused:
4 routerboards everyone 70 mbit throw wireless 32000 pps/4 = 9000 pps …
I can’t get more than 32 mbits with 3000 pps … :confused:
Where will be ready the test site conf. from MUM? :} I want to see the magic. Is WDS soo much CPU hungry than routeing ?
P.S. Until now 5ghz-turbo, connection tracking - off, wds connection 2.9.12 - 33 mbit/s real traffic. Next step cut out everything I don’t need - dhcp, hotspot, webproxy-test, ppp. What about security if I use only telnet, is it unnesecery ? :slight_smile:
