i have 2 RB2011 1 uas-rm routers and i want to connect them with a fiber cable.
RB2011 → sfp module → st cable to LC cable ↔ LC cable to st <-sfp module <-RB2011
cant get it to work. can you give me some tips with this configuration isseu ?
What type of SFP’s are you using at both ends? Do they show up on the miktotik under the SFP option under the SFP interface?
Are you getting a link ? Send/Receive around the right way?
I’ve used a large number of different types of SFP’s with mikrtik’s and they don’t seem to be fussy at all.
some modules not so compatible with rb2011 ![]()
what status report rb about them ?
Try to force speed on one side of the link.
Do you know the basics of fiber ?
single mode / multimode , max distance, are the fibers crossed ?
Does it work in a other device ?
If i try somethong new i buy at least 1 or 2 spares …
Till now i have no problems with 2011 and SFP modules (i use mikrotik and opton)
