RouterBOARD RB260GSP gbit or 100mbit poe
can you advice me, when I will power supply throught POE RBSXTG-5HPacD from RB260GSP, that it will be 1gbit or 100mbit connection.
Thank you for answer.
RB260GSP is a gigabit device, you will get gigabit link with other RouterBOARD gigabit products no matter what.
…except e.g. the 450G.
my RB260GSP is powering RB850Gx2, RB mAP 2n, another RB450G and another RB850Gx2.
Thank you janisk.
I never managed that.
Load is not detected. After setting PoE manual to on, it auto-negociates to 100mbps full duplex.
Probably time to change some cables.
LE: Changed cable and voila, 1Gbps, but still without load detection (calibration didn’t help…).
So yes, 450G works via PoE at 1Gbps, too.
power usage of some routers is very low. So sow, that port PoE can be turned off due to that. That is why fow low consumption router set forced-on on the port.
PoE setting (auto, forced-on) is not interfering with ethernet auto-negotiation process. Link should be negotiated correctly every time.
