routerboard rb260gsp how to bridge sfp port to a switch with fiber?
i have to mikrotik
one 260gsp
cloud core ccr-1036
i want to link both using the SFP and it does not work.
i tried both as switch , so i reset everything and it is by default.
now the router it is acting like a bridge.
so i can ping everything PC using ethernet but i cannot using the SFP.
i have read i have to set it up one SFP as master and other as slave but i cannot find much info about that..
thank you in advance
same here ,
Swithing menu can be found under this link:
http://192.168.88.1/index.html#forwarding
Check if all SFP checkboxes are marked (from - to)
