I have Mikrotik RouterBoard 750 and my mikrotik restarting after some minutes, then when i go inside in the Mikrotik with Winbox first window is the clock and the time is like …1970. I’m not sure where is problem.
Somebody now, why my routerboard is restarting. Thank you so much if someone have it some idea.
hi
you must configure NTP Client in your router and enable ntp client and set mode to unicast and set primary ntp server ip to a valid ip address of ntp server.
you can find ntp server from http://www.pool.ntp.org/.
after enable ntp client,you must set your time zone name in system clock.
