Routerboard - USB - Hotspot - Webserver
You can use the USB storage in a RouterBOARD 433, to have a webserver that is accessed from hotspot
Thank you all.
Everyone correct me here, but in short no…
You can create some static HTML pages for the hot spot service to use, but I dont believe that the will reside on the USB device…
You can’t do that.
What you could do, is use Metarouter and have some other OS with a LAMP setup sitting there. RouterBOARD and RouterOS will work the same, but you will also have a full featured web server in there.
This sounds cool, I hope it runs in Metarouter:
http://www.turnkeylinux.org/lamp
Maybe somebody can try it?
normis thanks.
Duda clarified.
Yeh…
Forgot to mention that one…
My bad…
Bad MikroTik user… Now go and try to configure that Cisco as punishment for forgetting to mention another feature of RouterOS…
