I bought this product:
RB912UAG-5HPnD
It says in the box that connect antennas before powering device. However I do not have antennas. I ordered now, but still waiting for then.
What happens if I power on without antennas? Will it fry the WiFi chip?
RB912UAG-5HPnD
Output amplifier will work without load, so yes a very probable chance of damaging it.
For tests and indoor, you can use regular rubberduck rp-sma antennas as found on most consumer access points.
Thanks.
I will try to see if I have some antennas in some AP.
Sadly most of them are ufl connectors vs Mikrotik mmcx.
Normally you would have mmcx-rpsma pigtails but I see they come with the enclosure rather than with the board.
Sorry, thought you were using a Basebox5 instead of the standalone RB912.
You’re right, you need either an mmcx to rp-sma pigtail + rp-sma antenna
or mmcx to N pigtail and suitable antenna.
If you’re going to assemble several, then having a pair of antennas with integrated pigtail, like the ACSWIM will speed up initial board testing in the lab prior to assembling:
