Press any key within 1 seconds to enter setup.
loading kernel from nand… OK
setting up elf image… OK
jumping to kernel code
Starting…
insmod: init_module: flash: Operation not permitted
modprobe: failed to load module flash
RouterBOOT booter 1.13
RouterBoard 532
CPU frequency: 264 MHz
Memory size: 32 MB
Starting…
modprobe: failed to load module rb
Starting services…
Demo license expired!
Please reinstall the router.
in4ni, you have to use netinstall.
Run netinstall and set appropriate configuration for it,
set RouterBOARD to boot from Ethernet.
Netinstall will show the license key of the current router, then you can search for the key on the account server, save it as *.key and specify path for the netinstall.
Net install didnt show the key.
After running net install i got a lot of errors on the next boot.
I feel that the onboard nand is messed up. My vendor is going to replace the unit.
Hi , how to reload , i faced a problem that its not find the kernal and not start the service .. i have format the nand and now its show the folloing :
RouterBOOT booter 2.23
RouterBoard 433
CPU frequency: 300 MHz
Memory size: 64 MB
Press any key within 2 seconds to enter setup..
kernel not found
