RouterBoard with mPCI-VGA card
My company is looking at designing a wireless video transmission unit to accompany an existing product. We would like to have a embedded receiver that can display video. The video would be a maximum resolution of 640x480. Is there a good way, using the RB433UAH (for example) to get a video out? VGA seems the most appropriate, however we wouldn’t be opposed to another comparable method. There are mini-PCI to VGA cards on the market, are there any known cards that RouterOS supports.? Alternatively, USB-VGA units exist, are there any known units that RouterOS supports?
Ideally we would like a single-board solution, and the RouterBoard equipment looks very promising, I just want to make sure there is some way to display the video feed.
Thank you for your help.
Bump. I’m guessing the answer is no?
http://www.pcengines.ch/alix3d3.htm
This board has built-in VGA and 2 miniPCI slots for wireless NIC.
Regards, Grzegorz.
yes, simply run RouterOS on some small sized X86 box.
