Routerboard with POE in and POE out
Hello all,
I have a question in case someone can help. I am searching for a routerboard device that has POE in and POE out in the same time.
I have a power supply in the house and an ethernet cable that powers on an RB912 on the roof. Since its impossible to pass a second cable I am trying to find a solution so that a device that can be powered on by one power supply and in the same time it can provide POE out to a second device.
If anyone has any idea please let me know.
Thank you in advanced.
Hello there are three devices with poe IN and POE out in the same time
RB951Ui - http://routerboard.com/RB951Ui-2HnD
and
mAP - http://routerboard.com/RBmAP2n
and
http://routerboard.com/RB2011UiAS-2HnD-IN
Or you can solder a bit maybe whatever 100mbit device with poe in.
regular Omnitik on the roof with soldered ports … not UPA model wich doesn’t work verry well …
That’s my way…
Also RB260GSP, RB750UP
And Omnitik UPA model - works ok for us but the LED’s are mixed up which can confuse people :slight_smile:
Thank you all for your replies! I will have a look to them.
One question only, what does it mean soldered ports?
Just for inspiration:
http://forum.mikrotik.com/viewtopic.php?f=3&t=60638&start=50#p448944
Interesting. I have an Omnitik with an SXT5 Lite working at one recent plus another with RB433 and QRT5 working so maybe some models (manufacturing runs) work better than others ?
Is there anything which has Poe In + Poe Out + 5GHz and compact enclosure and power efficient, so that I can run a “single” Ethernet cable (running to Poe in port and continuing on Poe out port to the next device) and put one device on every room to create a small 5GHz hotspot in each room?
https://mikrotik.com/product/cap_ac
Although I’m not sure if they can be daisy chained together since its Poe In and Poe Out use different standards.
