Routerboard with Router OS 2.8.19 hangs
I have 10 RB230 with RouterOS 2.8.19 and 2 PCMCIA wireless cards in each. They are all exatly the same configuration. One of the units has started locking up and only a power cycle will make it start functioning again. Any ideas on what I should do to start toubleshooting it?
Thanks,
Steve
Time to upgrade?
Do I lose all configuration when I upgrade from 2.8.x to 2.9?
No, but you must check it after upgrade to be sure :wink:
However, configuration in some areas is lost, e.g. policy routing.
