Ok Im simply trying to configure an RB to connect as a client to another AP.
Ive got it connected and DHCP client on Wireless, and I got dhcp setup with gateway as dhcp ip and its issuing IPS to my lan but I still have no internet. I can ping the internet from the rb, but my networks not getting anythign.
BUT NO INTERNET, Ive tried setting up NAT masquerade dest range x.x.x.x/24 dst interface has been tried with all interfaces, still no routing, any ideas what im missing?
This has gotta be an issue with the firewall/rules/gateway/nat
Whats the proper config???
ok if you receive an ip with dhcp client, you must have internet connection inside your router…first check that out by pinging any public ip…
if you have that…you have to create a new ip address with the proper mask to the interface you are connecting your pc, laptop or terminal, then add a firewall nat rule…of srcnat with action masquerade…you dont even have to click on anything else
that would be all…post your configuration so we can help you with more details
Masquerade Nat would not work when entered in winbox, I was going insane until I entered it in terminal, its the wierdest thing, same exact settings, hmmf, well its working now and has been reliably ever since I kicked it into gear, so thank you.
