RouterBOARD 850gx2 constantly rebooting need help
did you try to netinstall it?
Did you connect to the console? What’s the ouput during startup?
Regards,
Ape
Change log output to save to disk so it’s not cleared after each boot. I had a constant reboot issue with a different model. Log showed kernel failure. Netinstall is usually the first trial. Didn’t fix it for me. I exchange the unit for a new one.
