Routerboards experience RB922, RB953
experience • RB922UAGS-5HPacD
We bought 15 devices.
and after a few days it became as follows:
Sometimes stops working ethernet. Is seen in the system, but the data do not go through it. Disable /eneble not help. A reboot is required.
Sometimes longer be seen R11e-5HacD • 802.11ac / a / n. Everything is working normally, just not visible interface.
But most importantly, reouterboard reboot several times a day.
6.23 reboot, reboot + 6.27 kernel failure, reboot + 6.28 kernel failures, 6.30 shut down and not start up.
Exchange for a new one did not work, the same problem. Power jack 15V / 10A poe24V / 1A jack 24V / 2A
We return back 14 devices, we mounted back RB711 / RB 435G without any problem.
experience • RB953GS-5HnT
We bought 5 devices.
For me was surprised SMA connector when normal using RSMA connector + Chain Labels on board are different than the software :slight_smile:
The following happened:
6.23 reboot, reboot + 6.27 kernel failure, reboot + 6.28 kernel failures, 6.30 shut down and start up.
Exchange for a new one work the same problem. Power jack 15V / 10A poe24V / 1A jack 24V / 2A
We return back 4 devices, many months waiting for RMA Mikrotik. I report this on MUM mikrotik inPrague.
We mounted back RB 435G without any problem.
Please functional device for WISP.
Thank You.Jiri, Czech republic, 1400Routerboards
Thank you for letting us know about this issue.
Please write to MikroTik support. We would like to see suppout files from devices so we would be able to analyze kernel panics you talking about.
Before that please do following :
  1. Netinstall boards. Without backup
  2. Try another R11e-5HacD
  3. Try to repeat scenario in lab
regards,
Nauris
