medo
September 15, 2008, 12:24pm
1
I noticed that 433AH is actualy slower than RB532A when doing AES encrypted IPSec VPN tunnel. I also noticed that (discontinued) RB333 is 2-3 times faster with AES than RB532A.
I would like to know about IPSec performance of other RouterBoards especily RB600. Are there ANY official documents about IPSec performance benchmarks for different RouterBoards?
sergejs
September 15, 2008, 12:30pm
2
How did you tested IPSec on all boards ?
Do you use the same configurution ?
Is it possible to get configuration from your routers ?
medo
September 15, 2008, 12:41pm
3
All RBs were netinstalled from the scratch. AES-256 encryption was used for encryption and SHA auth for both phases with modp1024 PFS and DH groups.
laptop1–(eth1)–RB532 –(eth2)—crossover_UTP—(eth2)–RB532 –(eth1)–laptop2
I ran iperf, chariot and Bandwidth test within both RB and got similar results.
Any update to this? I am also very interested in IPSEC performance…
Any updates with regards to IPSec performance on the various Routerboard models?
What is your configuration for IPSec?
What are the results you got?
I had no Routerboard at that time, but I do now.
I have a Watchguard Firebox II in the other end and I get about 5mbit trough. The link is fiber to fiber full duplex at 10/10mbit.
Is this the IPsec speed I can expect from the RouterBoard 450G ?
I use 3des and sha1.
Regards,
Siggi
You probably won’t get a whole lot more out of it…
Try switching to AES-128 - this should be a lot faster.
The Watchguard has been replaced by a RB 750G, and I’m now running aes-128. I get the full 10mbits with a CPU usage of approx 45% on the RB750G.
