Hello. I would like know why all my routerboards are in my DHCP leases table.
My toppology:
/ BaseBox 5
LtAP - PowerBox Pro - BaseBox 2
\ Server
Both BaseBox are AP bridge, no routing, no DHCP client, no DHCP server, no rules, anything. PowerBox Pro also is bridging, no DHCP, no routing, no rules, anything. LtAP is the DHCP server. All are running ROS 6.45 with FW version 6.45.
These are the configs of my devices (The information marked as “XX” or “XXX” is censored information".
LtAP Config:
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] disabled=no ssid=MikroTik
/interface lte apn
add apn=XXX authentication=chap default-route-distance=1 name=Movistar user=XXX
/interface lte
set [ find ] apn-profiles=Movistar mac-address=AC:FF:FF:00:00:00 name=lte1
/ip hotspot profile
add name=dhcp_pool0 ranges=10.0.0.1-10.0.0.99
add address-pool=dhcp_pool0 disabled=no interface=bridge1 lease-time=1w name=dhcp1
/system logging action
set 3 remote=10.0.0.100
add bridge=bridge1 interface=wlan1
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=all wan-interface-list=all
add address=10.1.1.1/15 interface=bridge1 network=10.0.0.0
/ip dhcp-server lease
add address=10.0.0.100 mac-address=C0:25:E9:XX:XX:XX server=dhcp1
add address=10.0.0.1 mac-address=C0:14:3D:XX:XX:XX server=dhcp1
add address=10.0.0.2 mac-address=38:80:DF:XX:XX:XX server=dhcp1
add address=10.0.0.0/15 dns-server=8.8.8.8,8.8.4.4 gateway=10.1.1.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
add action=masquerade chain=srcnat out-interface=lte1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/snmp
set contact=XXX enabled=yes location="XXX" trap-version=2
/system clock
set time-zone-name=XXX/XXX
/system identity
set name=RBLtAP-2HnD&R11e-LTE
/system leds
# using RSRP, modem-signal-treshold ignored
add interface=lte1 leds=led1,led2,led3,led4,led5 type=modem-signal
/system logging
add action=remote topics=info
add action=remote topics=error
add action=remote topics=warning
add action=remote topics=critical
/system ntp client
set enabled=yes primary-ntp=XXX secondary-ntp=XXX
/tool sms
set port=lte1 receive-enabled=yes
PowerBox Pro:
add name=bridge1
/ip hotspot profile
add address=10.1.1.2/15 interface=bridge1 network=10.0.0.0
add distance=1 gateway=10.1.1.1
/ip service
/system clock
/system identity
set name=RB960PGS
/system logging
/system ntp client
BaseBox 2:
add name=bridge1
add authentication-types=wpa2-psk eap-methods="" management-protection=allowed mode=dynamic-keys name=WPA2 supplicant-identity=""
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=10 band=2ghz-b/g/n country=XXX disabled=no frequency=2422 mode=ap-bridge rx-chains=0,1 security-profile=WPA2 \
ssid=XXX tx-chains=0,1 tx-power=30 tx-power-mode=all-rates-fixed wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
add address=10.1.1.3/15 interface=bridge1 network=10.0.0.0
/ip service
/ip ssh
set allow-none-crypto=yes forwarding-enabled=remote
/system clock
/system identity
set name=RB912UAG-2HPnD
/system logging
/system ntp client
BaseBox 5:
add name=bridge1
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=13 band=5ghz-a/n channel-width=20/40mhz-XX country=XXX disabled=no mode=ap-bridge rx-chains=0,1 \
security-profile=WPA2 ssid=XXX tx-chains=0,1 tx-power=30 tx-power-mode=all-rates-fixed wireless-protocol=802.11 wmm-support=enabled wps-mode=disabled
add address=10.1.1.4/15 interface=bridge1 network=10.0.0.0
/ip service
/ip ssh
/system clock
/system identity
set name=RB912UAG-5HPnD
/system logging
/system ntp client
Regards.
