Routerboot Upgrade Fail
I’m currently trying to upgrade a RB 433 AH but this error shows up:
[admin@MikroTik] > system routerboard print
       routerboard: yes
             model: 433AH
     serial-number: 185C01F5008E
     firmware-type: ar7100
  factory-firmware: 2.15
  current-firmware: 2.29
  upgrade-firmware: 3.41
[admin@MikroTik] > system routerboard upgrade
Do you really want to upgrade firmware? [y/n]
y
ERROR: can not change firmware to this version, please try newer one
Any way to upgrade it?
Hi Companion,
Thank you! I’ve tested your procedure, nothing happen. =(
By the way I got success using serial xModem file transfer.
Routerboot:
From 2.29
To 3.41
Regards.
Try:
/system package update install
/system routerboard print
upgrade-firmware: (should update to a recent one)
and then
/system routerboard upgrade
/system reboot
