RouterBOOT v2.18 for rb532a (MIPSle"
hi
I recently bought a couple of rb532a boards, I need to instal the latest RouterBOOT firmware.
I think RouterBOOT v2.18 is the last for “MIPSle” (mip32/little endina).
Where can I download it?
As far as i know, the last version to support RB500 (AdmTek / MipsLE) was 6.32.4, and that is ancient
if you plan on playing with OpenWRT, then you can probably find the .fwf file in the archived version (unzip the .npk, look in /etc)
if you plan on using these in a production network, * don’t *.
6.32 is too outdated, and has known exploits
https://download.mikrotik.com/routeros/6.32.4/routeros-mipsle-6.32.4.npk
(the last version supported from changelogs is sometime 6.32.3, sometime 6.33.3, sometime 6.32.x, but not matter, 2.18 is still the last version of the BIOS)
use something like 7-zip and go on etc folder.
the file is rc32434-2.18.fwf and is for the IDT CPU 79RC32H435
Search in the forum you find.
And like rextended says, it easy to take 7zip to unpack the routeros file and find the routerboot in etc directory.
