RouterOS 2.9.43 Released
What’s new in 2.9.43:
*) routing-test - changes that are aimed at increasing perfomance and
reducing memory usage:
limit number of outstanding bgp updates, sending feeds to many peers
uses bounded amount of memory;
*) fixed bug - telephony was crashing whenever voice-port was changed;
*) ups - fixed: program was becoming unresponsive when serial ups was
configured but was not connected;
*) support for full frequency list of Atheros chips;
*) user manager - password not revealed on sign-up;
realy.... :smiley::
regards
Hasbullah.com
updated some units(pc and rb)…working good
Oh happy day!!! :smiley: :sunglasses: :smiley: :sunglasses:
That’s like an admission of guilt after months of correspondence with MT!!
Finally we have 2.5GHz up and working!!!
:laughing:
Already updated some WRAP, rb200, rb500 and few PC’s and no problem so far everything is OK for the time being.
Regards.
Faton
Speaking of updates, it seems there really is an improvement in wireless performance w/the 3.06 and later beta software (either that or a bunch of favorable coincidences in our testing). Any chance this will appear in the 2.9.x series? If beta for 3.x is anticipated to go on for a long time it would be nice to see the putative wireless improvements appear in the production branch.
there is a reason we are making a new version … v3 has new wireless module.
I updated 1 RB532 and 2 x86 routers at 5am this morning, all working fine including routing-test for OSPF :slight_smile:
Hai people
just finished update ROS, x86 as centralized AAA and RBs as wirelessly, userman as radius server is more fast and, for unwire system very...very...very.. quick assossiating..... and much ... much stable.
specialy thanks Mikrotik and Teams for
regsrds
Hasbullah.com
Then I’ll think good thoughts about a swift march for v3 up to and through the Victory Arch of Production Stability.
:smiley:
i upgrade it but the cpu of my router os x86 is always to max.
Why?
depends on a lot of things.
http://wiki.mikrotik.com/wiki/CPU_Usage
Upgrading one system (office router here) I ran into a problem.
Probably just some quirk, but just to warn others or to give a hint what to check for.
I upgraded from 2.9.41 to 2.9.43. The router had the routeros-all-in-one package on it, with several packages enabled, among them the PPP and the wireless package).
After the upgrade (which took unusually long in that case) the router came up again, and was on 2.9.43. But nothing worked.
While checking I noticed the router was in the following state:
  • the upgrade package file still was on the router (routeros-x86-2.9.43.npk) - a sign that the upgrade hasn’t been properly done.
  • the package list showed the routeros-x86 package, but the only “sub-package” (shown indented in WinBox) was the system package.
    Consequently most things in the config were “not there” (for example a PPPoE client - no ppp package was there…).
    I was not able to make a supout of that state, as the supout command (WinBox and terminal) just returned without an error and without creating a supout file.
After another reboot the upgrade seems to have worked ok - the package file in the file are has vanished, and “/system packages print” shows all desired packages.
BUT the config for most things was lost (like the PPPoE client). Restoring the backup I made immediately before the upgrade worked, though, so everything was back running quite quickly.
So:
  1. DO make backups - this is really a good habit :wink:
  2. Anyone did notice a similar behaviour?
This would have been much more painful if it had happened on a remote router…
Best regards,
Christian Meis
I had a similar issue upgrading a pc based MT, but I thought it was because I was going from 2.8.xx to 2.9.43 in one big step. I re-uploaded routeros-x86-2.9.43.npk and rebooted, it then installed the extra packages on that second reboot.
Now, I have an rb150 (Pretty cute little box) that won’t upgrade the board firmware after the upgrade. I try to upgrade it to 2.8, but it stays 2.6.
[admin@noblelboro] > system routerboard
[admin@noblelboro] system routerboard> print
       routerboard: yes
             model: "miniROUTER"
     serial-number: "10CF01CF4B8F"
  current-firmware: "2.6"
  upgrade-firmware: "2.8"
[admin@noblelboro] system routerboard> upgrade
Do you really want to upgrade firmware? [y/n] y
firmware upgraded successfully
       routerboard: yes
             model: "miniROUTER"
  current-firmware: "2.8"
[admin@noblelboro] system routerboard> /system reboot
Reboot, yes? [y/N]: y
system will reboot shortly
Connection closed by foreign host.
jp@travelmug:~> sleep 60s
jp@travelmug:~> telnet 10.0.2.162
Trying 10.0.2.162...
Connected to 10.0.2.162.
Escape character is '^]'.
MikroTik v2.9.43
Login: admin
Password:
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 2.9.43 (c) 1999-2007       http://www.mikrotik.com/
Property of Midcoast Internet Solutions 2075948277 or www.midcoast.com
Unauthorized access will be prosecuted.
All Access is logged.
Terminal xterm detected, using multiline input mode
       routerboard: yes
             model: "miniROUTER"
[admin@noblelboro] system routerboard> /quit
Same problem for me. Firmware failed to upgrade eventhough said “sussesful”
[admin] > system routerboard
[admin] system routerboard> print
routerboard: yes
model: “153”
serial-number: “13FE01D668FA”
current-firmware: “2.7”
upgrade-firmware: “2.8”
[admin] system routerboard> upgrade
routerboard: yes
model: “153”
current-firmware: “2.8”
routerboard: yes
model: “153”
[admin] system routerboard>[/quote]
routerboard: yes
model: “153”
routerboard: yes
model: “153”
routerboard: yes
model: “153”
sorry friend, i don't have mini board all my rb is fine, try '/sy reboot' after upgrade your firmware. and this screen capture one of my RBs
regards
Hasbullah.com
Yah, it works by rebooting immediately after I upgrade. Thank you Balimore.
I just was wondering why can’t my RouterOS sustanin the system time after rebooting? The system clock resets itself to Jan/01/2000. I’m sure it’s not the Millenium bug :slight_smile:
They don’t keep the time because they don’t have a battery to maintain a clock circuit. Having you own NTP server is easier and more consistent for time.
