RouterOS 4.11 (x86) in Linux KVM exits with errorno=2
For eval purpose - I have downloaded the v4.11 (x86) and installed the OS as a Linux KVM guest OS.
Host System: openSUSE 11.2 (64 bit), 6GB RAM, network interfaces – br0 (bridge) bound to eth0 and tap0, br1 bound to tap2
Script ($HOME/KVM/bin/routeros.sh) to start the guest VM
#!/bin/bash
export KVM_DIR=$HOME/KVM
nic0=00:07:43:7a:18:7b
nic1=00:07:43:37:54:42
qemu-kvm
-daemonize
-enable-kvm
-monitor unix:$KVM_DIR/run/routeros.socket,server,nowait
-vga cirrus
-m 128
-drive file=$KVM_DIR/vdisks/routeros.vdd,index=0,boot=on
-net nic,model=rtl8139,macaddr=${nic0}
-net tap,ifname=tap0,script=no,downscript=no
-net nic,model=e1000,macaddr=${nic1}
-net tap,ifname=tap2,script=no,downscript=no \
</shell script>
When I run the above script the RouterOS guest VM boots displays error messages (that display on the screen quite fast).
What I have been able to eye ball is:
“Boot from hard disk”
“Loading from initrd”
"Connect failed (errorno=2)
and after the VM is shut down by the OS.
Any idea why RouterOS fails to complete the boot process? Is it because of the network cards being Realtek and Intel?
I have browsed through a couple of postings in this forum. One of response mentioned use “legacy” network card. What is considered as a “legacy” card?
TIA
– Arun Khan
See http://forum.mikrotik.com/t/chance-to-run-ros4-10-in-kvm/38992/1
use “-cpu qemu32”… :wink:
RouterOS don’t run with 64bit-cpu :frowning:
L.
Interesting - 32bit versions of the main stream Linux distros run just fine on the same hardware.
Thanks much for the “-cpu qemu32” hint. It did solve my boot problem
– Arun
you can use other -cpu options, it just does not work with default -cpu setting. And it has nothing to do with other settings.
