normis
December 21, 2009, 9:36am
1
What’s new in 4.4:
*) snmp - fixed snmp version three;
*) snmp - fixed vlan interface speed;
*) hotspot - fixed radius variables in hotspot html pages;
*) removed support for xen;
*) routing - added support for BFD protocol;
*) fixed problem - MetaROUTER sometimes froze on RB4xx;
*) fixed OSPFv3 on bridge interfac
and some other minor fixes.
http://www.mikrotik.com/download/routeros-ALL-4.4.torrent
gbh
December 21, 2009, 9:40am
2
OK, I can’t be a guinea pig this time.
Can some 433uah users post back here once they have upgraded..
8+)
Eising
December 21, 2009, 10:06am
3
Do you have any documentation available regarding BFD?
Is your BFD implementation compatible with e.g. Cisco’s?
normis
December 21, 2009, 10:07am
4
asus
December 21, 2009, 11:51am
5
can you mail me TEST UM for 4.4OS Please??
xezen
December 21, 2009, 1:17pm
6
please send us a link to download test UM thanks for the support
asus
December 21, 2009, 1:20pm
7
LoL may be they will respond you
xezen
December 21, 2009, 1:23pm
8
normis posted this
user manager beta-test package is not yet released
asus
December 21, 2009, 1:30pm
9
But without it we cannot upgrade our router to 4.4, I think they had fix all bugs & released it as a stable version in 4.4 download package.
bdronka
December 21, 2009, 2:57pm
10
In 4.3 and 4.4 (!!!) Nstream work very unstable.
Link are lose connect when I did bandwidthtest every 60-70 seconds, when I choose 5GHz-turbo - every 20-30 seconds
Under 3.30 every works fine…but not 4.4…
xezen
December 21, 2009, 3:07pm
11
maybe the UM will come out later
and it might be stable then
od3m
December 21, 2009, 3:31pm
12
Hi all !
since upgrading from 4.3 to 4.4 my System Health seems wrong.
Just take a look ath the picture.
itßs definatly not so hot, but not showing the right temperature anymore
flayzer
December 21, 2009, 4:25pm
13
Has anyone noticed in 4.3 and 4.4 that if you run a scan using a r52n the signal strength is 8-10db better than the registration
yet in 4.2 and below if i run a scan and it states -60 it will register at -60
but in 4.3 and 4.4 if i scan at -60 it registers at -68 to -70.
however if you use an r52 in all versions the scan and registration are the same.
This problem also happens when using sr7 cards.
i have upgraded from 4.2-4.3-4.4 and back again serveral times via ethernet ,reseting config each time and the results are always the same.
FIPTech
December 21, 2009, 11:57pm
14
It seems that since we’ve updated from 4.3 to 4.4 on a RB750G, we have lost Mac autodetection feature from Winbox.
But if we enter manually the MAC adress, we can connect.
FIPTech
December 22, 2009, 12:45am
15
Sorry, MAC discovery is working with 4.4. We’ve added a rule for MNDP and that’s ok. I thought MNDP was level 2.
gbh
December 22, 2009, 7:16am
16
OK, I took the plunge.
Can confirm 4.4 is working nicely on a 433uah, 5 hours or so, no issues.
Also upgraded on an x86 platform and 3 x 450’s.
All good at the moment.
Many thanks.
we have update 6 RB/600 with MPLS/VPLS an OSPF. System works fine…
dingsingo
normis
December 22, 2009, 1:27pm
18
yes, it has been tested with Cisco, but since this is just first preliminary release there are some limitations:
echo mode is not supported, so be sure to disable that on Cisco with “no bfd echo”;
very small (e.g. millisecond timers) also are not supported at the moment
you are welcome to report any interoperability bugs you can find "
Were there any wireless changes in 4.4? I have some test links with r52n’s I can try.
jarapa
December 22, 2009, 10:38pm
20
I found one bug in V4.4. I have script for sending me emails with backup file. It stops working - in log I have this: “Error sending email: error handling file”.
After downgrade it works fine. This script works in all versions - 3.x and 4.x except 4.4.
The script:
:local mserver
:local mkomu
:local msubject
:local bjmeno
:set mkomu "> xxx@email.com > "
:set msubject ("Backup " . [/system identity get name])
:set bjmeno ([/system identity get name] . “-” . [:pick [/system clock get date] 7 11] . [:pick [/system clock get date] 0 3] . [:pick [/system clock get date] 4 6] . “.backup” )
/system backup save name=$bjmeno
:delay 30
:put ($mserver.“\n”)
/tool e-mail send subject=$msubject file=$bjmeno to=$mkomu body=("Backup from " . [/system clock get date] . " mikrotik " . [/system identity get name] . “.”)
:put ("Backup " . $bjmeno . “\n”)
:delay 30
/file remove [/file find name=$bjmeno]
