RouterOS 4.6 and Virtual AP problem
Hello.
I found out that 4.6 version crashes winbox while using virtual ap features. Winbox simply closing window, that makes unable to manage virtialap by winbox. It worked fine at 4.5.
Any fixes ?
Yes, we know about this, next version will have fix.
Normis…
Since we well knew the mikrotik nowadays is very weak on the 11N support, any action plan on it?
some time, some forum friend was suspect that, it’s the Mikrotik senior engineer already jump to the ubt???
that’s not funny :slight_smile:
802.11n itself is difficult, not that we have specific universal problems. Look at the 802.11n forum threads. After multiple complaints, people end up getting forum advice that fixes their links.
We are working on many major wireless improvements right now, it’s not so easy, so we can’t deliver yet.
this is weird since im running v 4.6 and facing no problem with virtual ap
you probably use console? this is winbox related issue.
this is why i found it weird normis… i use winbox :slight_smile:
you are lucky :slight_smile:
