RouterOS 5.0beta4
i see that the vouchers, csv file in the beta is not work + i all see that you cant enter IP address in hotspot, walled garden, Dst. Address: this can only be done under Terminal …
dst-address is read only option in /ip hotspot walled-garden, it is not available for configuration.
What is the problem with vouchers and CSV files? I can generate them without any problems.
We have a server running RouterOS 5.0beta4
Resources: Free Memory: 184.8 MIB, Total Memory:218.2 MIB, CPU: VIA, CPU: 797 MHz, Free HDD Space: 19.0GB, Total HDD Size: 19.2GB…
when we click on Generate Vouchers nothing happens + CSV File is there not a problem with this PC / X86 ???
Have you put checkbox for any user before generating voucher?
ok so you are saying the old software you only did one click to get an voucher now in the new software you have to do two steps to get a voucher,i also see that you cant change the voucher templets ..
To generate vouchers for all clients, click on upper level checkbox, then click to generate voucher.
Where is the problem to change the template?
Settings —> Templates —> Change whatever you want.
