*) ipsec - fix SA lifetime display when timezone offset does not equal 0;
*) ipsec - now default DPD interval is 2 min for new configurations;
*) webfig - make bandwidth-test work;
*) fixed problem - wireless package got disabled after upgrading from v4;
*) sstp - fix problems on multicore systems;
It is not possible. The changelog didn’t say anything about such changes.
How it is possible to introduce bugs into the code when some one is hacking away on totally other part of it?
It does not show bugs as accidents of coordinated programming, but chaotic messing with the code. Too bad.
This bug related to switch chip, maybe another elements not affected (but not tested) cli died after specify a specific command (winbox connection works and i see in profiler the “console process” eats 100% of cpu)
ROS 5.1, HDAMA Board 2xCPU Opteron, 1 GB RAM, Intel cards on PCIX 133MHz, Both CPU load 100percent, thruput runs like 40Mbit FDX as max. instead of normal 100-120Mbits with load of some 30percent with 4.16
Something is wrong
Happens on RB433 and RB750. Can’t get in Webfig page.
After clicking Webfig icon in welcome page, it displays “Loading” and a progress bar. The page never loads.
I upgraded to 5.1 and am still having problems with the wireless radios not working. I have been able to get the 5.8 mhz radio working but the 2.4 is not showing up. It looks like it is activated but it is not broadcasting.
Is anyone still having radio problems after upgrade to 5.1 ??
It happens on a RB750G using OpenBSD 4.9 and Mozilla Firefox too. It hangs on the “Loading…” page as described on this thread by other customers. No way to access webfig for me either.
edit: same on demo2.mt.lv too; tested with Gentoo Linux and Mozilla Firefox, Opera and Chromium.
