RouterOS 5.17 SNMP High LOAD
HI…
this problem wasn’t solved?
look the image attached…
if change SNMP to DISABLED load goes to 10 %
with SNMP ENABLED 100%
RB110 ROS 5.15 management eating CPU!
Contact support, they can fix this. Or wait ROS 5.18.
alissonx, we have fixed SNMP 100% CPU load and it even was made before the 5.17 release, however there were not enough time to get included at the latest version.
Please contact support to get management problem fixed immediately, we can provide you with pre-release package with SNMP fix (it requires more testing).
can you send me de patch?
v5.18 released
*) snmp - fix dhcp lease table, snmp reported an incorrect information when a static lease had configured different address than current active address, this should also solve problem with dude polling same leases over and over again;
Issue with SNMP and high cpu usage insists even with v5.18.
Tested on RB450G. Anyone else with the same problem?
ROS 5.18 - RB433UAH - resolved for me.
