RouterOS 5.5 Released
What’s new in 5.5 (2011-Jun-20 14:43):
*) console - resolved problem that appeared in version 5.4. it caused
‘sup-output’ command to crash console on systems with many ethernet
interfaces or very long interface names.
*) serial console - do not automatically send login prompt to attached
usb modem if no other serial port exists;
*) winbox - fixed scrolling in terminal window;
*) webfig - encrypt whole session even in non https mode;
*) do not show contents of skin files to users without
‘sensitive’ permission;
20 min uptime on RB333, so far looks good
no dhcp6-pd :frowning:
Already have such low space on routerboard 750 with 5.4 installed. Don’t know how I’m going to fit this update on for install =/ and have minimal packages installed =(
Please fix the torrent file, packages are just thrown in, they should be in directories as always.
:frowning: :frowning: so sad… Hopefully next release!
http://forum.mikrotik.com/t/dhcpv6-pd/44274/1 i hope it will be there on next release.
Nothing regarding wireless disconnects I guess :frowning:
Nothing about any wireless improvements (NV2 disconnects etc.)!
And nothing about port flapping I guess? (It still exists on 5 different rb’s I have, all with 5.4 and updated firmware and MT radio cards)
To me this looks a ´minor´ upgrade I might as well consider not to use… :frowning:
And why do I only get the notification e-mail on Sunday 26th? While the package is already out since 22nd?
due to national holidays..
and considering release - you should definitely use 5.5 if you are using webfig - encryption of session even over http, and login page changed solving a lot of login problems.
Reguarding bridge Filters without conn track ??
Regards
this should work with 5.5
Yes, bridge filters working fine now. Already upgraded all my remains rb’s. Thanks Mikrotik Team!!
When we can expect simple queues to be fixed?
Why is this not in the changelog?
Hi Janisk.
This is a matter that has bugged me since 5.5 was announced a week ago: how does encryption over http work? https in an obvious choice when encrypting traffic but http… the only way it may work is encrypting/decrypting traffic on both ends of a communication link, and I do not see how a browser can do it without using https. Does the browser run some sort of script that encrypts traffic? How is the encryption key adquired/shared? Is it public key? private key? OTP?
Just curious about this new RouterOS feature…
that is not private/public key as with ssl/tls encryption that we are used to use. But if you check packet sniff of webfig traffic you will see that it is not plain-text.
I am having a rather strange issue, after performing a configuration reset on RB493G running 5.5 my Ethernet interface names have changed.
Is anyone else seeing this?
this is a known problem on RB493G, you can rename the ports back to what you want, only the names have changed.
Routing mark Ipv6 please, I really need it.
Thanks for confirming this as a known bug. I tried swapping out a RB493AH with a 493G and ran into this. I’m glad it wasn’t just me.
