I’m not able to install RouterOS 5.7 on HP Compaq 6005 Pro PC (P/N: XG068EA#BED) which has AMD Phenom II X2 B55 3 GHz, 2 GiB DDR3 1066 MHz, AMD 785G chipset. The PC boots normally to Windows 7.
After booting with the installation CD, ISOLINUX says:
Looking for harddrives …
FATAL ERROR: no harddrives found
BIOS (the newest, ver. 1.15) shows the following configuration:
SATA0: Samsung HD502HJ
SATA1: CDDVDW TS-H653T
SATA EMULATION: AHCI
I tried to change the SATA emulation to IDE but to no avail.
Does this error sound familiar to anyone?
BTW, I was able to boot the installation CD on an old PC (MB: MSI 845E Max2 Series, Intel P4 2.4 GHz, 768 MiB DDR 266 MHz) and installed RouterOS 5.7 successfully.
– rpr.
