RouterOS 6.0rc5 CPU in 100% after use USERMAN (USER-MANAGER)
Hello Guys,
I am wanting to use the “user-manager” but I’m having trouble using it after a period of time when I enable credits to any User in USERMAN, the RouterBoard is at 100% CPU usage and can no longer enter the USERMAN , webfig, webpage hostpot WinBox and is slow to come, so back to normal after I restart the RouterBoard, my settings:
  • RB 450G
  • ROS 6.0rc5
  • Hotspot + user-manager
  • DHCP
Attached is the error log autosupout.rif.
autosupout.rar (596 KB)
nobody can help me?
is that if I go back to version 5.23 solves my problem?
I see that no one will help me, you can not help me normis?
You can use 6.0rc9
http://www.mikrotik.com/download
I already had problems with version 6.0rc6 and had to return to rc5, I am afraid to upgrade again with the RCs.
I will test and post the results anything.
I got similar problem
in my case the userman db got full of logs and stuck cpu usage with 100%
i cleaned all logs and rebuilt DB, after than cpu usage went to less than usual (around 16% RC9) :slight_smile:
The problem occurred using version RC9? I still can not upgrade my RB to test.
