*) pptp, l2tp - fixed crash when tunnel mru was too big and fragmented ip packet
was received;
*) hotspot - fixed problem when after upgrade hotspot html directory was empty;
*) ipv6 nd - dns dynamic-servers were not included in router advertisements;
*) winbox - fixed problem Switch menu disappeared on RB2011;
*) fixed memory amount issue on RB1100AHx2;
*) console - ‘/import’ prints each command that is executed;
*) console - ‘import’ has new argument ‘from-line’ that starts executing
commands after specified line;
*) secure api - fixed problem when wrong client ip address was reported;
*) hotspot - fixed universal client;
*) api - added support for API over TLS (SSL);
*) api - api service is now enabled by default;
*) ppp - do not show R flag for locally authenticated users;
*) vrrp - fixed ah authentication;
*) webfig - added support for RADIUS authentication (via MS-CHAPv2);
*) ipsec - for peers with full IP address specified system will
autostart ISAKMP SA negotiation;
*) trafficgen - added inject-pcap command for replaying pcap files into network;
*) dns - retry queries with tcp if truncated results received;
*) improved queue statistics updating;
*) fix 1G linking with some Cisco devices (affects RB7xx, RB9xx, RB1100, RB2011, CCR);
RB2011UAS-2HnD-IN Tx Power Problem
ROS V6.1 and V6.0 (Firmware 3.08)
On wireless tab
Frequency Mode set: manual txpower
Country: no_country_set
Atenna Gain: 0
Tx Power tab
Tx Power Mode set: card rates
Tx Power set: 18 dBm
Current Tx Power tab show all rates = 30 dBm Total Tx Power
When I load this on RB333(PPC) and upgrade from 6.0 to 6.1 I loose access by IP after about 60 seconds but can still get into it via MAC address. Down grading to 6.0 fixes it. I suspect it has something to do with bridging. Loaded 6.1 on a RB951-2n(mipsbe) with almost exact same config, (pppoe client, NAT, IPv4, IPv6, bridging, UPNP and etc), no issues at all.
