routeros 6.1 static arp bonding problem
Just upgrade from RouterOS 6.0rc11 to 6.1. The static arp bonding is not work.
configure info
  1. hardware
    routerboard: yes
    model: 1100AHx2
    serial-number: 3AD2020663BF
    current-firmware: 2.39
    upgrade-firmware: 3.02
  2. software info
    /system package print
    Flags: X - disabled
NAME VERSION SCHEDULED
0 routeros-powerpc 6.1
1 system 6.1
2 X ipv6 6.1
3 X wireless 6.1
4 hotspot 6.1
5 dhcp 6.1
6 mpls 6.1
7 routing 6.1
8 ppp 6.1
9 security 6.1
10 advanced-tools 6.1
11 ntp 6.1
  1. configure
    set ether1 arp=reply-only
    making ip - mac static bonding
I can't ping the static bonding ip address.
Has any suggestion anyone?
Regards
Just tested from client.
I found the client can not get arp response from mikrotik device although I have set the ether1 arp=reply-only.
Any one knows
/ip settings print
ip-forward: yes
send-redirects: yes
accept-source-route: no
accept-redirects: no
secure-redirects: yes
rp-filter: no
tcp-syncookies: no
allow-fast-path: yes
arp-timeout: 30s
the arp-timeout mean?
and Flags: X - disabled, I - invalid, H - DHCP, D - dynamic, P - published
0 address=192.168.199.245 mac-address=00:24:E8:00:02:77 interface=ether2 published=no
What mean that the new published?
