As title says, RouterOS 6.10 has been released for development testing. No changelog so far.
I will keep this thread updated, as a changelog appears.
Update:
What’s new in 6.10 (2014-Feb-06 12:44):
*) ipv6 pool - fix dynamic prefix disappearing which may influence large VPNs with IPv6;
*) ssh client - fix key agreement when sometimes wrong DH algorithm was selected;
*) bgp - multipath eBGP now does not propagate BGP nexthop unless
forced in configuration;
Well all is working for me just fine in EOIP over PPTP that is bridged on both sides with Ethernet.
Just check if EOIP mac addresses are different on both tunnel end also - check what MAC addresses bridge is using.
If no write to support with supout.rif files from both ends.
routing mark in firewall works (at least rule counts packets, doing 2 different marks, based on connection mark and mangle rules)
route shows up inactive and does not work, even if gateway says reachable, as if the interface is visible only from the main table, but not from other routing tables (outgoing interfaces are PPPoE and sstp server binding).
So it doesn’t work.
6.7 to 6.9 broke pptp connections on several of our systems in production. It actually works fine, however after upgrade security profiles were not working/applied … showing instead of the configured profile (we always set new profiles rather than “default-profile”)
It happens when the 6.7 version was running the experimental PPP package. At least everywhere i got this problem, the 6.7 experimental PPP package was installed and after upgrade all PPP settings/profiles/interfaces were gone.
*) ovpn client - remove cipher=any & auth=any options, protocol does not support them;
*) pptp - fixed where Windows & MacOS clients were disconnecting all the time;
*) sstp - make it work with Windows client with AES encryption;
*) bgp - multipath eBGP now does not propagate BGP nexthop unless forced in configuration;
What shiny said, although we were not running "ppp experimental’ package.
All profiles were missing in Winbox and webfig, present in the cli, but not recognized in the PPTP interface .
Re-entering the security profiles fixed the issue. Sorry I can’t seem to replicate the issue downgrading to 6.7 then upgrading to 6.9.
