where can i find routeros 6.2 changelog
What’s new in 6.2 (2013-Jul-16 13:48):
*) dhcp server - framed routes are now also added to the server routing table;
*) dhcpv6 server - added binding-script option;
*) proxy - allow multiple src-address for ipv4 and ipv6;
*) eoip,gre tunnels could occasionally crash multicore router;
*) fixed bug - sometimes some types of interfaces would stop working;
*) ipsec sometimes could crash kernel on CCR;
*) connection tracking sometimes could crash kernel on CCR;
*) ppp,pptp,l2tp,sstp - added default-route-distance parameter;
*) scep - “/cert scep ra” merged into “/cert scep client” without saving ra config;
*) ipsec - fix phase1 autonegotiation on little endian platforms;
*) pppoe server - allow service with empty service-name to accept all pppoe clients;
*) lcd - current-screen option is replaced with “/lcd show” command
*) lcd - current-interface option is replaced with “/lcd interface display” command
*) graphing - make graphs stable on ppp & ovpn interfaces;
*) www, hotspot - fixed problem when www service stopped responding on high load;
*) winbox, webfig: allow to enter space in the text fields;
*) webfig - fixed configuration of VPLS & routing filters;
*) lcd - added option for enabling or disabling the touch screen;
*) lcd - added options for screen switching;
*) lcd - up to 10 non-physical interfaces can now be added to the lcd;
*) lcd - all interface graph screen can now be customized from /lcd interface page;
*) backup - changed default backup file name to -
for file browsers to sort them properly;
*) webfig - it did not work in Opera;
*) webfig - made terminal work again;
*) winbox - added ability to fully set up traffic generator in winbox;
*) trafficgen - allow ranges for ip addrs and udp ports;
*) queue simple - fixed bug - actual queue order sometimes was wrong;
*) queue simple - queue is not invalid when at least one of target interfaces is up;
*) fixed crash when setting master-port on AR8327 switch chips;
*) fixed addresslist - dynamic entries sometimes would still
show up even afther being timed out;
thanks dear
Hello Normis,
when you will be available to download the version 6.2?
Regards,
Normis just posted the Changelog!
Hi, Normis! do you have the download link?
Thanx!
v6.2 is here: http://www.mikrotik.com/download/share/routeros-mipsbe-6.2.npk (MIPS-BE). Change the name to get other build files.
From Normis post in this topic: http://forum.mikrotik.com/t/listing-the-routing-table-via-snmp/47158/1
Normis check userman part … there is people say that have problems with paypal http://forum.mikrotik.com/t/user-is-not-activated-after-successful-payment/67172/1
Thank you!
There is no support for “Multicast” in the v6.2 package.
No mention of script fixes. Anyone had a chance to test previously working scripts on 6.2 yet?
all scripts are working, check if you have updated your scripts for the v6 commands and features
clarify please, what is not working
Sorry, are you implying there were no scripting bugs with 6.1?
There are a few issues, but they are not fixed in the above build, that’s why they are not in the changelog. Which specific issue are you talking about?
for the multicast to work, you need package that has multicast stuff in it.
here are archive with some additional packages:
http://www.mikrotik.com/download/share/all_files_6.2.zip
Ok, thanks for confirmation. My issues are in ticket #2013061866000451. Please could you fix them in 6.3? The scripting API is very important to us. ![]()
v6.2 is not released, this is only a discussion about it. the issues will be fixed before we release v6.2
Do you plan any wireless improvements?
We always “plan for improvements” ![]()
