RouterOS 6.27 Bug - address-list find not working
Hi, after upgrading to 6.27 my scripts broke. I am using: /ip firewall address-list find list=komunikat in my script and it is no longer working. On another router with 6.7 it works fine. Running this command in terminal is not working either.
There is one more bug with address-list: when I try to remove entry by hand it is automatically added again.
I have a RB750G running 6.27 using address-list just fine.
Troubleshoot your script. Most likely, you used something that they have tightened up the rules on and is now considered not correct to use.
EDIT:
Opps - I did not use the find command.
I tried using both commands in terminal - didn’t work. Find returns nothing. Remove works, yeah, but right after it removes, entry that was removed is added again. When I remove entry 0 and then check with Print then this entry is at the end of the list with new index.
