routeros 6.31 cm2, can't add VirtualAP interface, l2mtu wrong
routeros 6.31,package wireless-cm2, can’t add VIrtualAP, l2mtu wrong, and can’t edit L2MTU value.
RB941
you can add it via terminal
Contacted support about this. They say they are aware and it is scheduled to be fixed. In the meantime you can add via terminal or webfig
Router RB2011
I have same problem in Mipsbe and Misple, ROS 6.31
Same Here with RB2011UiAS-2HnD :frowning:
