RouterOS 6.33.3 delay in dns queries for certain domains
There is a significant delay in dns queries to the router for certain domains that should have a servfail reply.
Eg. http://www.duckdns.org
One doing nslookup for the above named domain on 8.8.8.8, I get a very quick reply. With debug on, here is the reply, point being the response is very quick.
> www.duckdns.org
Server:  google-public-dns-a.google.com
Address:  8.8.8.8
SendRequest(), len 33
    HEADER:
        opcode = QUERY, id = 2, rcode = NOERROR
        header flags:  query, want recursion
        questions = 1,  answers = 0,  authority records = 0,  additional = 0
    QUESTIONS:
        www.duckdns.org, type = A, class = IN
Got answer (49 bytes):
    HEADER:
        header flags:  response, want recursion, recursion avail.
        questions = 1,  answers = 1,  authority records = 0,  additional = 0
    QUESTIONS:
    ANSWERS:
    ->  www.duckdns.org
        type = A, class = IN, dlen = 4
        internet address = 52.24.195.93
        ttl = 18 (18 secs)
Non-authoritative answer:
    HEADER:
        opcode = QUERY, id = 3, rcode = NOERROR
    QUESTIONS:
        www.duckdns.org, type = AAAA, class = IN
Got answer (33 bytes):
    HEADER:
        opcode = QUERY, id = 3, rcode = SERVFAIL
    QUESTIONS:
Address:  52.24.195.93
There is no AAAA address for the domain, but the server still replies quickly with SERVFAIL.
However, when I run the same thing, using the router dns server, there is a significant delay. It does not send a SERVFAIL reply for the AAAA record, so the dns client waits till it times out. Hence, opening http://www.duckdns.org is significantly delayed.
> www.duckdns.org
Server:  [192.168.0.1]
Address:  192.168.0.1
    HEADER:
        opcode = QUERY, id = 5, rcode = NOERROR
    QUESTIONS:
    HEADER:
    QUESTIONS:
    ANSWERS:
    ->  www.duckdns.org
        ttl = 19 (19 secs)
    HEADER:
        opcode = QUERY, id = 6, rcode = NOERROR
    QUESTIONS:
DNS request timed out.
    timeout was 2 seconds.
timeout (2 secs)
SendRequest failed
There is no SERVFAIL reply from routerOS dns server, so there is a delay, followed by a request timeout for the AAAA record.
More info:
The delay on going to the www.duckdns.org website is only seen when we are running dual stack, both ipv4 and ipv6 together.
There is no delay if we only use ipv4 on the network
