Dear sirs,
I’m trying to send / receive sms with this config, but I think something is missing:
hw:
RB953GS-5HnT
pcie modem: WI-D15G2
pcie modem: AUX 0168
1 sim (slot position should be the same?)
sw: router OS 6.38.5
I don’t understand if the modems are seen from the routerboard from the joint views.
In LTe page, I can’t change network mode from LTE to GSM, it reset the setting.
What means the gobi firmware error?
From tools > sms a timeout error appear when sending, no received message in inbox.
I’ve looked at wiki, but can’t figure out the exact sequence of steps that should be take to make a simple sms send/receive work so kindly ask your advice.
I tried this today and no lte device could send Sms but 3G devices that show as ppp could send or receive Sms provided the ppp interface was disabled. I think it is a limitation of LTE ? I even tried an sxt lte from
Mikrotik [emoji3]
I’ve tried also changing the antenna connection on the modem, no change in results.
What is causing the timeout error? It’s just an sms, I’ve inserted the sms center number, the serial get used by sms, then timeout error appear…
Can someone please help me?
Is there a “paid support” way to obtain some useful information to make it work?
