Dear MikroTik !
When will be released RouterOS 6.8 ?
I hope today…
Thx.
Attila
Dear MikroTik !
I hope today…
Thx.
Attila
When we will fix all known issues. This is not easy to predict.
routeros 6.8 was released but now its gone and 6.7 is back again. and i also managed to upgrade to 6.8.
what is wrong with 6.8 then if it was drawn back download page and 6.7 placed there?
The 6.8 released had the wrong bootloader included by accident and was quickly withdrawn once discovered. I believe 6.8 will not be released instead it will be called 6.9 to avoid any confusion about versions
Ok thx for the tip but when i already installed it… any F ups i should worry about?
from what i gather, if your router survived the upgrade your ok. the problem was with the bootloader not the Ros itself. A couple of models became unresponsive if upgraded and had to be manually reset
Thnx for reply. I’ll wait for 6.9 then with fixed bootloader.
