but with PIM I have all IGMP groups wich coming to OLT and CPU on 100%
That IGMP switch can be a problem. Also, PIM is little more complicated for configuration. It has something called Rendezvous Point, and all traffic is forwarded to it.
I just upgrade to 6.12 but bug still persist. after couple times upstrime interface goes to down/up, IGMP proxy stop to forward multicast traffic and only reboot help.
When can we expect a solution for this bug!? It became unacceptable to reboot routers every day because of this ONE bug… If you can’t or won’t fix the bug atleast can you make something that reboots the router automaticly when the IGMP proxy stops working??
On which of the two routerboards the igmp proxy stops working? The 1100 or 2011?
What is the output of “/routing igmp-proxy mfc print” on both routers when this happens?
IGMP proxy stops forward of multicast traffic on all mikrotik routers. you can find detailed describe of problem if u read this topic.
it is obvious that there’s problem with interface since thins bug happend only when I have PPPoE server with PPPoE clients connected on that same router. So, in IGMP proxy I have ethernet 1 configured as upstream interface and ethernet 5 as downstream interface. I also have PPPoE server with one PPPoE client connected on ethernet 5. When I unplug cable from ethernet 1 and plug in again IGMP stops doing forward of traffic and I need to reboot router so that he can work again. This bug is not present when PPPoE client are disconnected from ethernet 5.
Hi janisk, do you have information about this but? We need solution ASAP for this problem!!! Your making huge damage to out company by not fixing this bug!
1 PC WITCH VLC STREAMING MULTICAST UDP IN ETHERNET 2
ROUTER MIKEORIK FB433AH
1 PC WITCH VLC CLIENT RECEIVING MULTICAST STREAM IN ETHERNET 3
IGMP Proxy don’t work.
I enable IGMP Proxy, I test all configuration, but in the client I can’t see anithing, I can’t see the streaming and Routervoard not forwader the multicast streaming.
I don’t have firewall, because the RB it’s only to test here in my house.
But I put in firewall the rules to accept UDP/IGMP/ICMP
In Nat I put masquerade the 2 interfaces.
I create the MFC but nothing,
Mikrotik receiv the mulkticast but don’t forward to the otrher interface…
I don’t know.
You need to add ether2 and ether3 to igmp proxy interface list. On ether2 in igmp interface list you need to enable “usptream”, and in alternative subnets add 0.0.0.0/0. Also, you need to have IP address on both interfaces. If you have PPPoE server or more downstream interface in IGMP Proxy, you can forget on mikrotik, because of big bugs with IGMP proxy in ROS.
Notice: For support from Mikrotik staff, write to > support@mikrotik.com > - Mikrotik does not generally offer support on the forum, > this is a user forum
