RouterOS 6 webbox Error 501: Not Implemented
On the router web admin page, all the images are 404 and attempts to log in to webbox leads to Error 501. I did an upgrade from 6.15 to 6.18 and it didnt fix the problem. This is on a RB750G. Is it caused by missing files? Any way to fix it without reinstallation?
use netinstall 6.18 and reinstall routeros-mipsbe-6.18.npk.
make one .rsc export first!
if you make one .backup than one .rsc probably when you re-import it cause mess again…
I did a netinstall and it fixed the problem. The web interface looks totally different. I guess the v6 has a new web interface but for some reason the previous installation/upgrade did not update the web portion.
