RouterOS 7.1.1 openvpn udp issue
Hello! Tried to establish udp connection between two mikrotik routers instead of tcp. TCP connection working well and worked for years. Connection is being established, ping is ok, ssh to other router is OK! but nothing else. I couldn’t connect to other router interface via web or via winbox(winbox is connecting, but tables are empty), and also couldn’t connect to network behind it(ping is ok).
My network schematics is in attached file below.
I’m trying to get access from 192.168.1.0/24 network to 192.168.2.0/24. So i can ping 192.168.2.1 and can access to it via SSH but nothing else.
answering to myself :slight_smile: you need to set MTU in openvpn server config to 1400! and all is working good!
saw something about mtu in connection with winbox issues on this forum
