RouterOS 7.10 PuTTY 0.71 Error Resolution
RouterOS 7.7 /ip ssh set strong-crypto=yes works with PuTTY 0.71
RouterOS 7.10 /ip ssh set strong-crypto=no works with PuTTY 0.71
RouterOS 7.10 /ip ssh set strong-crypto=yes works with PuTTY 0.78
RouterOS 7.10 /ip ssh set strong-crypto=yes fails with PuTTY 0.71
FATAL ERROR: Couldn’t agree a host key algorithm (available: rsa-sha2-256)
In between 0.71 and 0.78 there were various fixes for putty.
So where is the problem ? The latest version works, no ?
It was released in oktober 2022, so why go back to an older version ?
Issue is PuTTY 0.71 and RouterOS 7.10 with strong-crypto are incompatible. The resolutions are
  • upgrade PuTTY
  • downgrade RouterOS
  • disable RouterOS 7.10 strong-crypto
Any one or combination will do.
My case was failing to follow PuTTY releases.
