RouterOS 7.11 - kid control not working?
have a problem for some weeks. Just found kid control doesn’t work for me.
  • if I change times, after some seconds all times revert to previous or change to 00:01:00-1d 00:00:00
  • if I enable some kid control, after some seconds revert to disabled state
In logs I see “kid-control user test changed by username” but I didn’t change anything.
I can record video of this issue if it’s required.
Any fix please?
any help please?
btw have RB4011. Today I tried factory reset of RB, kid control still doesn’t work so I restored a backup backup.
Here’s the list of what’s been fixed since 7.1.1 was released on 2021-Dec-21.
Perhaps try reading through the list to see if it’s mentioned, or just skip the reading and go straight to updating to a newer version…
What's new in 7.11 (2023-Aug-15 09:33):
*) api - disallow executing commands without required parameters;
*) bfd - fixed "actual-tx-interval" value and added "remote-min-tx" (CLI only);
*) bfd - improved system stability;
*) bluetooth - added "decode-ad" command for decoding raw Bluetooth payloads (CLI only);
*) bluetooth - added "Peripheral devices" section which displays decoded Eddystone TLM and UID, iBeacon and MikroTik Bluetooth payloads;
*) bluetooth - added new AD structure type "service-data" for Bluetooth advertisement;
*) bridge - added more STP-related logging;
*) bridge - added warning when VLAN interface list contains ports that are not bridged;
*) bridge - fixed MAC learning on "switch-cpu" port with enabled FastPath;
*) bridge - fixed MSTP BPDU aging;
*) bridge - fixed MSTP synchronization after link down;
*) bridge - prevent bridging the VLAN interface created on the same bridge;
*) certificate - allow to import certificate with DNS name constraint;
*) certificate - fixed PEM import;
*) certificate - fixed trust store CRL link if generated on an older version (introduced in v7.7);
*) certificate - improved CRL download retry handling;
*) certificate - removed request for "passphrase" property on import;
*) certificate - require CRL presence when using "crl-use=yes" setting;
*) certificate - restored RSA with SHA512 support;
*) conntrack - fixed "active-ipv4" property;
*) console - added ":convert" command;
*) console - added default value for "rndstr" command (16 characters from 0-9a-zA-Z);
*) console - fixed incorrect date when printing "value-list" with multiple entries;
*) console - fixed minor typos;
*) console - fixed missing "parent" for script jobs (introduced in v7.9);
*) console - fixed missing return value for ping command in certain cases;
*) console - fixed printing interval when resizing terminal;
*) console - improved flag printing in certain menus;
*) console - improved stability and responsiveness;
*) console - improved stability when canceling console actions;
*) console - improved stability when using fullscreen editor;
*) console - improved timeout for certain commands and menus;
*) console - improved VPLS "cisco-id" argument validation;
*) container - added IPv6 support for VETH interface;
*) container - added option to use overlayfs layers;
*) container - adjust the ownership of volume mounts that fall outside the container's UID range;
*) container - fixed duplicate image name;
*) container - fixed IP address in container host file;
*) defconf - do not change admin password if resetting with "keep-users=yes";
*) dhcp-server - fixed setting "bootp-lease-time=lease-time";
*) discovery - fixed "lldp-med-net-policy-vlan" (introduced in v7.8);
*) dns - improved system stability when processing static DNS entries with specified address-list;
*) ethernet - fixed forced half-duplex 10/100 Mbps link speeds on CRS312 device;
*) ethernet - improved interface stability for CRS312 device;
*) fetch - improved timeout detection;
*) firewall - added warning when PCC divider argument is smaller than remainder;
*) firewall - fixed mangle "mark-connection" with "passthrough=yes" rule for TCP RST packets;
*) firewall - improved system stability when using "endpoint-independent-nat";
*) graphing - added paging support;
*) health - added more gradual control over fans for CRS3xx, CRS5xx, CCR2xxx devices;
*) health - fixed configuration export for "/system/health/settings" menu;
*) hotspot - allow number as a first symbol in the Hotspot server DNS name;
*) ike1 - fixed Phase 1 when using aggressive exchange mode (introduced in v7.10);
*) ike2 - improved SA rekeying reply process;
*) ike2 - improved system stability when closing phase1;
*) ike2 - improved system stability when making configuration changes on active setup;
*) ike2 - log "reply ignored" as non-debug log message;
*) ipsec - fixed public key export (introduced in v7.10);
*) ipsec - fixed signature authentication using secp521r1 certificate (introduced in v7.10);
*) ipsec - improved IKE2 rekey process;
*) ipsec - properly check ph2 approval validity when using IKE1 exchange mode;
*) l3hw - changed minimal supported values for "neigh-discovery-interval" and "neigh-keepalive-interval" properties;
*) l3hw - fixed /32 and /128 route offloading after nexthop change;
*) l3hw - fixed incorrect source MAC usage for offloaded bonding interface;
*) l3hw - improved system responsiveness during partial offloading;
*) l3hw - improved system stability during IPv6 route offloading;
*) l3hw - improved system stability;
*) led - fixed manually configured user LED for RB2011;
*) leds - blink red system-led when LTE is not connected to the network on D53 devices;
*) leds - fixed system-led color for "GSM EGPRS" RAT on D53 devices;
*) lora - added new EUI field;
*) lora - added uplink message filtering option using NetID or JoinEUI;
*) lora - moved LoRa service to IoT package;
*) lora - properly apply configuration changes when multiple LoRa cards are used;
*) lora - updated LoRa firmware for R11e-LR8, R11e-LR9 and R11e-LR2 cards;
*) lte - added "at-chat" support for Dell DW5821e-eSIM modem;
*) lte - added "at-chat" support for Dell DW5829 modem;
*) lte - added "at-chat" support for Fibocom L850-GL modem;
*) lte - added "at-chat" support for SIMCom 8202G modem;
*) lte - added "band" info to the "monitor" command for MBIM modems that support serving cell info reporting over MBIM;
*) lte - added extended support for Neoway N75 modem;
*) lte - fixed Dell DW5821e "at-chat" support;
*) lte - fixed LtAP mini default SIM slot "down" changeover to "up" after an upgrade (introduced in v7.10beta1);
*) lte - fixed NR SINR reporting for Chateau 5G;
*) lte - fixed R11e-LTE, R11e-LTE6 legacy 2G/3G RAT mode selection;
*) lte - fixed Telit LE910C4 "at-chat" support;
*) lte - improved initial interface startup time for SXT LTE 3-7;
*) lte - improved system stability when changing the "radio" state for MBIM modems;
*) lte - only listen to DHCP packets for LTE passtrough interface in auto mode when looking for the host;
*) modem - added initial support for BG77 modem DFOTA firmware update;
*) modem - changed Quectel EC25 portmap to expose DM (diag port), DM channel=0, GPS channel=1;
*) modem - fixed missing sender's last symbol in SMS inbox if the sender is an alphabetic string;
*) mpls - improved MPLS TCP performance;
*) mqtt - added more MQTT publish configuration options;
*) mqtt - added new MQTT subscribe feature;
*) netwatch - added "src-address" property;
*) netwatch - changed "thr-tcp-conn-time" argument to time interval;
*) ovpn - do not try to use the "bridge" setting from PPP/Profile, if the OVPN server is used in IP mode (introduced in v7.10);
*) ovpn - fixed OVPN server peer-id negotiation;
*) ovpn - fixed session-timeout when using UDP mode;
*) ovpn - improved key renegotiation process;
*) ovpn - include "connect-retry 1" and "reneg-sec" parameters into the OVPN configuration export file;
*) ovpn - properly close OVPN session on the server when client gets disconnected;
*) package - treat disabled packages as enabled during upgrade;
*) poe - fixed missing PoE configuration section under specific conditions;
*) poe-out - advertise LLDP power-mdi-long even if no power allocation was requested (introduced in v7.7);
*) pppoe - fixed PPPoE client trying to establish connection when parent interface is inactive;
*) profile - added "container" process classifier;
*) profile - properly classify "console" related processes;
*) qos-hw - keep VLAN priority in packets that are sent from CPU;
*) quickset - correctly apply configuration when using "DHCP Server Range" property;
*) resource - fixed erroneous CPU usage values;
*) rose-storage - added "scsi-scan" command (CLI only);
*) rose-storage - added disk stats for ramdisks;
*) rose-storage - fixed RAID 0 creation;
*) rose-storage - limit striped RAID element size to smallest disk size;
*) route - added comment for BFD configuration (CLI only);
*) route - convert BFD timers from milliseconds to microseconds after upgrade;
*) routerboard - fixed "gpio-function" setting on RBM33G ("/system routerboard upgrade" required);
*) routerboard - improved RouterBOOT stability for Alpine CPUs ("/system routerboard upgrade" required);
*) routerboard - removed unnecessary serial port for netPower16P and hAP ax lite devices ("/system routerboard upgrade" required);
*) routerboot - increased etherboot bootp timeout to 40s on MIPSBE and MMIPS devices ("/system routerboard upgrade" required);
*) sfp - fixed incorrect optical SFP temperature readings (introduced in v7.10);
*) sfp - improved interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 based switches;
*) sfp - improved optical QSFP interface handling for 98DX8332, 98DX3257, 98DX4310, 98DX8525 switches;
*) sfp - improved Q/SFP interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 switches;
*) sfp - reduce CPU load due to SFP interface handling for CCR2116, CCR2216, CCR2004-12S+2XS, CRS312, CRS518 devices (introduced in v7.9)
*) sms - increased wait time for modem startup;
*) ssh - fixed host public key export (introduced in v7.9);
*) ssh - fixed private key import (introduced in v7.9);
*) ssh - fixed SSH key agreement on the client side when ed25519 used under server settings;
*) ssh - fixed user RSA private key import;
*) switch - fixed "reset-counters" for "switch-cpu";
*) switch - fixed BPDU packet processing on MT7621, MT7531 with HW offloaded vlan-filtering;
*) switch - improved multicast packet forwarding on MT7621;
*) system - disallow setting a non-existing CPU core number for system IRQ;
*) system - increased maximum supported CPU core count to 512 on CHR and x86;
*) system - reduced RAM usage for SMIPS devices;
*) tftp - improved file name matching;
*) user - added "sensitive" policy requirement for SSH key and certificate export;
*) w60g - improved stability for Cube 60Pro ac and CubeSA 60Pro ac devices;
*) webfig - added option to enable wide view in item list;
*) webfig - fixed "Connect To" configuration changes for L2TP client;
*) webfig - fixed gray-out italic font for entries after enable;
*) webfig - use router time zone for date and time;
*) wifiwave2 - added "steering" parameters and menu to set up and monitor AP neighbor groups (CLI only);
*) wifiwave2 - added more information on roaming candidates to BSS transition management requests (802.11v) and neighbor report responses (802.11k);
*) wifiwave2 - added option to filter frames captured by the sniffer command (CLI only);
*) wifiwave2 - automatically add wifi interfaces to appropriate bridge VLAN when wireless clients with new VLAN IDs connect;
*) wifiwave2 - changed default behavior for handling duplicate client MAC addresses, added settings for changing it (CLI only);
*) wifiwave2 - enabled PMK caching with EAP authentication types;
*) wifiwave2 - fixed "reg-info" information for several countries;
*) wifiwave2 - fixed "security.sae-max-failure" rate not limiting authentications correctly in some cases;
*) wifiwave2 - fixed clearing CAPsMAN Common Name when disabling "lock-to-caps-man";
*) wifiwave2 - fixed interface hangs on IPQ6010-based boards (introduced in v7.9);
*) wifiwave2 - improved stability when changing interface settings;
*) wifiwave2 - improved stability when receiving malformed WPA3-PSK authentication frames;
*) wifiwave2 - make info log less verbose during client roaming (some info moved to wireless,debug log);
*) wifiwave2 - rename "reg-info" country argument from "Macedonia" to "North Macedonia";
*) wifiwave2 - use correct status code when rejecting WPA3-PSK re-association;
*) winbox - added missing status values for Ethernet and Cable Test;
*) winbox - added warning about non-running probe due to "startup-delay";
*) winbox - fixed "Storm Rate" property under "Switch/Port" menu;
*) winbox - fixed BGP affinity display;
*) winbox - fixed default "Ingress Filtering" value under "Bridge" menu;
*) winbox - improved supout.rif progress display;
*) winbox - rename "Group Master" property to "Group Authority" under "Interface/VRRP" menu;
*) wireguard - fixed peer connection using DNS name on IP change;
*) wireguard - fixed peer IPv6 "allowed-address" usage;
*) wireless - ignore EAPOL Logoff frames;
*) x86 - updated e1000 driver;
Release 7.10.22023-07-12
What's new in 7.10.2 (2023-Jul-12 12:45):
Release 7.10.12023-06-27
What's new in 7.10.1 (2023-Jun-27 12:03):
Release 7.102023-06-15
What's new in 7.10 (2023-Jun-15 08:17):
!) ipv6 - fixed DNS server processing by IPv6/ND services (CVE-2023-32154);
!) route - added BFD;
*) bgp - allow to filter BGP sessions by AFI;
*) bgp - changed default VPNv4 import distance to iBGP value (200);
*) bgp - do not check route distinguisher on import;
*) bgp - fixed "as-override" and rename to "output.as-override";
*) bgp - fixed "remove-private-as" and rename to "output.remove-private.as";
*) bgp - show address family in advertisements;
*) bgp - show approximate received prefix count by the session;
*) branding - fixed custom logo (introduced in v7.8);
*) bridge - fixed HW offloaded STP state on port disable;
*) bridge - fixed HW offloading for vlan-filtered bridge on devices with multiple switches (introduced in v7.8);
*) bridge - fixed incorrect host moving between ports with enabled FastPath;
*) certificate - fixed displaying of certificate serial number;
*) certificate - improved error reporting for Let's Encrypt certificate;
*) certificate - restore available "key-usage" property options;
*) conntrack - added read-only "active-ipv4" and "active-ipv6" fields to "/ip/firewall/connection/tracking" (CLI only);
*) console - added timeout error for configuration export;
*) console - changed time format according to ISO standard;
*) console - disable output when using "as-value" parameter;
*) console - fixed ":terminal inkey" input when resizing terminal;
*) console - fixed "print without-paging" output in some cases;
*) console - hide past commands with sensitive arguments;
*) console - improved stability when using command completion;
*) container - fixed "container pull" to support OCI manifest format;
*) container - fixed crash due to missing system directories;
*) container - improved default internal environment values;
*) defconf - allow to use device factory preset credentials in Flashfig and Netinstall configuration files;
*) defconf - fixed default configuration for RBSXTLTE3-7;
*) dhcp-server - fixed accounting on RADIUS interim update;
*) dhcpv4-server - added name for "IPv6-Only Preferred" option (108) in debug logs;
*) doh - less verbose logging;
*) firewall - added "endpoint-independent-nat" support;
*) firewall - added "nth" option for IPv6 firewall;
*) gps - expose GPS port for Quectel RM520N-GL;
*) ike2 - improved child SA delete request processing;
*) iot - added option to send Modbus function code commands directly from RouterOS (CLI only);
*) ipsec - added hardware acceleration support for IPQ-5010 (hAP ax lite);
*) ipsec - refactor public key authentication;
*) ipsec - removed "ec2n185" and "ec2n155" values from proposal configurations;
*) ipv6 - fixed IPv6 address removal;
*) l3hw - added "autorestart" option to L3HW settings;
*) l3hw - added advanced configuration options for fine-tuning the L3HW offload (l3hw-settings are cleared after upgrade or downgrade) (CLI only);
*) l3hw - added error message and reset "l3-hw-offloading=no" if L3HW driver fails to start;
*) l3hw - added monitoring options for L3HW utilization (CLI only);
*) l3hw - fixed /32 route deletion;
*) l3hw - fixed IPv6 ECMP route offloading;
*) l3hw - fixed offloading of /32 IPv4 and /128 IPv6 routes;
*) l3hw - fixed route table offloading during large volume of route updates;
*) l3hw - improved host and nexthop offloading;
*) l3hw - improved offloading of IPv6 hosts after L3HW driver restart;
*) l3hw - improved performance of partial offloading;
*) l3hw - improved route offloading after gateway change;
*) l3hw - improved system stability for partial routing table offload;
*) leds - fixed modem RAT mode indication on hAP ac^3 LTE6 WPS mode button LEDs;
*) lora - improved gateway card detection and upgrade logic;
*) lora - updated firmware version for LoRaWAN gateway (for R11e-LoRa8, R11e-LoRa9 cards);
*) lte - added serving cell query for MBIM modems with necessary MBIM extension;
*) lte - disable DHCP request filtering (UDP port 67) for Chateau 5G;
*) lte - fixed APN authentication for R11e-LTE6 modem;
*) lte - fixed Google Pixel 7 tethering support;
*) lte - improved MBIM modem firmware reported error handling when settings RAT modes;
*) lte - improved modem firmware upgrade stability for MBIM modems;
*) lte - improved stability for Chateau 5G LTE modem firmware upgrade;
*) lte - reduced SIM slot switchover time for MBIM modems with UUIC reset support;
*) lte - stop "cell-monitor" on LTE interface configuration change for MBIM modems;
*) mpls - added FastPath support;
*) netwatch - added warning about non-running probe due to "startup-delay" (CLI only);
*) ovpn - added initial support for V2 data transfer protocol;
*) ovpn - improved system stability;
*) poe - fixed bogous "poe-in-voltage" values when using DC jack for RB5009;
*) pppoe - fixed PPPoE client scan when server is sending PADO messages without Service-Name tag;
*) qos-hw - added QoS marking support for 98DXxxxx switches (CLI only);
*) qos-hw - renamed VLAN "priority" field to "pcp" to avoid confusion;
*) rose-storage - added support for multiple smb users and smb shares;
*) route - improved system stability when removing multicast forwarding entries;
*) routerboard - fixed memory test on CCR2116-12G-4S+ ("/system routerboard upgrade" required);
*) routerboot - increased "preboot-etherboot" maximum value to 30 seconds ("/system routerboard upgrade" required);
*) scheduler - fixed incorrectly started scheduler during reboot or shutdown;
*) sfp - fixed "rate" monitor value for SFP interface on L009UiGS series devices;
*) sfp - fixed combo-ether link monitor for CRS328-4C-20S-4S+ switch;
*) sfp - fixed combo-sfp linking at 1G rate for CRS312 switch;
*) sfp - improved 10G interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 based switches;
*) sfp - improved module compatibility with bad EEPROM data for RB4011, RB5009, CCR2xxx, CRS312 and CRS518 devices;
*) sfp - improved SFP interface handling for RB4011, RB5009, CCR2xxx and CRS518 devices;
*) sfp - improved system stability with certain SFP modules for CCR2216 and CRS518 devices;
*) sfp - report EEPROM data even if "auto-init-failed" has occurred;
*) smb - improved SMB v1 operation;
*) sniffer - fixed large .pcap file limit;
*) snmp - added "engine-id-suffix" setting and display actual "engine-id" as read-only property;
*) snmp - added BGP peer table support IPv4 only (1.3.6.1.2.1.15.3.1);
*) snmp - added new "mtxrInterfaceStatsTxRx1024ToMax" OID to MIKROTIK-MIB;
*) ssh - added inline key "passphrase" property;
*) ssh - fixed RouterOS SSH client login when using a key (introduced in v7.9);
*) switch - added more precise "storm-rate" configuration options for 98DXxxxx switches (CLI only);
*) switch - fixed storm rate on 10G links for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255 switches;
*) system - improved watchdog reporting in log after reboots for several ARM and ARM64 devices;
*) tile - fixed support for microSD card;
*) tr069 - added 5G SCC "SNR" parameter for modems that report it;
*) upgrade - do not run manual upgrade if some packages are missing;
*) ups - fixed updating of "battery-voltage" property;
*) vrrp - added warning if "sync-connection-tracking=yes" while the global connection tracking is inactive;
*) vrrp - added warning if the VRRP group is misconfigured;
*) vrrp - added warning if VRRP or its interface does not have an IP address;
*) vrrp - do not start connection synchronization if the global connection tracking is inactive;
*) vrrp - fixed issue where disabled VRRP interface is affecting group;
*) vrrp - fixed VRRP interface state on physical cable disconnection;
*) vrrp - improved system stability on changing "group-authority" or "sync-connection-tracking";
*) vrrp - renamed "group-master" to "group-authority" to avoid confusion with VRRP master;
*) vrrp - send VRRP announcements only by "group-authority";
*) w60g - improved interface stability for PTMP setups;
*) webfig - added high-resolution favicon;
*) webfig - allow limitless upper bounds for number range;
*) webfig - allow to set "0" second time for fields with default values;
*) webfig - changed time format according to ISO standard;
*) webfig - display date and time in local time zone;
*) webfig - fixed missing "WifiWave2" menu;
*) webfig - fixed missing property names in "WifiWave2" menu;
*) webfig - redesigned item configuration display;
*) webfig - redesigned top menu bar;
*) webfig - removed "Tools/Telnet" menu;
*) webfig - removed auto-login with default credentials (admin without a password);
*) wifiwave2 - avoid transmitting extra bytes at the end of the packet after stripping a VLAN tag;
*) wifiwave2 - do not show placeholder transmit power values on interface startup;
*) wifiwave2 - fixed CAP connection when provisioning "manager=capsman";
*) wifiwave2 - fixed CAP interface name when using "name-format";
*) wifiwave2 - fixed connectivity issues wheen access-list is used;
*) wifiwave2 - fixed DFS channel availability warning (introduced in v7.9);
*) wifiwave2 - fixed dynamic interface adding to bridge on CAP device;
*) wifiwave2 - fixed inability to disable CAPsMAN when there are RADIUS-authenticated clients connected;
*) wifiwave2 - fixed incorrect limits on number of interfaces in station mode;
*) wifiwave2 - fixed interface name change when restoring backup;
*) wifiwave2 - fixed key handshake timeout with re-associating clients;
*) wifiwave2 - fixed OWE authentication compatibility with 802.11ax client devices;
*) wifiwave2 - fixed OWE authentication compatibility with third-party client devices (introduced in v7.8);
*) wifiwave2 - fixed wireless throughput issues after 802.11r client roaming events on 802.11ac devices;
*) wifiwave2 - improve protections against DoS attacks on WPA3-PSK;
*) wifiwave2 - improved logging when an interface is unable to assign a VLAN tag to client;
*) wifiwave2 - improved system stability when trying to exceed virtual AP limit;
*) wifiwave2 - less verbose logging when WPA3-PSK clients are connecting;
*) wifiwave2 - other system stability improvements;
*) wifiwave2 - restore interface running state when connection to CAPsMAN is lost;
*) winbox - added "MPLS/Settings" menu;
*) winbox - added "Queues" configuration tab when creating new entries under "IPv6/DHCP-Server" menu;
*) winbox - rename "URL" property to "Action data" under "IP/Web-Proxy/Access" menu;
*) wireguard - fixed IPv6 traffic processing with multiple peers;
*) wireguard - retry "endpoint-address" DNS query on failed resolve;
*) x86 - ice driver update to v1.11.14;
*) zerotier - make "identity" setting sensitive;
Release 7.9.22023-05-31
What's new in 7.9.2 (2023-May-30 16:49):
*) sfp - improved SFP interface handling for RB4011 device;
Release 7.9.12023-05-22
What's new in 7.9.1 (2023-May-19 15:11):
Release 7.92023-05-02
What's new in 7.9 (2023-May-02 08:35):
*) bgp - improved BGP VPN selection;
*) bridge - added warning log when "ageing-time" exceeds supported hardware limit for 98DX224S, 98DX226S, and 98DX3236 switch chips;
*) bridge - fixed FastPath when setting "use-ip-firewall-for-vlan" or "use-ip-firewall-for-pppoe" without enabled "use-ip-firewall";
*) certificate - fixed bogus log messages;
*) chr - fixed public SSH key pulling when running on AWS;
*) console - added "/task" submenu (CLI only);
*) console - added option to create new files using "/file add" command (CLI only);
*) console - improved stability when doing "/console inspect" in certain menus;
*) console - improved stability when editing long strings;
*) console - improved system stability;
*) console - removed bogus "reset" command from "/system resource usb" menu;
*) console - rename flag "seen reply" to "seen-reply" under "/ipv6 firewall connection" menu;
*) console - replaced "fingerprint" with "skid" in "/certificate print";
*) console - show Ethernet advertise, speed and duplex settings depending on configured auto-negotiation;
*) container - fixed invoking "container shell" more than once;
*) container - improved "container pull" to support OCI manifest format;
*) defconf - added CAPs mode script for wifiwave2 devices;
*) detnet - fixed interface state detection after reboot;
*) dhcp - changed the default lease time for newly created DHCP servers to 30 minutes;
*) dhcpv4-server - release lease if "check-status" reveals no conflict;
*) disk - improved system stability when removing USB while formatting;
*) ethernet - fixed half-duplex forced mode at 10Mbps and 100Mbps on ether1 for RB5009, Chateau 5G ax and hAP ax3 devices;
*) filesystem - fixed partition "copy-to" function;
*) firewall - added "connection-nat-state" to IPv6 mangle and filter rules;
*) health - added limited manual control over fans for CRS3xx, CRS5xx, CCR2xxx devices;
*) health - fixed bogus value reporting for CRS510 device;
*) ike2 - fixed minor logging typo;
*) ipsec - added error log message when peer ID does not match certificate;
*) ipsec - fixed packet processing by hardware encryption engine on RB850Gx2 device;
*) ipsec - refactor X.509 implementation;
*) ipv6 - added "valid" and "lifetime" parameters for SLAAC IPv6 addresses;
*) ipv6 - send out RA packet with "preferred-lifetime" set to "0" when IPv6 address is deactivated;
*) l3hw - improved route offloading for 98DX224S, 98DX226S, and 98DX3236 switch chips;
*) leds - disable LEDs after "/system shutdown";
*) lte - capped maximum lifetime of SLAAC address to 1 hour;
*) lte - fixed CA band clearing on RAT mode change;
*) lte - fixed duplicate IPv6 route for lte interface when "ipv6-interface" setting is used;
*) lte - fixed LTE interface not showing up when resetting RouterOS configuration;
*) lte - fixed passthrough mode when used together with another APN for Chateau 5G;
*) lte - fixed R11-LTE-US in LTE passthrough mode;
*) lte - fixed R11e-LTE-US reporting of RSSI in LTE mode;
*) lte - fixed re-attach in some cases where module would stay in not-running state after network detach;
*) lte - fixed second modem halt on dual R11e-LTE6 setup;
*) lte - improved system stability when changing LTE interface configuration during network scan with MBIM modems (introduced in v7.8);
*) mpls- fixed LDP "preferred-afi" parameter;
*) netinstall-cli - improved device reinstall on failed attempt;
*) netwatch - added "startup-delay" setting (CLI only);
*) netwatch - improved ICMP status evaluation when no reply was present;
*) netwatch - limit "start-delay" range;
*) ospf - fixed processing of fragmented LSAs;
*) ovpn - added support for OVPN server configuration export and client configuration import from .ovpn file;
*) ovpn - improved system stability for Tile devices;
*) quickset - fixed displaying of "SINR" when value is 0;
*) rose-storage - added option to nvme-discover with hostname (CLI only);
*) rose-storage - fixed crash on nvme-tcp disable;
*) rose-storage - fixed rsync transfer permissions;
*) rose-storage - various stability fixes;
*) route - fixed "dynamic-id" for VRF tables;
*) route - improved system stability when making routing decision;
*) route - show SLAAC routes under the "/routing route" menu;
*) route-filter - improved stability when matching blackhole routes;
*) routerboot - added "preboot-etherboot" and "preboot-etherboot-server" settings ("/system routerboard upgrade" required) (CLI only);
*) sfp - added log warning about failed auto-initialization on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices;
*) sfp - allow modules that hold "TX_FAULT" high signal all the time on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices;
*) sfp - allow modules with bad or no EEPROM in forced mode on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices;
*) sfp - fixed "rate-select" functionality on CCR2004-16G-2S+ and CCR2004-1G-12S+2XS devices (introduced in v7.8);
*) sfp - improved module initialization and display more detailed initialization status on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices;
*) sfp - improved SFP28 interface stability with some optical modules for CRS518 switch;
*) sfp - improved system stability with some SFP GPON modules on RB4011, RB5009, CCR2004-1G-12S+2XS, CCR2004-16G-2S+, CCR2116-12G-4S+, CCR2216-1G-12XS-2XQ devices;
*) snmp - fixed SNMPv3 "Reportable" flag behavior;
*) snmp - improved outputting of routes;
*) socks - added VRF support;
*) ssh - added Ed25519 host key support;
*) ssh - added support for Ed25519 key export and import in PKCS8 format;
*) ssh - do not allow SHA1 usage with strong crypto enabled;
*) ssh - improved service responsiveness when changing SSH service settings;
*) ssh - improved SSH key import process;
*) storage - mount RAM drive for devices with 32MB flash;
*) supout - added DHCP server network section;
*) switch - fixed ACL rules matching IPv6 packets when using only IPv4 matchers;
*) switch - improved system stability during rapid MAC flapping for 98DXxxxx switches;
*) switch - improved system stability for 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 switches;
*) timezone - updated timezone information from "tzdata2023c" release;
*) vrrp - added "self" value for "group-master" setting;
*) vxlan - added forwarding table;
*) vxlan - fixed packet drops when host moves between remote VTEPs;
*) webfig - added inline comments;
*) webfig - fixed "Destination" value under "MPLS/Forwarding-Table" menu;
*) webfig - fixed issue where "Certificate" value disappears under "IP/Services" menu;
*) webfig - fixed issue where entries might be missing under "IP/DHCP-Server" menu;
*) webfig - various stability fixes;
*) wifiwave2 - added "radio/reg-info" command to show regulatory requirements (currently implemented for 802.11ac interfaces) (CLI only);
*) wifiwave2 - added ability to configure antenna gain;
*) wifiwave2 - added ability to configure beacon interval and DTIM period;
*) wifiwave2 - added information on additional interface capabilities to radio parameters;
*) wifiwave2 - automatically add a VLAN-tagged interface to the appropriate bridge VLAN;
*) wifiwave2 - exit sniffer command and return error when trying to sniff on an unsupported channel;
*) wifiwave2 - fixed 802.11r roaming for clients that performed initial authentication with an AP which has been restarted since;
*) wifiwave2 - fixed issue of some supported channels not being listed in the radio parameters;
*) wifiwave2 - fixed issue which lead to VLAN-tagged wireless clients receiving tagged traffic from other VLANs;
*) wifiwave2 - fixed key handshake timeout for re-associating client devices on 802.11ac interfaces;
*) wifiwave2 - fixed VLAN tagging for unencrypted (open) APs;
*) wifiwave2 - improved general interface stability;
*) wifiwave2 - improved regulatory compliance for hAP ax^2, hAP ax^3 and Chateau ax;
*) wifiwave2 - improved WPS connection speed;
*) wifiwave2 - increased maximum value for "channel.frequency" to 7300;
*) wifiwave2 - show information on captured packets and added ability to save them locally in a pcap file;
*) winbox - added "MTU" and "Hoplimit" properties under "IPv6/Routes" menu;
*) winbox - added "Preferred AFI" property under "MPLS/LDP-Instance" menu;
*) winbox - added "S" flag under "IPv6/Firewall/Connections" menu;
*) winbox - added "Tx Power" property under "Wifiwave2/Status" menu;
*) winbox - added "Tx Queue Drops" property under interface settings "Traffic" tab;
*) winbox - added "Username" and "Password" properties under "Container/Config" menu;
*) winbox - added "Valid" and "Preferred" properties under "IPv6/Address" menu;
*) winbox - added missing properties for "Remote ID Type" under "IP/IPsec/Identities" menu;
*) winbox - changed route flag name from "invalid" to "inactive";
*) winbox - fixed "TLS" property under "Tools/Email" menu;
*) winbox - fixed "Type" property under "System/Disk" menu when "rose-storage" package is installed;
*) winbox - fixed changing slot name under "System/Disk" menu;
*) winbox - fixed default value for "Allow managed" property under "Zerotier" menu;
*) winbox - fixed duplicate "My ID" column under "IP/IPsec/Identities" menu;
*) winbox - fixed minor typo in "WifiWave2/Radios" menu;
*) winbox - fixed missing "Sector Writes" for certain devices under "System/Resources" menu (introduced in v7.8);
*) winbox - improved Ethernet advertise, speed and duplex settings;
*) winbox - only show permitted countries for wifiwave2 interfaces;
*) winbox - show missing "Designated Bridge" and "Designated Port Number" monitoring data under "Bridge/Port menu;
*) www - allow unsecure HTTP access to REST API;
*) x86 - fixed changing software-id (introduced in v7.7);
*) zerotier - upgraded to version 1.10.3;
Release 7.82023-02-27
What's new in 7.8 (2023-Feb-24 11:03):
!) storage - added new "rose-storage" package support for extended disk management and monitoring functionality (ARM, ARM64, Tile and x86) (CLI only);
*) bgp - fixed setting of "default-prepend" parameter;
*) bridge - fixed adding disabled MSTI;
*) bridge - fixed DHCP packet flow when using DHCP snooping, HW offloading and "use-ip-firewall";
*) bridge - fixed possible DHCP packet corruption when using DHCP snooping;
*) bridge - fixed PVID warning typo;
*) bridge - improved HW offloading logic;
*) certificate - fixed export of a certificate when the last line of the certificate is exactly 64 bytes long;
*) certificate - fixed PBES2 certificate import;
*) certificate - improved certificate management, signing and storing processes;
*) certificate - improved multiple certificate import process;
*) conntrack - improved system stability when changing connection tracking state;
*) conntrack - improved system stability when PPTP helper is used;
*) console - added "as-string" parameter to the ":execute" command;
*) container - added authentication option for registry (CLI only);
*) container - fixed ".type" file ownership;
*) container - fixed file ownership after system upgrade for containers running on internal disk;
*) container - fixed multiple container automatic startup on boot;
*) dhcpv4-client - send DHCPv4 unicast requests to DHCPv4 relay, instead of server when it is being used;
*) disk - limit maximum TMPFS size;
*) dns - added configurable DoH concurrent query limitation parameters;
*) dns - do not cache results from ":resolve" command with specific server;
*) dns - fixed CNAME reading from the cache;
*) dns - limited "DoH max concurrent queries reached" logging messages to once per minute;
*) dns - respond with "NOERROR" to DNS requests for static domain names when appropriate type record is not configured or found on upstream server;
*) firewall - fixed bridge priority target;
*) firewall - fixed DSCP priority target for IPv6 Mangle;
*) firewall - fixed netmap range maximum address calculation for IPv6 NAT;
*) graphing - fixed hiding of target queues when "allow-target" is disabled;
*) graphing - fixed sorting of interface and queue graphs;
*) graphing - properly handle disabled and static-binding interface graphs;
*) graphing - removed "move" command for graphing rules;
*) health - fixed "temperature" and "power-consumption" readings for RB1100AHx4;
*) hotspot - fixed setting of "address" parameter for IP binding;
*) hotspot - restore cookie timeout on reboot;
*) ike2 - added support for "address", "key-id" and "dn" for Remote ID matching (CLI only);
*) ike2 - fixed active SA flush on responder after an unsuccessful peer connection attempt;
*) ipsec - added support for "Framed-Route" RADIUS attribute support;
*) ipsec - do not match incoming IKE requests by unresolved DNS name peers;
*) ipsec - fixed peer matcher for incoming connection with unresolved DNS;
*) ipv6 - added "pref64" option configuration for RA;
*) ipv6 - improved handling of "advertise" IPv6 address status changes;
*) ipv6 - limited "hop-limit" parameter value range to 255;
*) ipv6 - made distributed DNS lifetime RFC8106 compliant;
*) l3hw - added destination MAC address check for offloaded FastTrack connections;
*) led - fixed signal reading for KNOT device;
*) leds - always require to set interface name when setting "modem-signal" indication;
*) lte - added AT support for Telit LE910C4 in MBIM mode;
*) lte - fixed APN setting usage on initial connection attempt for AT based Quectel and Neoway modems;
*) lte - fixed automatic antenna selection on Chateau LTE12/LTE18;
*) lte - fixed dialing for Fibocom L850-GL module;
*) lte - fixed displaying of "subscriber-number";
*) lte - fixed possible memory leak when using passthrough mode on Chateau 5G;
*) lte - improved AT port matching for SIMCom, Huawei, WeLink, Cinterion, BandLuxe and Sierra modems;
*) lte - improved modem detection speed in lower mini-PCIe slot on LtAP;
*) lte - improved stability for R11e-LTE6, skip connection reset on first EEMGINFO command timeout;
*) lte - LtAP improved modem detection in lower mini-PCie slot ("/system routerboard upgrade" required);
*) lte - parse USSD even if encoding is unsupported;
*) mpls - fixed handling of more than 9 VRF's;
*) mpls - fixed LDP listen socket creation before IPv6 address is ready for use;
*) mpls - improved stability when neighboring router reboots;
*) ospf - fixed "ospf-type" parameter for OSPFv3 routes;
*) ospf - fixed simple auth for OSPFv3;
*) ovpn - added AES-GCM and multicore encryption support;
*) ovpn - improved server stability;
*) ovpn - improved TLS-related error logging;
*) pimsm - improved system stability;
*) poe - added LLDP power management support for 802.3at PSE;
*) poe - properly turn off power when link not detected on hAP ax2 and hAP ax3;
*) port - fixed modem channel number on KNOT;
*) pppoe - fixed PPPoE client scan showing only one server;
*) resource - show filesystem related statistics on CCR2004;
*) route - fixed IPv6 default route presence when received from RA;
*) route - fixed printing of routing table's "count-only" parameter;
*) route - show hoplimit and MTU properties under the "/routing route" menu for SLAAC routes;
*) routerboot - fixed format storage for RBM33G device ("/system routerboard upgrade" required);
*) routerboot - fixed protected routerboot for RBM33G device ("/system routerboard upgrade" required);
*) sfp - fixed false link detection with S+RJ10 on RB5009;
*) sfp - fixed reading of SFP EEPROM on single SFP port devices;
*) sfp - improved optical modules SFP compatibility on CCR2004-16G-2S+, CCR2004-1G-12S+2XS, CCR2116-12G-4S+ devices;
*) sms - improved reporting of SMS sending errors;
*) sms - log USSD response when USSD is sent over MBIM;
*) sniffer - added additional filtering parameters;
*) snmp - do not show identity in LLDP when branding is used with hide SNMP data;
*) snmp - fixed handling of disabled routes;
*) snmp - fixed reporting of total number of routes counter;
*) ssh - hard-coded "localhost" address for forwarding requests;
*) ssh - improved system stability when processing none-crypto SSH connection;
*) sstp - fixed TLS session establishment when "connect-to" is DNS name;
*) switch - fixed SFP rate select for CRS354 devices;
*) switch - improved 10G, 25G, 40G and 100G interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 switches;
*) switch - improved system stability for 98DXxxxx switch chips;
*) swos - removed "/system swos" menu for CRS5xx series switches;
*) torch - allow "without-paging" parameter for Torch;
*) traffic-generator - increased maximum allowed stream count;
*) upgrade - show error message when license prohibits upgrade;
*) usb - changed USB auto detect behavior to default to the external USB, when no internal USB devices detected;
*) vxlan - added "dont-fragment" setting that allows managing fragmentation;
*) vxlan - added "max-fdb-size" parameter;
*) vxlan - added FastPath support;
*) webfig - allow setting numeric values in time interval fields;
*) webfig - fixed accessing of WebFig when "Interface" menu is disabled by skin;
*) webfig - fixed editing of multi-field parameters with "not" checkbox;
*) webfig - fixed handling of empty skin files;
*) webfig - improved navigation responsiveness;
*) webfig - improved skin file parsing;
*) webfig - improved terminal operation;
*) webfig - properly escape all reserved URI characters;
*) webfig - updated WebFig and graph web pages to HTML5;
*) wifiwave2 - added wireless sniffer tool to capture wireless transmissions (CLI only);
*) wifiwave2 - adjust monitoring of station interfaces to report when an interface is authorized, not just connected;
*) wifiwave2 - enabled additional channels in UNII-3 and UNII-4 bands for Europe and USA on hAP ax^2, hAP ax^3 and Chateau ax;
*) wifiwave2 - fixed compatibility with third-party devices when using SAE hash-to-element authentication with DH groups 20 and 21;
*) wifiwave2 - fixed SAE authentication for interfaces in station mode when trying to connect to APs which require an anti-clogging token (introduced in RouterOS 7.4);
*) wifiwave2 - implement 802.11w management protection SA Query procedures;
*) wifiwave2 - improve protections from denial-of-service attacks on WPA3;
*) winbox - added "Connect" button under "WifiWave2/Scan" menu;
*) winbox - added "Disable/Enable" buttons under "WifiWave2" menu;
*) winbox - added "Match Subdomain" parameter under "IP/DNS/Static" menu;
*) winbox - added "Provision" button under "WifiWave2" menu;
*) winbox - added "Start On Boot" checkbox under "Container" menu;
*) winbox - added "Tx Rate" and "Rx Rate" columns under "WifiWave2/Registration" menu;
*) winbox - added missing properties when setting "Use DoH Server";
*) winbox - added missing WifiWave2 related parameters under "WifiWave2" menu;
*) winbox - added support for manual RAM file system (TMPFS) creation under "System/Disk" menu;
*) winbox - added Type "https-get" parameter under "Tools/Netwatch" menu;
*) winbox - allow selecting bridge for static entries under "Bridge/MDB" menu;
*) winbox - fixed displaying of "Default Prepend" value under "Routing/BGP/Sessions" menu;
*) winbox - fixed displaying of "Tx/Rx CCQ" values under "Wireless/Registration" menu;
*) winbox - fixed displaying of flags under "System/Console" menu;
*) winbox - fixed displaying of multiple character flags;
*) winbox - fixed usage of IPv6 family addresses under "IP/Web Proxy/Access" menu;
*) winbox - hide "TTL" value for static DNS entries with FWD type;
*) winbox - hide unnecessary properties for virtual interfaces under "WifiWave2" menu;
*) winbox - improved mouseover hint for "local" policy under "System/Users/Groups" menu;
*) winbox - rename "Multicast Router" monitoring property to "Is Multicast Router" under "Bridge" menu;
*) winbox - show "Gateway" column by default under "IPv6/Routes" menu;
*) x86 - added support for TP-Link TG-3468;
*) x86 - fixed SR-IOV support for Intel X710 series NIC;
*) x86 - improved Intel 500 series 10G SFP module support;
*) x86 - improved stability for Intel X550 series NIC with SR-IOV;
*) zerotier - fixed routes after VRF change;
Release 7.72023-01-12
What's new in 7.7 (2023-Jan-12 09:35):
*) bgp - added comment functionality for BGP VPN (CLI only);
*) bgp - do not reflect route back to sender;
*) bgp - fixed BGP advertisement PCAP saver;
*) bgp - fixed connection establishment using link-local addresses;
*) bgp - improved BGP advertisement printing;
*) bgp - improved BGP session load distribution across multiple CPU cores;
*) bgp - properly set "bgp-ext-communities" from "communities" list;
*) bluetooth - added unique advertise message filtering;
*) bonding - properly detect VPLS interface state changes;
*) branding - fixed identity setting from branding package;
*) bridge - added support for static MDB entries;
*) bridge - disallow port-controller while the bridge has MSTP enabled;
*) bridge - fixed "edge=yes" setting for MSTP;
*) bridge - fixed MSTP compatibility with STP;
*) bridge - fixed R/M/STP bridge identifier on protocol-mode change;
*) bridge - fixed RSTP BCP with bridged PPP interfaces;
*) bridge - fixed STP blocking state on port-controller;
*) bridge - fixed host moving with fast-path;
*) bridge - fixed incorrect root port blocking for MSTP;
*) bridge - fixed master port conversion;
*) bridge - fixed mst-override port priority for MSTP;
*) bridge - fixed port priority for STP and RSTP;
*) bridge - improved port-controller system stability;
*) bridge - improved system stability when using MSTP and many VLAN mappings;
*) bridge - removed "age" monitoring property from the host table;
*) certificate - improved Let's Encrypt logging and error recovery;
*) conntrack - improved system stability when processing SCTP connections on TILE;
*) console - updated copyright notice;
*) container - fixed access to "/dev/stderr" from containers;
*) container - fixed handling of groups and usernames from Dockerfile;
*) container - fixed tar extracting;
*) container - made "ram" and "tmp" directories use tmpfs;
*) crs1xx/2xx - fixed "new-customer-pcp" setting for ACL rules;
*) dhcpv6-client - handle receiving of invalid T1 and T2 times;
*) discovery - added "discovered-by" parameter to indicate which protocol discovered the neighbor;
*) discovery - added "mode" parameter for discovery configuration;
*) discovery - fixed neighbor discovery on Mesh interfaces;
*) discovery - report IPv6 LL address if global address does not exist;
*) disk - added support for manual RAM file system (TMPFS) creation (CLI only);
*) disk - improved external storage file system mounting, formatting and naming;
*) dns - do not query upstream DNS servers for matched regex records;
*) dns - fixed changing of "forward-to" parameter for FWD entries;
*) dns - fixed handling of CNAME entry pointing to another FWD entry;
*) dns - fixed handling of FWD entries where "forward-to" is a hostname;
*) dns - fixed incorrect TTL=0 reporting for cached entries;
*) dns - improved resolved static entry addition to address list;
*) dns - improved service stability when CNAME points to a FWD entry;
*) dns - query upstream DNS servers for other record types even if static entry exists;
*) dns - require "write" policy for DNS cache flushing;
*) dns - respond with lowest TTL for inner queries containing A, AAAA, CNAME chains;
*) filesystem - fixed repartition on devices with containers;
*) firewall - added "set-priority" option for IPv6 mangle firewall;
*) firewall - made "dynamic" parameter settable for IPv4 address lists;
*) hotspot - added "install-hotspot-queue" parameter to control dynamic queue creation;
*) hotspot - fixed maximum allowed connections limitation;
*) hotspot - fixed minor memory leak after each successful login from WEB;
*) hotspot - improved limitation of maximum allowed connections;
*) hotspot - improved system stability when clients migrate between bridge ports or VLANs;
*) ike1 - disallow "remote-id" setting for identity;
*) ike1 - fixed XAuth responder trying to recreate phase 1;
*) ike1 - improved expired IPsec-SA processing;
*) ike2 - added support for ChaChaPoly1305 encryption;
*) ike2 - added support for DH Group 31 (EC25519) (CLI only);
*) ike2 - fixed rekey notify creation;
*) ike2 - improved certificate payload parsing;
*) interface - do not allow adding invalid "veth" interfaces;
*) interface - improved system stability when handling large packets on CCR2216;
*) interface - show RTL8153 CDC Modem Device as ethernet;
*) ipsec - added "current-address" parameter for peers with DNS address;
*) ipsec - added hardware acceleration support for IPQ-6010;
*) ipsec - added support for AVX optimized SHA acceleration;
*) ipsec - improved "H" (hw-aead) flag presence for accelerated SA's;
*) ipsec - improved IKE payload processing;
*) ipsec - improved configuration of IPsec proposal auth-algorithms;
*) ipsec - removed Blowfish and Camellia encryption algorithms for IKE;
*) ipv6 - do not generate LL addresses for VPN interfaces when IPv6 is disabled;
*) ipv6 - do not use invalid/disabled global addresses for IPv6 ND;
*) l2tp - added VRF support for L2TP Ether interfaces;
*) l3hw - fixed host offloading in a case of MAC address change;
*) l3hw - fixed offloaded NAT for CRS309 switch;
*) l3hw - improved system stability when disabling or enabling L3HW offloading;
*) leds - fixed default LED configuration on netFiber 9;
*) leds - fixed turning off LEDs after system shutdown;
*) lte - added AT channel support for Telit FN990;
*) lte - added CA information in 5G mode;
*) lte - fixed error handling on opening AT control channel;
*) lte - fixed new MTU value validation;
*) lte - improved stability when LTE passthrough is enabled on Chateau 5G;
*) lte - properly show leading zeros in MCC and MNC strings;
*) lte - show band number in "ca-band" in NSA mode on Chateau 5G;
*) lte - use RSRP value reported by MBIM signal for MBIM type modems;
*) macsec - fixed packet duplication on Ethernet interface;
*) macsec - fixed packet transmission using traffic-generator;
*) macsec - fixed packet validation;
*) modem - added USB tethering support for Google Pixel 7 devices;
*) mpls - added VPLS LDP information in remote/local-mappings;
*) mpls - fixed assigning of explicit null label for IPv6;
*) netinstall - added "-i " parameter for Netinstall (CLI Linux);
*) netinstall - fixed Netinstall procedure on RouterBOOT versions from 3.27 to 6.41;
*) netinstall - improved automatic netbooting interface selection;
*) netwatch - added support for "https-get" type (CLI only);
*) netwatch - fixed reporting of VRF name in logging messages;
*) netwatch - improved "interval" and "packet-interval" coexistence for ICMP type;
*) ntp - log error message when server is unreachable;
*) ospf - fixed MD5 checksum calculation;
*) ospf - fixed simple authentication and checksums for NBMA and PTMP links;
*) ospf - fixed simple authentication checksum calculation;
*) ospf - fixed virtual-link address selection for PTP links;
*) ovpn - added "CBC" postfix to AES cipher names;
*) ovpn - added "route-nopull" option for client side;
*) ovpn - added hardware acceleration support for IPQ-6010;
*) ovpn - added support for IPv6 tunneling;
*) ovpn - fixed "Called-Station-Id" usage in RADIUS requests;
*) package - fixed missing menus when both "lora" and "wifiwave2" packages are installed;
*) ping - fixed ARP ping;
*) port - added serial port support for Telit FN990 modem;
*) port - do not show unusable USB port on hAP ax^2;
*) port - fixed R11e-LTE6 port mapping;
*) ppp - changed default lease time of dynamic DHCPv6 server to 1 day;
*) ppp - do not inherit routing mark for encapsulated packets;
*) ppp - fixed displaying of "info" command for PPP client;
*) ppp - improved authentication method negotiation;
*) pppoe - improved service stability when establishing PPPoE sessions;
*) quickset - fixed addition of bridge filter rules in bridged mode;
*) quickset - fixed interface list member table on configuration changes;
*) quickset - update DNS server IP address when changing router's IP address;
*) rb4011 - fixed reporting of current CPU frequency and changed default frequency to "auto";
*) sfp - added 2.5G SFP module support for RB5009;
*) sfp - allow usage of "10G Base-LR" mode for XS+31LC10D module;
*) snmp - added support for "lldpRemLocalPortNum" OID's;
*) snmp - improved stability when receiving bogus packets;
*) ssh - added support for Ed25519 key exchange;
*) ssh - fixed handling of non standard size RSA keys;
*) supout - added MSTI and mst-override monitor for bridge MSTP;
*) supout - added missing IPv6 firewall sections;
*) switch - avoid packet corruption in some setups for 98DX3257, 98DX3255, 98DX4310, 98DX8525 and 98PX1012 switches;
*) switch - fixed SFP Tx disable when changing auto-negotiation settings for 98DXxxxx and 98PX1012 switches;
*) switch - fixed egress mirror for 98DX4310 and 98DX8525 switches;
*) switch - hide invalid settings for 98DX3255 and 98DX8525 switch chips;
*) switch - improved 10G, 25G and 40G interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98DX8525, 98PX1012 switches;
*) switch - improved 10G, 25G and 40G interface stability for 98DX8208, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98PX1012 switches;
*) switch - improved 10Gbps Ethernet interface stability for 98DX8212 switch;
*) switch - improved 25G interface stability for 98PX1012, 98DX4310 and 98DX8525 switches (introduced in v7.6);
*) switch - increased the maximum value of "rate" for ACL rules;
*) swos - fixed "allow-from-ports" setting;
*) swos - fixed SwOS configuration changes from RouterOS;
*) swos - improved default SwOS backup file name;
*) system - allow up to 4GB of RAM allocation per process on x86, ARM64 and TILE;
*) system - improved handling of user policies;
*) timezone - updated timezone information from "tzdata2022g" release;
*) tr069-client - updated data model to version 2.15;
*) traffic-flow - fixed sending of sampling interval;
*) tunnels - added VRF support for EoIP, IPIP and GRE tunnels;
*) vpls - expose VPLS related debug logs to "vpls" logging topic;
*) vrrp - always use slave interface MTU;
*) vrrp - improved interface stability on configuration changes;
*) vxlan - added "local-address" parameter support;
*) vxlan - added VRF support;
*) w60g - improved system stability for Cube Pro devices;
*) webfig - ensure login page is displayed after each log out;
*) webfig - fixed displaying of VRF routes;
*) webfig - fixed input validation for "VPLS ID" parameter;
*) webfig - fixed setting of "DHCP Option Set" parameter;
*) webfig - improved WEB caching capabilities;
*) webfig - properly detect current location for navigation buttons;
*) webfig - properly show limited number of available options;
*) wifiwave2 - added "datapath" settings to configure data forwarding for an interface (CLI only);
*) wifiwave2 - added "ft-preserve-vlanid" parameter to control whether to change VLAN ID after FT;
*) wifiwave2 - added "provisioning" menu to automatically assign interface configurations to radios (CLI only);
*) wifiwave2 - added disable/enable commands to configuration profile sub-menus (CLI only);
*) wifiwave2 - added information of per-station throughput in the registration table;
*) wifiwave2 - added initial CAPsMAN support (only compatible with wifiwave2 interfaces) (CLI only);
*) wifiwave2 - added interworking/Hotspot 2.0 support (CLI only);
*) wifiwave2 - added more informative log messages on configuration profile changes;
*) wifiwave2 - added option to set per-client vlan-id in access list (only supported on 802.11ax interfaces) (CLI only);
*) wifiwave2 - do not permit a client device to be connected to more than one interface at a time;
*) wifiwave2 - fixed "radio-mac" provisioning matcher;
*) wifiwave2 - fixed 4-way handshake with TKIP;
*) wifiwave2 - improved compliance with regulatory domain information;
*) wifiwave2 - improved general system stability;
*) wifiwave2 - improved system stability when multiple virtual AP are configured;
*) wifiwave2 - properly report interface on which traffic is received when multiple station interfaces are used concurrently;
*) wifiwave2 - released packages for MMIPS, PPC, TILE and x86;
*) wifiwave2 - removed maximum limit for group key update interval and changed the default to 1 day;
*) winbox - added "Active" prefix for current "Circuit ID" and "Cookie Length" fields for L2TP-Ether interfaces;
*) winbox - added "Make Static" button to "IP/DHCP Server/Leases" menu;
*) winbox - added "bus" parameter for "USB Power Reset" command on Chateau ax;
*) winbox - added missing "force" parameter for new "IP/DHCP Server/Options" entries;
*) winbox - added missing "vlan-id" column under "IP/Hotspot/Hosts" table;
*) winbox - do not show LACP related status parameters for other bonding types;
*) winbox - fixed default MTU value for CAP interfaces;
*) winbox - fixed minor typo in "Zerotier" menu;
*) winbox - improved handling of large WinBox protocol messages;
*) winbox - increased maximum number of Winbox read-only sessions 5->25;
*) winbox - properly save "Interfaces/Detect Internet/Detect Internet State" menu in session file;
*) winbox - removed bogus VRF tab from "Interface" menu;
*) winbox - show "Switch" menu on Chateau 5G ax;
*) winbox - show "Switch" menu on NetFiber 9;
*) winbox - show "System/Health/Settings" only on boards that have configurable values;
*) winbox - show "System/RouterBOARD/Mode Button" on devices that have such feature;
*) winbox - show "USB Power Reset" menu on Chateau 5G ax;
*) winbox - show dynamic comment in WifiWave2 registration table;
*) wireless - fixed "nstreme" related parameter control in skins;
*) wireless - fixed setting of realms interworking parameter if realms-raw is unset;
*) x86 - added support for SUN 10G NICs;
*) x86 - improved igc driver support;
Release 7.62022-10-18
What's new in 7.6 (2022-Oct-17 13:55):
*) bgp - added support for BGP advertisement displaying (CLI only);
*) bgp - fixed reporting of session uptime;
*) bgp - improved session establishment speed after bootup;
*) bonding - fixed ARP monitor packets with bond's MAC address;
*) bonding - improved interface stability on slave configuration changes;
*) bonding - reduce "actual-mtu" according to interface "l2mtu";
*) branding - execute "autorun.scr" file when installing branding package;
*) capsman - fixed RADIUS accounting when EAP is used;
*) certificate - fixed SHA1 certificate name lookup;
*) certificate - restricted maximum retry attempt window for Let's Encrypt certificate to 60 minutes;
*) container - added "start-on-boot" parameter for automatic container startup;
*) container - allow changing container related parameters while it is running;
*) container - fixed usage of non-authenticated registries;
*) dhcpv4-server - fixed matcher functionality;
*) dhcpv4-server - fixed RADIUS accounting for local leases;
*) dhcpv4-server - improved service stability when removing dynamic leases;
*) dhcpv6-client - fixed false error status reporting when server offers T1 or T2 value as 0;
*) dns - added "match-subdomain" option for static entries (CLI only);
*) dot1x - fixed incorrect error when using "mac-auth";
*) ethernet - added "5Gbps" option for speed setting;
*) firewall - added "src/dst-address-type" parameter under "IPv6/Firewall/Mangle" menu;
*) firewall - disable IRC NAT helper on upgrade;
*) firewall - fixed IPv6 filtering with "in/out-interface" matcher that is in VRF;
*) firewall - fixed IRC NAT helper (CVE-2022-2663);
*) firewall - fixed usage of "netmap" action for IPv6 source NAT;
*) health - fixed fan speed and temperature reporting on CCR1072;
*) health - improved voltage reading on RBmAP-2nD;
*) hotspot - fixed service initialization when HTML directory configured on an external disk;
*) hotspot - fixed SSL usage on all HotSpot pages;
*) hotspot - improved stability when receiving bogus packets;
*) hotspot - limit maximum allowed connections based on free RAM resources;
*) hotspot - removed "routerboard.com" URL from default HotSpot advertise;
*) interface - added warning when interface has configured "mtu" higher than "l2mtu";
*) ipsec - added "invalid-packets" counter for Installed SA's menu;
*) ipsec - fixed packet processing by hardware encryption engine on MMIPS devices;
*) l3hw - added "l3hw-settings" sub menu under the switch menu;
*) l3hw - added support for IPv6 route offloading (disabled by default);
*) l3hw - fixed "H" flag presence for accelerated connection tracking entries;
*) l3hw - fixed possible packet loss when using HW offloaded NAT;
*) l3hw - improved connected host offloading on startup;
*) l3hw - improved connected IPv6 host offloading when routing table is nearly full for 98DX224S, 98DX226S, and 98DX3236 switch chips;
*) l3hw - made route offloading selection work only on unicast;
*) lte - added interface name in MTU debug logging message;
*) lte - added periodic IPv6 RS to trigger IPv6 adress acquisition for non-MBIM modems;
*) lte - added support for Neoway N75-EA;
*) lte - added support to perform FOTA upgrade from local file for EG12-EA, EG18-EA, RG502Q-AE, EG06-A, EP06-A modems;
*) lte - disabled RPLMN on Chateau 5G;
*) lte - fixed at-chat on Telit FN980m;
*) lte - fixed handover from UMTS to LTE when PS activation had failed for MBIM modems;
*) lte - fixed MBIM modem initialization;
*) lte - fixed re-attaching on PS detach for MBIM modems;
*) lte - removed reconnect delay after receiving DETACH notification for MBIM modems;
*) macsec - added configuration support with VLAN, ARP, DHCP and bridge tagging/untagging;
*) macsec - added logging support with "debug" and "dot1x" topics;
*) macsec - added support for MTU and L2MTU;
*) macsec - fixed interface after Ethernet link down;
*) macsec - fixed interface statistics and missing properties;
*) macsec - fixed interface status;
*) macsec - fixed multiple interface creation on different Ethernet ports
*) macsec - improved interface stability;
*) macsec - improved system stability for TILE and RB5009 devices;
*) macsec - removed interface from SMIPS devices;
*) mac-telnet - respect interface MTU setting when sending packets for MAC-Telnet and MAC-WinBox;
*) netwatch - fixed string variable values in script;
*) ntp - improved initial synchronization speed after bootup;
*) ospf - added SHA hashing for authentication;
*) ospf - fixed area "no-summary" setting;
*) ospf - fixed checksum calculation;
*) ospf - fixed displaying of VRF interface in related logs;
*) ospf - fixed transmit of LSA/ACK's on p2p interfaces;
*) ospf - improved logging when invalid configuration is detected;
*) ospf - refresh OSPFv3 interface configuration when IPv6 network becomes available;
*) ovpn - added IPv6 support;
*) ovpn - added VRF support for client;
*) ppp - fixed memory leak;
*) ppp - improved service stability when multiple users disconnect simultaneously;
*) pppoe - fixed MRU negotiation even when it is set to 1500;
*) qsfp - added interface temperature warnings and shutdown;
*) queue - improved stability for CAKE type queues;
*) radius - require "policy" policy for "login" service configuration;
*) rip - fixed passwordless MD5 authentication;
*) route-filter - fixed filtering for multiple community routes;
*) route-filter - fixed memory allocation when moving entries;
*) route - fixed disappearance of inactive static routes after upgrade;
*) route - fixed memory leak;
*) routerboard - return router's short name in "model" parameter;
*) routerboard - set "Delete" as default key to enter booter menu ("/system routerboard upgrade" required);
*) serial - added support for newer PL2303 serial controllers;
*) sfp - improved QSFP/SFP interface stability for 98DXxxxx and 98PX1012 switches;
*) sms - added "status-report-request" parameter for "send" command;
*) sms - fixed handling of SMS send attempts on unsupported modems;
*) snmp - improved retrieval of routing related OID's;
*) ssh - increased key generation timeout;
*) sstp - added VRF support for client;
*) supout - added tr069-client section;
*) supout - removed duplicate "bridge-controller" section;
*) switch - improved traffic forwarding at 5Gbps rate for 98DX8525, 98DX4310 switches;
*) system - renamed error messages when trying to edit or remove dynamic entries;
*) tile - improved system stability when processing packets;
*) tr069-client - do not allow ":" symbols in username;
*) tr069-client - fixed reporting of "X_MIKROTIK_MimoRSRP" parameter;
*) user-manager - accept any username for outer authentication;
*) user-manager - added "comment" parameter for batch user creation;
*) user-manager - added support for multiple accounting sessions;
*) user-manager - added variables to print profile name and end time in voucher templates;
*) user-manager - allow specifying router's address as subnet;
*) user-manager - fixed "migrate-legacy-db" command;
*) user-manager - fixed session expiry when it is stopped by Disconnect-Request;
*) user-manager - forced username verification against client's certificate for EAP-TLS;
*) user-manager - use "Class" attribute to associate user's accounting session;
*) user - removed unused "dude" policy;
*) vrrp - fixed connection tracking synchronization on MMIPS and MIPSBE devices;
*) vxlan - added IPv6 support for remote VTEPs (only IPv4 or IPv6 will be used at the same time, use "vteps-ip-version" property on VXLAN interface to change the version);
*) w60g - improved system stability (introduced in v7.5);
*) webfig - fixed creation of new IPv6 routes;
*) webfig - fixed displaying of "Last Seen" parameter under "IP/DHCP Server/Leases" menu;
*) webfig - fixed hex input for "Host Uniq" field;
*) webfig - fixed unsetting of "endpoint-address" parameter under "WireGuard/Peers" menu;
*) wifiwave2 - fixed enabling of unconfigured interfaces;
*) wifiwave2 - fixed malfunction of WPA3 hash-to-element technique when enabled on multiple interfaces;
*) wifiwave2 - fixed RADIUS accounting after fast-transition;
*) wifiwave2 - fixed "WPA Key Data Length" value in EAPOL frame when FT-EAP-SHA384 AKM is used;
*) winbox - added "Active" prefix for current remote and local session ID fields for L2TP-Ether interfaces;
*) winbox - added "address-list" parameter under "IP/DNS/Static" menu;
*) winbox - added "File Name" option for "Load Config" parameter under "System/SwOS" menu;
*) winbox - added icon for TR069-client menu;
*) winbox - added MACsec support;
*) winbox - added quick filtering option for route list;
*) winbox - added "Rapid Commit" parameter support under "IPv6/DHCP-Server" menu;
*) winbox - added "Reset Traffic Counters" button for all interfaces;
*) winbox - added "type" and "status-report-request" parameters under "Tools/SMS" menu;
*) winbox - allow "timeout" value to be less than 1 under "Tools/Netwatch" menu;
*) winbox - allow to rename mounted disks;
*) winbox - changed order of tabs under "User Manager" menu;
*) winbox - changed "uptime" parameter format when using the wifiwave2 package;
*) winbox - do not show unavailable features on SMIPS devices;
*) winbox - fixed interface traffic graph drawing on RB5009;
*) winbox - fixed maximum allowed value for VRRP's "priority" parameter;
*) winbox - fixed "Session Uptime" value for not established sessions under "Routing/BGP" menu;
*) winbox - fixed "Session Uptime" value under "Routing/BGP" menu;
*) winbox - fixed "System/SwOS" window refreshing after changes are detected;
*) winbox - fixed "User Manager/User Profiles" window refreshing after changes are detected;
*) winbox - made "backup.swb" the default value for SwOS backup;
*) winbox - made sessions removable in "User Manager" menu;
*) winbox - show "F" flag for failed entries under "Interfaces/VRRP" menu;
*) winbox - show "Switch" menu on Chateau LTE18 ax;
*) winbox - show "System/Health" only on boards that have health monitoring;
*) wireguard - strip whitespaces from keys;
*) wireless - disallowed using "default" as scan list or channel names;
*) wireless - fixed incorrectly applied ingress priority to non-wireless packets;
*) wireless - fixed missing wireless interface on some RB921GS-5HPacD devices;
*) www - improved stability when receiving bogus packets;
*) x86 - improved ixgbe driver support;
Release 6.49.72022-10-13
What's new in 6.49.7 (2022-Oct-11 17:37):
*) branding - fixed execution of "autorun.scr" file when installing branding package (introduced in v6.47);
*) routerboot - prevent enabling "protected-routerboot" on unsupported factory firmware versions;
*) routerboot - properly reset system configuration when protected bootloader is enabled and reset button used;
*) wireless - fixed disconnection of connected client while running background scan on wAP ac and wAP R ac devices;
Release 7.52022-08-31
What's new in 7.5 (2022-Aug-30 12:25):
*) bgp - fixed remote refuse capability options, max prefix limit errors and administrative stop;
*) bgp - improved stability when "default-originate" is configured;
*) bridge - fixed "new-priority" value validation for NAT rules;
*) capsman - added randomized range option for "reselect-interval" parameter (CLI only);
*) certificate - fixed handling of empty AKID by SCEP client;
*) console - fixed automatic command completion with keypress;
*) container - added support for running Docker (TM) containers on ARM, ARM64 and x86 (containers created before v7.4 must be recreated);
*) defconf - fixed loading of default configuration on RB4011 with WifiWave2 package enabled;
*) dhcpv4-server - fixed removal of dynamic leases when server is removed;
*) dhcpv6-client - moved invalid lifetime logging message from "debug" to "error" topic;
*) dhcpv6-client - use /128 prefix for IA_NA addresses;
*) dhcpv6-relay - fixed relay forwarding (introduced in v7.1.5);
*) dhcpv6-server - improved stability when acquiring binding;
*) dns - added "address-list" parameter for static DNS entries (CLI only);
*) firewall - added support for RTSP helper;
*) health - fixed "temperature" and "power-consumption" readings on RB1100x4;
*) health - improved voltage reading on CRS112-8P-4S;
*) health - renamed "cpu-temperature" to "switch-temperature" on CRS312-4C+8XG, CRS326-24S+2Q+, CRS354-48P-4S+2Q+, CRS354-48G-4S+2Q+, CRS504-4XQ-IN, CRS518-16XS-2XQ;
*) hostpot - fixed Walled Garden functionality for HTTPS sites;
*) hotspot - automatically reject all HTTPS requests passing through HotSpot server for unauthorized users;
*) hotspot - removed "https-redirect" option;
*) ike2 - allow sending certificate chain as initiator;
*) interface - fixed default interface naming on RB1100x2;
*) l3hw - fixed HW offloaded NAT;
*) leds - fixed default LED configuration for RBwsAP-5Hac2nD;
*) leds - fixed wireless LED functionality on LHGG;
*) lora - do not ignore negative sign for spoofed GPS coordinates;
*) lte - added at-chat and NMEA port support for Simcom modems, USB composition (device id - 0x9003);
*) lte - added at-chat support for Simcom modems, USB composition (device id - 0x9005);
*) lte - added "SIM not inserted" and "SIM failure" messages to "status" and "monitor" commands for AT modems;
*) lte - changed cell ID info display to short format for 3G connections;
*) lte - disallow empty APN name only for default entry;
*) lte - fixed AT channel for Sierra Wireless modems with device ID 0x9091;
*) lte - fixed LTE interface presence for Telit LN940;
*) lte - fixed UDP performance on MMIPS devices;
*) lte - improved antenna scan for Chateau devices with switchable antennas;
*) lte - improved configuration export when multiple LTE interfaces are present;
*) lte - modem dialer, do not reset dialing sequence if modem reply with error to user set init-string;
*) netinstall - fixed Netinstall procedure for ARM devices;
*) netwatch - automatically start migrated probes from previous RouterOS versions;
*) netwatch - changed ICMP default packet loss fail threshold to 85%;
*) ntp - fixed NTP server when "use-local-clock" is used;
*) ospf - fixed handling of external forwarding address;
*) ospf - improved stability when interface is being disabled during database exchange;
*) ovpn - fixed encryption key renewal process which caused periodic session disconnects;
*) ovpn - improved system stability when hardware acceleration is used on ARM64 devices;
*) ovpn - moved disconnected user logging message from "debug" to "info" topic;
*) ping - improved service stability;
*) port - added support for D-Link DWM-222 in serial/PPP mode (device id - 0xac01/0x7e3d);
*) port - added support for Huawei/ZTE K5006z in serial/PPP mode (device id - 0x1017/0x1018);
*) ppp - improved service stability under high load;
*) ppp - use /32 as default netmask if not specified for "routes" parameter;
*) ptp - improved system stability on CRS devices;
*) quickset - removed PPTP and SSTP server addition for "VPN" checkbox;
*) rb5009 - fixed ether1 status reporting after system reboot;
*) route-filter - fixed "delete bgp-communities" command;
*) routerboard - added "reset-button" script feature for TILE devices;
*) sfp - fixed "eeprom" reading on single SFP port ARM devices;
*) sfp - fixed QSFP+ and QSFP28 interface disable when using breakout cable;
*) sfp - fixed unresponsive "sfp1" interface after disabling "ether1" on NetMetal devices;
*) sfp - improved combo SFP ports initialization handling on CRS312-4C+8XG, CRS328-4C-20S-4S+;
*) sfp - improved stability when using 2.5G optical modules in CCR2116, CCR2216 and CRS518;
*) snmp - fixed usage of VRF after system startup;
*) socks - fixed "dst-port" usage when checking access list;
*) ssh - added AES support for PEM decryption;
*) ssh - fixed importing of public keys;
*) ssh - fixed minor typo issue when importing public key;
*) sstp - fixed client stuck in "nonce matching" state;
*) switch - fixed ACL rules for 98DXxxxx switches with more than 28 ports (introduced in v7.3);
*) switch - removed limit for number of hardware-offloaded bonding interfaces;
*) swos - enabled SwitchOS support for CRS310-1G-5S-4S+;
*) swos - fixed SwOS upgrade procedure on CRS305-1G-4S+;
*) traceroute - added "do-not-fragment" parameter support (CLI only);
*) traceroute - increased packet size limit to 65535;
*) vrrp - added "sync-connection-tracking" compatibility with preemption-mode;
*) vrrp - fixed high CPU usage when "sync-connection-tracking=yes" and the backup router goes offline;
*) vrrp - fixed HW offloaded bridge MAC address learning when changing from VRRP master to backup;
*) vrrp - fixed initial connection tracking synchronization, a backup router now always receives all existing connections;
*) vrrp - improved connection tracking synchronization protocol (CTSYNC), the new protocol is incompatible with previous RouterOS versions with "sync-connection-tracking=yes";
*) webfig - allow to specify NTP server as domain name;
*) webfig - fixed displaying of grahs in status pages;
*) webfig - fixed floating point field's negative value in -0.*** format;
*) wifiwave2 - added "sae-pwe" parameter with hash-to-element mechanism for SAE PWE derivation;
*) wifiwave2 - added support for 802.11k;
*) wifiwave2 - disable wireless interface after wireless configuration reset;
*) wifiwave2 - fixed displaying of AKM in scan results;
*) wifiwave2 - fixed duplicated AKM in RSN message;
*) wifiwave2 - fixed group key update for client devices which connect via fast BSS transition;
*) wifiwave2 - fixed incorrect AKM usage for FT-WPA3-EAP-192;
*) wifiwave2 - fixed reassociation response sending for fast transition over DS;
*) wifiwave2 - fixed setting of "ft-nas-identifier" parameter;
*) wifiwave2 - fixed usage of Canada country setting on US locked devices;
*) wifiwave2 - improved default channel width selection for interfaces in station mode;
*) winbox - do not show previously attached LTE interfaces while establishing LTE connection;
*) winbox - enabled all filters by default under "Tools/Torch" menu;
*) winbox - fixed "Enable", "Disable" and "Comment" functions for L2TP-ether type interfaces;
*) winbox - fixed "Next Run" parameter displaying under "System/Scheduler" menu;
*) winbox - fixed "Type" and "Value" field displaying under "System/Health" sub-menu's;
*) winbox - show warning messages for BGP connection entries;
*) wireless - fixed interface initialization on x86 devices;
*) x86 - allow downgrading to RouterOS v6 only if it was previously installed;
*) x86 - fixed advertising of 2500M and 5000M link speeds on ixgbe driver;
Release 7.4.12022-08-08
What's new in 7.4.1 (2022-Aug-04 14:48):
*) firewall - fixed "in-interface-list" matcher when VRF is used;
*) netwatch - fixed usage of "timeout" value in simple mode;
*) sfp - fixed speed mode setting after reinserting SFP module on CRS328-4C-20S-4S+;
Release 7.42022-07-20
What's new in 7.4 (2022-Jul-19 14:25):
Important note!!!
- Container package is not available in v7.4. Development and testing continues in "testing" channel.
Changes in this release:
*) api - fixed comma encoding within URL when using the ".proplist" argument;
*) bridge - properly process IPsec decapsulated packets through the firewall when the "use-ip-firewall" option is enabled;
*) capsman - require a unique name for configuration and configuration pre-sets;
*) certificate - fixed new CRL updating;
*) chr - fixed booting with added additional SCSI disk;
*) cloud - print critical log message when system clock gets synchronized;
*) console - added ":retry" command;
*) console - fixed situation when print output was not consistent;
*) defconf - fixed default configuration loading on devices with WifiWave2 package;
*) dhcp-relay - fixed DHCPv6 relay forward and reply creation (introduced in v7.1.3);
*) dhcp-server - change "vendor-class-id" matcher to generic option matcher;
*) dhcpv4-server - disallowed overriding message type option;
*) dhcpv4-server - log message when user option updates existing option;
*) dhcpv4-server - placed option 53 as the first one in the packet;
*) dns - convert the domain name to lowercase before matching regex;
*) dot1x - fixed "undo" command for server instances;
*) e-mail - added VRF support;
*) filesystem - fixed repartition on RB5009 series devices;
*) firewall - added "srcnat" and "dstnat" flags to IPv6/Firewall/Connection table;
*) firewall - added support for IPv6/Firewall/NAT action=src-nat rules;
*) firewall - fixed IPv6 NAT functionality when processing GRE traffic on TILE devices;
*) firewall - fixed IPv6/Firewall/RAW functionality;
*) firewall - include "connection-mark", "connection-state", and "packet-mark" when packet logging is enabled;
*) firewall - properly handle interface matcher when VRF interface is specified;
*) health - fixed requesting data from sensor when issuing "get" command;
*) health - fixed voltage reporting on some RBmAP-2nD devices;
*) hotspot - fixed ARP resolution for clients when address pool is specified on the server;
*) hotspot - fixed Walled Garden entries with action=deny;
*) ipv6 - fixed system stability when adding/removing IPv6 address;
*) l2tp - improved stability when establishing l2tp-ether connection (introduced in v7.3);
*) ldp - correctly handle AFI selection for usage on dual-stack peers;
*) leds - fixed GPS LED configuration on LtAP LTE kit;
*) leds - fixed LTE signal strength LED configuration on LHGG LTE kit;
*) leds - fixed LTE signal strength LED configuration on LtAP LTE kit;
*) lte - added AT chat support for Dell dw5821e modem;
*) lte - fixed LTE interface running state after modem reconnection;
*) lte - fixed Telit AT interface numbering;
*) lte - improved LTE interface detection for LtAP-2HnD devices;
*) lte - keep MBIM working even if AT channel fails to respond in the initialization stage;
*) lte - request connect with the same IP type as in LTE attach status for MBIM;
*) lte - show current value for "antenna" parameter when auto antenna selection fails;
*) lte - validate LTE attached IP type in MBIM mode;
*) mmips - improved USB device detection after system bootup;
*) mpls - fixed VPLS functionality when PW peer is an immediate neighbor;
*) mpls - improved stability with enabled loop-detect;
*) mqtt - fixed log flooding with disconnect messages;
*) mqtt - fixed socket error handling;
*) netwatch - added support for more advanced probing;
*) ntp - added VRF support for client and server;
*) ntp - fixed manycast server support;
*) ntp - improved "debug" log level logging;
*) ovpn - added "AUTH_FAILED" control message sending;
*) ovpn - fixed "called-station-id" RADIUS attribute value for OVPN server;
*) ovpn - use selected cipher by default when the server does not provide "cipher" option;
*) pimsm - improved system stability when changing configuration;
*) poe - hide "poe-voltage" parameter on devices that do not support it;
*) ppp - do not fail connection when trying to add existing IP address to address list;
*) ppp - log warning message when remote IP address can not be added;
*) ppp - properly try to use different authentication algorithms when Conf-Rej is received during the LCP phase;
*) quickset - specify the "in-interface-list=WAN" attribute on firewall rules created through "Port Mapping";
*) radius - added VRF support for RADIUS client;
*) route - added option to join static IGMP and MLD groups (available in "/routing/gmp" menu);
*) route - expose all valid routes to route select filter from BGP;
*) route - expose all valid routes to route select filter from OSPF and RIP;
*) route - fixed false route type detection as blackhole;
*) route - fixed log messages when changing routing configuration;
*) route - made export run faster on tables with a large number of dynamic routes;
*) route - provide more detailed information about prefixes when using "discourse" tool;
*) route-filter - fixed route select filter rules;
*) routing - moved "/interface bgp vpls" to "/routing bgp vpls" menu;
*) routing-filter - added origin matcher to match for example routes of a specific OSPF instance;
*) routing-filter - fixed regexp community matcher;
*) routing-filter - made "do-jump" work in select rules;
*) rpki - fix potential memory leak;
*) ssh - disable ssh-rsa when strong-crypto=yes and use rsa-sha2-sha256;
*) ssh - fixed host key generation (introduced in v7.3);
*) ssh - implemented "server-sig-algs" extension in order to improve rsa-sha2-sha256 support;
*) switch - disabled second CPU core for CRS328-24P-4S+ device in order to improve SFP+ link stability;
*) switch - fixed multicast flooding when HW offloaded bridge port gets disabled;
*) system - added "shutdown" parameter for reset-configuration (CLI only);
*) system - fixed configuration reset with "run-after-reset" with file stored on ramdisk;
*) upgrade - ignore same version packages during upgrade procedure;
*) upgrade - improved RouterOS upgrade stability with attached USB modem on MIPSBE, SMIPS and MMIPS devices;
*) vpls - improved system stability with enabled connection tracking;
*) vxlan - allow to specify MAC address manually;
*) w60g - fixed interface "reset-configuration" on Cube 60 devices;
*) w60g - improved interface initialization after being inactive for a while;
*) w60g - improved system stability when using mismatched L2MTU between station and AP;
*) webfig - updated WebFig HTML files with the new MikroTik logo and removed Telnet option from index page;
*) webfig - updated link to the WinBox executable;
*) webfig - updated link to the documentation;
*) wifiwave2 - added initial support for roaming (802.11r) between local AP interfaces;
*) wifiwave2 - fixed "frequency-scan" functionality (introduced in v7.3);
*) wifiwave2 - improved WPA3 support stability;
*) winbox - add a log and log-prefix options to IPv6 firewall NAT and mangle rules;
*) winbox - added "name" parameter under "Routing/BGP/Session" menu;
*) winbox - added "to-address" and "to-ports" parameters under "IPv6/Firewall/NAT" menu;
*) winbox - added support for "veth" interface types;
*) winbox - fixed "inactive" flag naming under "MPLS/Local Mapping" menu;
*) winbox - fixed IP/Route and IPv6/Route OSPF type value;
*) winbox - fixed filename dropdown value filtering;
*) winbox - fixed minor typo under "Interface" stats;
*) winbox - fixed units for "reachable-time" parameter under "IPv6/ND" menu;
*) winbox - removed "TLS Host" parameter from "IP/Firewall/NAT" menu;
*) winbox - removed duplicate signal strength column under "Wireless/Registration Table" menu;
*) winbox - removed unused "Apply Changes" button from BGP sessions menu;
*) wireguard - fixed system stability when adding/removing WireGuard interface;
*) wireless - fixed possible traffic flooding to WDS clients when using Nv2 and multicast helper;
*) x86 - fixed Broadcom NIC support;
*) x86 - fixed keep old configuration functionality during x86 setup installation;
*) x86 - improved log warning message on failed downgrade attempt;
*) x86 - removed "hdd-model" information from installation screen;
Release 7.3.12022-06-10
What's new in 7.3.1 (2022-Jun-09 11:58):
*) rb3011 - fixed RB3011 going into a reboot loop when the SFP module is present (introduced in v7.3);
*) wifiwave2 - fixed WPA3-PSK authentication incompatibility with certain vendor and model devices;
Release 7.32022-06-07
What's new in 7.3 (2022-Jun-06 11:38):
*) bgp - added "name" parameter for connections;
*) bgp - added initial support for prefix limit;
*) bgp - fixed "keepalive-timeout" value when upgrading from RouterOS v6;
*) bgp - fixed "l2vpn" distribution;
*) bgp - improved stability when editing BGP template;
*) bgp - moved "interface bgp-vpls" menu to "routing bgp vpls";
*) bgp - remove unused commands and parameters;
*) bluetooth - improved long-term service stability;
*) bonding - added "lacp-user-key" setting;
*) bonding - fixed LACP flapping for RB5009 and CCR2004-16G-2S+ devices;
*) bridge - added more details for loop detection warning;
*) bridge - do not set VLAN on inactive port with a "set" command;
*) bridge - fixed TCP, UDP port parsing for loop detect warning;
*) bridge - fixed packet marking for IP/IPv6 firewall;
*) bridge - ignore VLAN tagged BPDU;
*) capsman - fixed bridge disabling when using L2 connection;
*) capsman - fixed loss of manager configuration when "package-path" is set to external disk;
*) capsman - improved traffic processing over CAP communication tunnels:
*) ccr - added "passthrough" flag for interfaces on CCR2004-1G-2XS-PCIe;
*) ccr - added visible "passthrough" flag for interfaces on CCR2004-1G-2XS-PCIe;
*) ccr - improved interface link stability on CCR2004-16G-2S+PC;
*) ccr - usability and stability improvements for passthrough interfaces on CCR2004-1G-2XS-PCIe;
*) cd-install - allow selecting on which drive to install RouterOS;
*) chr - fixed Cloud DDNS update after license renewal;
*) conntrack - limited full Connection Tracking warning to 1 message per minute;
*) console - fixed "terminal inkey" command;
*) crs1xx/2xx - improved system stability during switch reset;
*) defconf - do not add passthrough ports to local bridge on CCR2004-1G-2XS-PCIe;
*) dhcpv4-server - added "age" parameter for dynamic leases;
*) dhcpv4-server - fixed conflicting or declined lease detection when IP pool differs from server's configuration;
*) dhcpv4-server - fixed minor logging typo;
*) dot1x - fixed RADIUS State attribute when client is reauthenticated;
*) dot1x - fixed port based VLAN ID assignment on devices without a switch chip;
*) dot1x - improved server stability when using re-authentication;
*) export - fixed value ID exporting that does not refer to any name;
*) fetch - fixed SFTP upload;
*) fetch - improved full disk detection;
*) filesystem - fixed possible boot failure on RB850Gx2 and RB1100AHx2;
*) filesystem - improved UBIFS stability and data integrity after downgrade to RouterOS v6 and upgrade to RouterOS v7;
*) filesystem - improved long-term filesystem stability and data integrity;
*) gps - added GPS package support for Chateau devices;
*) gps - fixed minor value unit typo;
*) ipsec - fixed IPsec IRQ initialization on startup on TILE;
*) ipsec - fixed printing of active peer statistics;
*) ipv6 - added "ra-preference" parameter support for RA;
*) ipv6 - fixed dynamic non link-local addresses displaying;
*) ipv6 - removed bogus commands from IPv6 neighbors menu;
*) l2tp - added VRF support for L2TP client;
*) l3hw - greatly improved route offloading speed;
*) l3hw - improved offloading for directly connected hosts on CRS305, CRS326-24G-2S+, CRS328, CRS318, CRS310;
*) l3hw - improved offloading in cases of HW table overflow for CRS305, CRS326-24G-2S+, CRS328, CRS318, CRS310;
*) l3hw - improved route table offloading for CRS317, CRS309, CRS312, CRS326-24S+2Q+, CRS354, CRS5xx, CCR2x16 devices;
*) l3hw - log HW routes count and the shortest offloaded subnet prefix if the HW memory gets full;
*) l3hw - offload only main routing table;
*) l3hw - optimized offloading when dealing with large volume of directly connected hosts;
*) l3hw - partial routing table offload for Marvell Prestera DX4000/DX8000 switch chip series;
*) leds - fixed ethernet LED behavior on wAP R ac;
*) leds - fixed wireless related LED behavior with WW2 package;
*) lhgg - improved system stability (introduced in v7.2);
*) lora - do not allow setting non-existing forwarding server;
*) lora - fixed bogus TOO_EARLY errors;
*) lora - removed TX lookup table;
*) lte - added SMS sending support for MBIM protocol;
*) lte - added support for generic PXA1802 based modems;
*) lte - allow only MCC/NMC format in "operator" parameter;
*) lte - clear SIM values when modem in "stopped" state;
*) lte - disabled extended signal info query for Telit LN940 module;
*) lte - disabled wait for LTE auto attach;
*) lte - expose diagnostics channel for all modems;
*) lte - fixed LTE firwmare upgrade on RBLtAP-2HnD with R11e-LTE6;
*) lte - fixed Sierra MC7455 modem initialization;
*) lte - hide slave interfaces from export;
*) lte - improved LTE interface initialization process on LtAP-2HnD;
*) lte - improved stability when configuring multiple APN's at the same time in MBIM mode;
*) lte - improved stability when upgrading LTE firmware on Chateau 5G;
*) mlag - fixed MAC address moving between bridge ports;
*) mpls - do MPLS forwarding for nexthops without mappings;
*) mpls - fixed MPLS MTU and path MTU selection;
*) mpls - fixed MPLS forwarding after any interface configuration parameter is changed;
*) mpls - improved LDP AF selection process and behavior;
*) mpls - made LDP bindings work on PPP interfaces;
*) ntp - do not allow setting port number in "server" parameter;
*) ntp - fixed "use-local-clock" behavior when enabling server;
*) ospf - fixed GRE interface compatibility with OSPF;
*) ospf - ignore instance route when originate-default=if-installed is enabled;
*) ospf - improved stability when enabling or removing interface-template entries;
*) ovpn - adjusted SHA2 authentication algorithm naming to allow legacy OpenVPN implementations to connect;
*) ovpn - fixed hardware offloading support on CHR;
*) ovpn - fixed memory leak on TILE architecture;
*) ovpn - fixed packet processing on MT7621A;
*) ovpn - fixed server instance not responding to incoming connections after reboot on CHR;
*) ovpn - improved Windows client disconnect procedure in UDP mode;
*) ovpn - improved server stability under continous overload;
*) ovpn - improved service stability when outbound packets are blocked by firewall in UDP mode;
*) ovpn - improved service stability when processing frequent disconnects in UDP mode;
*) ovpn - improved stability when forwarding traffic on TILE;
*) ovpn - moved authentication failure messages to "info" logging level;
*) ovpn - reply with the same IP address that the connection was established to;
*) ping - fixed socket allocation after VRF change;
*) port - do not loose "parity" setting;
*) ppp - added support for VRF;
*) ppp - added warning when using prefix length other than /64 for router advertisement;
*) ppp - fixed "remote-ipv6-prefix" parameter unsetting;
*) ppp - fixed active sessions sometimes getting stuck;
*) ppp - fixed issue with multiple active sessions when "only-one" is enabled;
*) profile - added "wireguard" process classificator;
*) profile - added "zerotier" process classificator;
*) qsfp - reset module only when all ports are disabled;
*) queue - allow to set higher limits than 4G;
*) queue - display warning for CAKE type in simple and tree setups when "bandwidth" parameter is configured;
*) queue - improved stability in large list of queue scenarios;
*) rb5009 - fixed 10G linking issues with Intel X520, XXV710 NICs;
*) resource - fixed CPU type display under system resources for ARM and ARM64;
*) romon - fixed VLAN tagged packet processing;
*) route - fixed "nexthop" table printing;
*) route - fixed "table" menu emptying after RouterOS upgrade;
*) route - fixed IPv6 /127 route nexthop resolution;
*) route - fixed static routes in VRF becoming invalid after reboot;
*) route-filter - fixed community matchers;
*) routerboard - fixed USB bus numbering on LtAP and M33G;
*) routerboot - added extra shortcut information on how to boot into etherboot;
*) rsvp-te - improved stability when "Resv" received for non-existing session;
*) sfp - added 2.5Gbps rate for SFP+ and QSFP+ interfaces on 98DXxxxx and 98PX1012 switches (requires disabled auto-negotiation);
*) sfp - hide empty monitor values in console;
*) sfp - improved Q/SFP interface initialization and stability for 98DXxxxx and 98PX1012 switches;
*) sfp - improved QSFP/SFP interface initialization for 98DXxxxx switches;
*) smb - fixed SMB2 file list reporting;
*) snmp - added VRF support (CLI only);
*) snmp - added VRF support;
*) snmp - fixed reported disk size when multiple external disks are attached;
*) snmp - hide Vendor ID in DHCP MIB when branding is present;
*) snmp - report "ifSpeed" as 0 if value out of bounds (use "ifHighSpeed" for high speed interfaces instead);
*) ssh - added AES-GCM cipher support;
*) ssh - fail non-interactive client after first invalid password;
*) ssh - fixed corrupt host key automatic regeneration;
*) ssh - fixed private key usage after downgrade;
*) ssh - removed DSA public key authentication support;
*) supout - added IGMP-Proxy section;
*) supout - added NTP servers section;
*) supout - added PIMSM section;
*) supout - added RIP section;
*) supout - added WireGuard section;
*) supout - added simplified IPv4 and IPv6 routing table prints;
*) switch - added option to match source and destination IP addresses in ARP packets for RB5009 (requires mac-protocol=arp setting);
*) switch - fixed missing stats from traffic-monitor for 98DXxxxx and 98PX1012 switches;
*) system - fixed IP service initialization in VRF after system startup;
*) system - fixed Kernel timer consistency;
*) system - fixed rare partial loss of RouterOS configuration after package upgrade/downgrade/install/uninstall;
*) torch - properly capture all related IPv6 traffic;
*) tr069-client - fixed RPC download of "1 Vendor Configuration File" with branding package;
*) tunnels - improved packet handling over EoIP, IPIP and GRE tunnels;
*) upnp - improved stability when processing incomplete HTTP header;
*) user-manager - added "Acct-Interim-Interval" to predefined attribute list;
*) user-manager - improved stability when received EAP attribute with non-existing state attribute;
*) vpls - fixed "pw-l2mtu" parameter usage;
*) vpls - fixed TE transport path usage after startup;
*) vrrp - fixed learning of bridged local MAC addreses;
*) w60g - improved stability on Cube 60Pro ac and CubeSA 60Pro ac;
*) webfig - properly show all routing table content;
*) wifiwave2 - fixed VLAN tag handling;
*) wifiwave2 - general stability and throughput improvements;
*) winbox - added "Comment" parameter for BGP templates and connections;
*) winbox - added "Default Cost" parameter under "Routing/OSPF/Area" menu;
*) winbox - added "ra-preference" parameter under "IPv6/ND" menu;
*) winbox - added SKID and AKID parameters under "Certificate" menu;
*) winbox - added missing "IBGP", "EBGP", "Limit Exceeded" and "Stopped" parameters under "Routing/BGP/Sessions" menu;
*) winbox - added missing "Keep Sent Attributes" parameter under "Routing/BGP/Connection" menu;
*) winbox - added missing "Scan List" parameter for W60G interfaces;
*) winbox - added missing BGP session commands;
*) winbox - added support for 2.5Gbps and 100Gbps Ethernet speed options;
*) winbox - added warning message for LTE upgrade process;
*) winbox - do not auto start Wireless Sniffer when opened;
*) winbox - do not show "Session Uptime" parameter under "LTE" menu if not supported by modem;
*) winbox - do not show "unknown" area under "Routing/OSPF/LSA" menu;
*) winbox - do not show type value for NXDOMAIN entries under "IP/DNS/Cache" menu;
*) winbox - fixed "Disconnect Timeout" parameter type under "CAPsMAN" menu;
*) winbox - fixed "IP/Cloud" window refreshing after changes are detected;
*) winbox - fixed "Type" values under "IP/Route" menu;
*) winbox - fixed graph drawing in QuickSet;
*) winbox - fixed hex type values under "User Manager" menu;
*) winbox - fixed minor typo in reboot confirmation prompt;
*) winbox - fixed typo in ZeroTier instance title;
*) winbox - made "Interface Templates" table sortable under "Routing/OSPF" menu;
*) winbox - made "MPLS Interface" table sortable under "MPLS" menu;
*) winbox - made 56 the default ping size;
*) winbox - made wireless access list entries sortable when using the wifiwave2 package;
*) winbox - minimal required version is v3.33;
*) winbox - moved "src-address-list" and "dst-address-list" parameters to "General" tab under "IP/Firewall" menu;
*) winbox - moved "src-address-list" and "dst-address-list" parameters to "General" tab under "IPv6/Firewall" menu;
*) winbox - properly clean up SFP module information after it is unplugged;
*) winbox - properly clean up disk after a failed file upload;
*) winbox - properly load band values under "LTE" menu;
*) winbox - removed obsolete "Routing Table" parameter under "IP/Firewall" menu;
*) winbox - show PVID column by default under "Bridge" menu;
*) winbox - show correct file system type under "System/Disks" menu;
*) winbox - take into account timezone for timed values under "User Manager" menu;
*) wireless - fixed "wmm-support=required" checking;
*) wireless - fixed EAP-TLS authentication;
*) wireless - fixed GUD version in 3gpp information;
*) x86 - added support for Solarflare SFC1920 NIC;
*) x86 - fixed soft-id reading on virtualized x86 installations (introduced in v7.2);
*) x86 - improved support for Intel E810 NIC;
*) zerotier - added support for Controller configuration;
Release 7.2.32022-05-03
What's new in 7.2.3 (2022-May-02 18:18):
*) system - fixed RouterOS bootup when wifiwave2 package is installed (introduced in v7.2.2);
Release 7.2.22022-05-02
What's new in 7.2.2 (2022-Apr-28 21:01):
*) crs3xx - fixed storm rate on 1Gbps interfaces for CRS354 devices;
*) defconf - suggest user to set up new password;
*) queues - improved stability in large list of queue scenarios;
*) vrf - fixed VRF leaking;
*) ww2 - fixed VLAN tag handling;
*) x86 - improved support for i40e driver;
Release 6.49.62022-04-19
What's new in 6.49.6 (2022-Apr-07 17:53):
*) led - fixed wireless signal strength led on Cube Lite60;
*) routerboot - fixed packet receiving in etherboot on Wireless Wire nRAY;
*) winbox - added missing "3GGP RAW" parameter under "Interface/Wireless/Interworking Profile" menu;
Release 7.2.12022-04-13
What's new in 7.2.1 (2022-Apr-13 09:01):
Release 7.22022-04-05
What's new in 7.2 (2022-Mar-31 12:11):
*) api - accept "Content-Type" with specified charset;
*) arm - fixed "auto" CPU frequency setting;
*) arm - fixed "shutdown" command on hAP ac^2;
*) arm64 - improved Watchdog initiated reboot reason reporting;
*) arm64 - improved low disk space handling condition on upgrade;
*) backup - added "force-v6-to-v7-configuration-upgrade" option on backup load to clear RouterOS v7 configuration and trigger reimport of RouterOS v6 route configuration (CLI only);
*) backup - fixed automatic backup generation when resetting configuration;
*) backup - fixed cloud backup's creation timezone;
*) bgp - added BGP advertisements display (requires output.keep-sent-attributes to be set);
*) bgp - do not export default BGP values;
*) bgp - fixed VPNv4 route sending to remote peer;
*) bgp - fixed link-local iBGP address selection;
*) bgp - fixed network advertisement from address-lists after reboot;
*) bgp - fixed routing table and BGP configuration order in export;
*) bgp - improvements on detecting peers local address when IPv6 link-local addresses are used;
*) bluetooth - allow to export device, advertiser and scanner configuration;
*) bluetooth - disable scanning by default;
*) bridge - added fast-path and inter-VLAN routing FastTrack support when vlan-filtering is enabled;
*) bridge - fixed FastPath when using "frame-types=admit-only-untagged-and-priority-tagged" setting;
*) bridge - fixed PPPoE packet forwarding when using "use-ip-firewall-for-pppoe" setting;
*) bridge - fixed bridge filter and NAT rules on ARM64 and TILE devices;
*) bridge - fixed destination NAT when using "use-ip-firewall" setting;
*) bridge - fixed filter and NAT "set-priority" action;
*) bridge - fixed filter and NAT "set-priority" on ARM64 devices;
*) bridge - fixed filter rules when using interface lists;
*) bridge - fixed firewall "ingress-priority" matcher and "new-priority=from-ingress" action settings from VLAN tagged frames;
*) bridge - fixed priority tagged frame forwarding when using "frame-types=admit-only-untagged-and-priority-tagged" setting;
*) capsman - improved stability when running background scan on CAP;
*) capsman - improved system stability when processing CAP packet by Mangle;
*) ccr2004 - improved PCI timeout handling on CCR2004-1G-2XS-PCIe;
*) ccr2004 - improved system stability on CCR2004-12S+2XS;
*) certificate - allow to choose digest algorithm for CSR signing;
*) certificate - made "fingerprint" parameter read-only;
*) chr - improved system stability when writing into memory;
*) chr - temporarily suspended downgrade to RouterOS v6;
*) clock - properly notify all instances about time changes;
*) conntrack - properly detect helper status;
*) console - fixed "print" command with additional "where" condition;
*) console - improved console responsiveness when processing received characters;
*) console - made "password" parameter mandatory when creating a new user;
*) console - properly erase CLI history after configuration reset;
*) crs1xx/2xx - fixed static switch host addresses after link down;
*) crs1xx/2xx - ignore static bridge host addresses (switch unicast-fdb should be used instead);
*) crs3xx - fixed CPU load balancing for ARM dual core devices;
*) crs3xx - fixed QSFP+ interface LEDs;
*) crs3xx - fixed watchdog timer functionality;
*) crs3xx - improved SFP+ interface linking after reboot for CRS312 device;
*) crs3xx - improved maximum allowed ACL rule calculation;
*) crs3xx - improved system stability when creating many ACL rules on CRS317, CRS309, CRS312, CRS326-24S+2Q+ and CRS354 devices;
*) defconf - made "192.168.188.1/24" the default LAN IP address for LTE CPE devices;
*) dhcp-server - fixed DHCP Option decimal value parsing;
*) dhcp-server - fixed statistics sending in "Accounting Stop" packets;
*) dhcp-server - send "Class" attribute in "Accounting Request" when provided by RADIUS;
*) dhcpv4-server - allow adding comments;
*) dhcpv4-server - remove dynamic leases when server configuration is removed;
*) dhcpv4-server - reset dynamic "bcast" flag when receiving offer from DHCP relay;
*) dhcpv4-server - reset offer counter when receiving offer from DHCP relay;
*) dhcpv6 - added VRF support;
*) dot1x - added "server-fail-vlan-id", "guest-vlan-id" and "reauth-timeout" settings for dot1x server;
*) dot1x - added "src-address", "src-mac-address" and "src-port" settings for dynamic switch rules;
*) dot1x - added NAS-Port-ID attribute for RADIUS Access-Request;
*) dude - fixed The Dude client compatibility with RouterOS v7;
*) dude - fixed The Dude compatibility with ARM64;
*) ethernet - improved system stability when receiving large packets on devices with 88F3720 CPU (nRAY, LHGG);
*) firewall - improved available port lookup for source NAT when free port range is exhausted;
*) graphing - properly generate interface graph for traffic higher than 2.1Gbps;
*) hotspot - fixed login page over HTTPS;
*) hotspot - fixed memory leak on every web page loading;
*) hotspot - fixed web page loading using HTTPS;
*) ike2 - ignore "INITIAL-CONTACT" payload on responder when "send-initial-contact" is disabled;
*) interface - fixed minor memory leak when interface or connected route is changed;
*) ipsec - added hardware acceleration support for CCR2116;
*) ipsec - fixed "identities" menu emptying after RouterOS upgrade/reboot;
*) ipv6 - do not add duplicate dynamic prefix when static already exists;
*) ipv6 - fixed "retransmissit-interval" unit value;
*) ipv6 - fixed VLAN tagged PPPoE packet receiving on RB5009;
*) l2tp - fixed CHAP challenge packet processing over IPsec;
*) l2tp - improved service stability when disabling L2TP server with connected clients;
*) l2tp - improved system stability when processing L2TP control messages;
*) l3hw - added HW offloaded FastTrack support for inter-VLAN routing;
*) l3hw - fixed HW offloaded routing when using 7 or more VLAN interfaces;
*) l3hw - fixed ICMP message when routed packet exceeds MTU and DF flag is set;
*) l3hw - fixed bonding source MAC address;
*) l3hw - fixed default route offloading for CRS305, CRS326-24G-2S+, CRS328, netPower, netFiber devices;
*) l3hw - improved routing table offloading for CRS305, CRS326-24G-2S+, CRS328, netPower, netFiber devices;
*) l3hw - improved system stability when using 7 or more VLAN interfaces;
*) led - fixed LED behavior on Audience;
*) led - reduced LTE signal LED range to -70;
*) leds - fixed user LED on RB750Gr3;
*) log - added warning message when connection tracking table is full;
*) log - include message also in e-mail body;
*) lora - fixed "antenna-gain" parameter unit;
*) lte - add IPv6 address on interface as well;
*) lte - added 3 APN profile support and APN name re-using on R11e-LTE6;
*) lte - added MAC address and IPv6 LL address persistence after reboot on EG12 and EG18 modems;
*) lte - added basic information support for Telit LM960 and LM940 in MBIM mode;
*) lte - added class based support for configless RNDIS LTE modems;
*) lte - added support for Uplink CA reporting;
*) lte - changed "CS/PS" registration type from "both" to "any" on R11e-LTE un R11e-LTE6;
*) lte - do not loose "band" configuration after reboot on Chateau 5G;
*) lte - do not show external antenna selector on devices that does not support it;
*) lte - enabled multi-APN and name re-use support for Chateau;
*) lte - fixed "monitor" command to not report old info;
*) lte - fixed AT command response handling on R11e-LTE;
*) lte - fixed IPv6 address addition after startup on R11e-LTE6;
*) lte - fixed MBIM modem reset on AT timeout;
*) lte - fixed link flapping when loosing cellular signal on R11e-LTE un R11e-LTE6;
*) lte - fixed packet forwarding on R11e-4G and R11e-LTE-US;
*) lte - fixed possible timeouts when sending SMS in LTE only mode on R11e-LTE;
*) lte - fixed support for Sierra MC7710;
*) lte - fixed support for Telit 960;
*) lte - improved stability on "+EGMR" response in MBIM mode;
*) lte - improved stability when modem disappears during firmware upgrade;
*) lte - improved support for sending/receiving SMS in LTE only mode on R11e-LTE6;
*) lte - made "no" the default value for "use-network-apn" parameter;
*) lte - properly recognize MBIM modem in USB port as LTE on Chateau 5G;
*) ntp - allow adding duplicate server address if dynamic entry exists;
*) ntp - fixed multicast mode support;
*) ntp - improved IPv6 address support;
*) ntp - improved service stability when none of the NTP servers are reachable for a while;
*) ntp - improved source address usage for reply packets;
*) ntp - print log change time with time-zone applied;
*) ospf - added "ptmp-broadcast" interface type (compatible with RouterOSv6 PTMP type);
*) ospf - convert ospf "static" redistribute to "static,dhcp,modem,vpn" after update from RouterOS v6;
*) ospf - fixed MD5 authentication;
*) ospf - fixed NBMA hello's not being sent if priority is set to 0;
*) ospf - fixed default route origination when "default-originate=if-installed" "redistribute" is enabled;
*) ospf - fixed default type-3 LSA's not being injected to stub area;
*) ospf - fixed distance if "originate-default" is set to "always";
*) ospf - fixed external LSA not updating after prefix netmask change;
*) ospf - fixed incorrect LSA types when changing area types;
*) ospf - fixed neighbor election failure;
*) ospf - fixed neighbor stuck in ExStart;
*) ospf - fixed simple authentication;
*) ospf - general stability improvements;
*) ospf - improved DB retransmit logging;
*) ospf - improved logging;
*) ospf - improved overall stability;
*) ospf - improved stability for very large LSDB;
*) ospf - improved stability on OSPFv3 instance disabling;
*) ospf - improved stability when DR goes down;
*) ospf - improves stability when handling looped back OSPF packets;
*) ospf - properly set VRF for gateway;
*) ospf - send notifies for neighbors;
*) ovpn - added SHA2 authentication algorithm support;
*) ovpn - added hardware acceleration support for IPQ4018/IPQ4019 and AL* series chipsets;
*) ovpn - added option to send disconnect message in UDP mode;
*) ovpn - fixed large option message parsing;
*) ovpn - improved UDP session handling;
*) ovpn - improved memory allocation on Tile in "ethernet" mode;
*) ovpn - improved system stability in high load scenarios;
*) pimsm - fixed menu prints;
*) pimsm - general stability improvements;
*) poe - fixed PoE driver loading on CRS354-48P-4S+2Q+;
*) poe - update PoE firmware only on devices that support it;
*) ppp - added "comment" option for PPPoE servers;
*) ppp - fixed AT+CPIN chat when SIM PIN is specified;
*) ppp - improved stability when handling large amount of connections simultaneously;
*) ppp - show local and remote IPv6 addresses (CLI only);
*) pppoe - added option to configure "host-uniq" parameter;
*) pppoe - added option to ignore PADI messages with empty service name;
*) pppoe - use default MTU of 1492;
*) pptp - added insecure connection warning;
*) pptp - show insecure connection warning on dynamic interfaces;
*) qsfp - correctly display auto-negotiation status;
*) queue - fixed queued IPv6 traffic considered as "invalid" by Firewall;
*) queue - improved system stability when processing traffic;
*) queue - improved system stability when using more than 255 unique packet marks;
*) rb4011 - fixed jumbo frame processing on SFP+ port when using 1G module;
*) rip - added logging;
*) rip - fixed route metrics;
*) rip - fixed route redistribution;
*) rip - use nexthop with interface;
*) route - allow OSPF and RIP redistributed routes to be matched by routing filters;
*) route - fixed "min-prefix" configuration when set to 0;
*) route - fixed "suppress-hw-offload" update;
*) route - fixed BGP atomic aggregate value;
*) route - fixed ECMP load balancing in FastPath;
*) route - fixed ECMP route removal;
*) route - fixed route addition to VRF from BGP;
*) route - fixed router's LSA for PTP networks;
*) route - fixed routing configuration export on SMIPS devices;
*) route - general stability improvements;
*) route - improved routing table print speed;
*) route - show OSPF and RIP specific attributes in "/routing route" table;
*) route-filter - fixed "return" action;
*) route-filter - fixed complex matchers with "|| or and &&";
*) route-filter - fixed incorrect invert-match configuration upgrade from RouterOS v6;
*) route-filter - fixed range conversion after update from RouterOS v6;
*) route-filters - allow to filter and modify default route if "originate-default" is set to "always";
*) route-filters - fixed possible address list race condition and memory leak;
*) route-filters - renamed "*-set" to "*-list";
*) routerboard - fixed "ether2" interface presence on some RBwAPGR devices;
*) routerboard - fixed WPS button functionality on Audience;
*) routing - added PCAP viewer tool for BGP advertisements debugging purposes;
*) routing-filter - fixed "bgp-*-communities-empty" matcher;
*) rpki - made RPKI verify non-strict, introduces new state "unverified";
*) rpki - show expire timer;
*) sfp - improved SFP module detection on CRS106 and CRS112;
*) smb - fixed SMB2.0 disk size reporting;
*) smips - improved RAM allocation;
*) sms - increased "at-chat" timeout when sending SMS;
*) snmp - added SFP vendor name to optical table;
*) snmp - added support for "ipv6AddrPrefixTable" and "ipv6RouteNumber" OID's;
*) snmp - allow two level nesting for vlan, bonding speed query;
*) socks - fixed SOCKS5 support;
*) ssh - fixed forwarding with IPv6 link-local addresses;
*) ssl - fixed CA certificate processing when "subjAltName" is marked as critical;
*) supout - added "port-controller" bridge section;
*) switch - added "rx-overflow" counter for 88E6393X (RB5009) and 88E6191X (CCR2004-16G-2S+) switch chips;
*) switch - fixed port-isolation misconfiguration detection when using multiple switches;
*) switch - improved packet forwarding with enabled "cpu-flow-control" setting between different rate interfaces for 88E6393X (RB5009) and 88E6191X (CCR2004-16G-2S+) switch chips;
*) switch - improved switch chip initialization process on bootup for CCR2004-16g-2s+ devices;
*) switch - properly limit maximum number of switch rules to 256 on RB5009;
*) system - fixed license loss on some RB1100Dx4 and RB4011 devices;
*) tr069-client - accept 200-299 codes for HTTP diagnostics;
*) tr069-client - added support for 5G band configuration;
*) tr069-client - added support for wireless "skip-DFS" configuration;
*) tr069-client - added support for wireless client uptime reporting;
*) tr069-client - fixed RPC download of "3 Vendor Configuration File" with branding package;
*) traffic-flow - do not handle NAT events when "nat-events" is disabled;
*) traffic-generator - fixed transmit speed for multiple asymmetric streams;
*) upgrade - improved 404 error handling when checking for new versions;
*) upgrade - improved downgrade prompt message;
*) ups - fixed UPS support;
*) usb - fixed display of incorrect port count for USB serial ports;
*) user - removed obsolete "tikapp" policy;
*) user - send "Class" attribute in "Accounting Request" when provided by RADIUS;
*) vlan - fixed improper VLAN priority addition for routed packets;
*) vxlan - allow unsetting "group" and "interface" properties;
*) vxlan - fixed running state after reboot when using "interface" and "group" settings;
*) webfig - do not show side menu if WebFig is disabled by skin;
*) webfig - fixed default configuration popup presence;
*) webfig - fixed user policy lookup for skin designer;
*) wifiwave2 - added "client-isolation" feature;
*) wifiwave2 - added support for handling disconnect request messages from RADIUS servers;
*) wifiwave2 - fixed calling "scan" and "frequency-scan" commands through the API;
*) winbox - added "Disconnect Notify" checkbox to "Interface/OVPN Client" menu;
*) winbox - added "Freq. Usage" and "Scan" buttons for WifiWave2 interfaces;
*) winbox - added "Ignore Missing" selector to "System/Packages" menu;
*) winbox - added "Mode" parameter under "Wireless" menu with WifiWave2 package;
*) winbox - added "Routing Table" parameter for IPv6 routes;
*) winbox - added "TLS Version" parameter for "Interface/OVPN";
*) winbox - added "VPN" tab to "Routing/BGP" menu;
*) winbox - added "VRF" parameter for "SSH" and "Telnet" menus;
*) winbox - added "VRF" parameter to "IP/Services" menu;
*) winbox - added "comment" parameter to "User Manager/Users" menu;
*) winbox - added "host-uniq" parameter to PPPoE client interface;
*) winbox - added MLAG support;
*) winbox - added SHA256 and SHA512 "Auth" values for OVPN menu's;
*) winbox - added ZeroTier support;
*) winbox - added explicit "Upload" and "Download" names for "Bucket Size" parameters under "Queues" menu;
*) winbox - added interface list support for "IP/Traffic Flow" menu;
*) winbox - added local/remote CPU load parameters for "Bandwidth Test";
*) winbox - added missing "accounting", "interim-update" and "radius-password" parameters under "IP/DHCP Server" menu;
*) winbox - added support for "Tool/Speedtest" menu;
*) winbox - added support for W60G align tool;
*) winbox - allow adding more than 100 tagged/untagged interfaces under "Bridge/VLAN" menu;
*) winbox - allow configuring "VTEP" under "Interface/VXLAN" menu;
*) winbox - allow setting "Interface" parameter for 100G LED types;
*) winbox - changed "Accept Redirects" parameter type under "IPv6/Settings" menu;
*) winbox - do not require "name" and "file name" parameters for certificate import/export;
*) winbox - do not show "Antenna Scan" button on devices that do not support it;
*) winbox - do not show connection tracking table if it has more than 10000 entries;
*) winbox - fixed "00:00:00" time printing;
*) winbox - fixed "Switch" menu on Chateau devices;
*) winbox - fixed "action" field in "IP/Web Proxy/Access" menu;
*) winbox - fixed "expires-after" certificate parameter value;
*) winbox - fixed CHR License renewing process;
*) winbox - fixed address list type parameters in "Routing" menu;
*) winbox - fixed content filtering in "Tools/Packet Sniffer/Packets" menu;
*) winbox - fixed entry order in "Tools/Packet Sniffer/Packets" menu;
*) winbox - fixed error message when adding NTH rule with "0" value;
*) winbox - fixed minor typo under "LTE" interface menu;
*) winbox - fixed switch related settings for MT7621 switch chip (hEX, hEX S, RBM33G, RBM11G, LtAP);
*) winbox - made "9" the default value for "Target" parameter under "IP/Traffic Flow" menu;
*) winbox - made "Routing Filters/Rules" table sortable;
*) winbox - made OSPF interface type names consistent between CLI and GUI;
*) winbox - moved "IP/Route/Nexthops" and "IPv6/Route/Nexthops" menus to "Routing/Nexthops";
*) winbox - moved IPv4 and IPv6 "Rules" menus under "Routing" menu;
*) winbox - properly limit "Disconnect Timeout" value under "CAPsMAN/Configuration" menu;
*) winbox - properly save "IPv6/Settings" menu in session file;
*) winbox - properly show "v" flag instead of "y" under "IP/Route" menu;
*) winbox - properly update ethernet auto negotiation status on CHR;
*) winbox - properly update server list under "System/NTP Client/Servers" menu;
*) winbox - renamed "Keep user configuration" to "Keep users" under "System/Reset Configuration" menu;
*) winbox - renamed "MBPS" to "Mbps" value unit name in "Tools/Traffic Generator" menu;
*) winbox - renamed "Revoked" parameter to "Revoked Time" under "System/Certificates" menu;
*) winbox - report local terminal session as "local" instead of "telnet";
*) winbox - require existing pool for "Address Pool" parameter under "IPv6/DHCP Server" menu;
*) winbox - require non empty "Packet Mark" value under "Queues" menu;
*) winbox - show "H" flag for offloaded connections in "IP/Firewall/Connections" menu;
*) winbox - show "Lost Ratio" column by default under "Tools/Traffic Generator" menu;
*) winbox - show "Routes" column by default under "PPP/Secrets" menu;
*) winbox - show "System/Health/Settings" only on boards that have configurable values;
*) winbox - show "System/SwOS" menu only on boards that have dual boot;
*) winbox - show additional columns by default for "Wireless" menu with WifiWave2 package;
*) winbox - sort "Address List" parameter values alphabetically in "IP/DHCP Server/Leases" menu;
*) winbox - updated default "Routing/BGP/Peer Cache" table appearance;
*) winbox - use "total" as default value for "Tools/Profile";
*) wireguard - allow same peer's public key for different interfaces;
*) wireguard - fixed IPv6 LL address generation;
*) wireguard - fixed IPv6 traffic processing with multiple peers;
*) wireguard - made "preshared-key" and "private-key" values sensitive;
*) wireless - added "3gpp-info" parameter to interworking configuration;
*) wireless - added EAP-AKA to interworking's realm configuration;
*) wireless - added information about client signal strength to log messages about disconnections;
*) wireless - correctly preserve WMM priority when receiving packets;
*) wireless - fixed frequency range information for IPQ4019 interfaces;
*) wireless - fixed interface initialization on Metal 2SHPn;
*) wireless - improved nv2 link stability;
*) wireless - improved wireless connection stability during background scans;
*) www - fixed "tls-version" for SSL;
*) x86 - added support for Intel E810 NIC;
*) x86 - allow to select disk for install image;
*) x86 - fixed NVME partition path;
*) x86 - fixed VLAN tagged packet transmit;
*) x86 - made "no" the default value for "disable-running-check" ethernet parameter;
*) x86 - properly distinguish multiple NICs that share the same PCI bus number;
*) zerotier - fixed IPv6 support;
*) zerotier - made MAC and MTU values read-only;
*) zerotier - properly handle IP address change;
Release 7.1.52022-03-22
What's new in 7.1.5 (2022-Mar-22 13:03):
Release 7.1.42022-03-22
What's new in 7.1.4 (2022-Mar-21 13:23):
*) lte - made "RG502QEAAAR11A06M4G" the last OTA firmware version update for Chateau 5G in RouterOS 7.1.x release tree;
Release 7.1.32022-02-21
What's new in 7.1.3 (2022-Feb-11 21:20):
Release 7.1.22022-02-10
What's new in 7.1.2 (2022-Feb-03 16:15):
*) console - updated copyright notice;
*) ntp - fixed "use-local-clock" when enabling server;
Already read changelog. As I wrote, RB is 7.1.1
/system/package/print
Columns: NAME, VERSION
NAME VERSION
0 container 7.11
1 routeros 7.11
which is it, 7.1.1 is NOT 7.11 there’s almost 2 years worth of difference between the two…
Yes sorry, my bad. Have 7.11. Changed topic title too.
today I found, all kid control items are deleted. Checked logs and I see, kid control started ad 22.00 by schedule and after some seconds rb deleted all items automatically..
I still do not understand what your is main MT. RB4011 you used to check?
Yes I’m using RB4011
