The issue is (for me) that when I upgraded a RB4011iGS+5HacQ2HnD to 7.11rc1 the MTU’s were no longer being applied to vlans on a bridge, they were all at 1500.
Rolling back to 7.10, the MTUs were correctly set.
The usual > clickbait headline > with the usual > footwritten explanation> :
Zero credibility> , > just bullshit> .
Is there anything true?
Easy to take screenshots when it works…
What’s the use of taking a screenshot of when “it works”???
(And then “it works”… given all those bridges and VLANs, let alone the configuration…)
Do an /export of when it does NOT work and let other users check.
Maybe it’s a mistake you made (and given how many bridges and vlans you’ve made… and screenshot do not display all…)
that is accentuated by some feature in v7.11.
