Hi
After the upgrade to ROS 7.13 i always get the “no space to extract layer” during the container extraction.
This has worked before.
I have noticed this because after the upgrade to RouterOS 7.13 i also wanted to upgrade my PiHole container.
Everything works as expected up until the extraction. Then i get the “no space to extract layer” error.
As far as I can see (if I leave the files window open in Winbox) is that RouterOS attempts to unzip it to the local storage and not to the USB drive.
Any ideas please?
Is this a known issue in 7.13? I do not really want to downgrade.
Disk config:
disk print
Flags: B - BLOCK-DEVICE; M - MOUNTED; p - PARTITION
Columns: SLOT, MODEL, SERIAL, INTERFACE, SIZE, FREE, FS
# SLOT MODEL SERIAL INTERFACE SIZE FREE FS
0 B usb1 SanDisk SanDisk 3.2 Gen1 A2003852CB065A46 USB 3.20 5000Mbps 125 162 225 664
1 BMp usb1-part1 @512-125'162'225'664 125 162 225 152 124 108 500 992 ext4
Container config:
/container mounts
add dst=/etc/pihole name=etc_pihole src=/usb1-part1/etc
add dst=/etc/dnsmasq.d name=dnsmasq_pihole src=/usb1-part1/etc-dnsmasq.d
/container config
set ram-high=200.0MiB registry-url=https://registry.hub.docker.com/v2/ tmpdir=usb1-part1/pull
/container envs
add key=TZ name=pihole value=Europe/Bucharest
add key=WEBPASSWORD name=pihole value=password
add key=DNSMASQ_USER name=pihole value=root
