RouterOS (7.16) - Simple WireGuard Client Setup
Hi All,
I’m a newbie who would like to enter the Mikrotik community and would appreciate some help getting there (yes, I have been through this forum and google, but still learning how to do it).
I would like to setup a simple WireGuard client on my router (hAP ax2- RouterOS 7.16).
How should I connect a hAP with a WireGuard to a VPN provider for all the connected devices to access the internet only through a VPN tunnel?
I’m starting with a standard MT config:
DHCP 192.168.88.1/24
DNS 192.168.88.1
WAN is on address 192.168.10.100
Setup info from AirVPN
[Interface]
Address = 10.150.xx.12/32,fd7d:xxxx:xxxx:xxxx::xxxx:822/128
PrivateKey = MyPrivateKeyFromAirVPN
MTU = 1320
DNS = 10.128.10.1, fd7d:xxxx:xxxx:xxxx::1
[Peer]
PublicKey = MyPublicKeyFromAirVPN
PresharedKey = MyPresharedKeyFromAirVPN
Endpoint = nl3.vpn.airdns.org:1637
AllowedIPs = 0.0.0.0/0,::/0
PersistentKeepalive = 15
My setup (not a working one - no internet) following forum and google (I can ping 1.1.1.1, but can’t ping DNS):
/interface wireguard
add listen-port=51820 name=wireguard1 mtu=1320 private-key="MyPrivateKeyFromAirVPN" comment="WireGuard VPN"
/interface wireguard peers
add allowed-address=0.0.0.0/0 endpoint-address=nl3.vpn.airdns.org endpoint-port=1637 interface=wireguard1 persistent-keepalive=15m public-key="MyPublicKeyFromAirVPN" preshared-key="MyPresharedKeyFromAirVPN" comment="WireGuard VPN"
add address=10.150.xx.12/32 interface=wireguard1 comment="WireGuard VPN"
add dst-address=0.0.0.0/0 gateway=wireguard1 comment="WireGuard VPN"
/ip/dhcp-server/network/set dns-server=10.128.10.1 0
add chain=input protocol=udp dst-port=1637 action=accept
I am not realy sure where to put DNS server information.
What else am I missing?
In the browser I’m getting following errors:
google.com’s server IP address could not be found.
Try:
Checking the proxy, firewall, and DNS configuration
Running Windows Network Diagnostics
DNS_PROBE_FINISHED_BAD_CONFIG
or
google.com’s DNS address could not be found. Diagnosing the problem.
Try running Windows Network Diagnostics.
DNS_PROBE_STARTED
Complete mikrotik config please.
/export file=anynameyouwish ( minus router serial number, any public WANIP information, keys etc. )
This might be missleading, but I would guess it’s problem with DNS.
# 2024-10-05 08:26:50 by RouterOS 7.16
# software id = HNDE-941S
# model = C52iG-5HaxD2HaxD
# serial number = xx
add admin-mac=xx:xx:xx:xx:xx:xx auto-mac=no comment=defconf name=bridge
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-CC494B \
    disabled=no security.authentication-types=wpa2-psk,wpa3-psk .ft=yes \
    .ft-over-ds=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
    10min-cac .width=20/40mhz configuration.mode=ap .ssid=MikroTik-CC494B \
    .ft-over-ds=yes
add comment="WireGuard VPN" listen-port=51820 mtu=1320 name=wireguard1 private-key="private-key"
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge name=defconf
/disk settings
set auto-media-interface=bridge auto-media-sharing=yes auto-smb-sharing=yes
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
add allowed-address=0.0.0.0/0 comment="WireGuard VPN" endpoint-address=\
    nl3.vpn.airdns.org endpoint-port=1637 interface=wireguard1 name=peer1 \
    persistent-keepalive=15m preshared-key=\
    "preshared-key" public-key="public-key"
    192.168.88.0
add address=10.xx.xx.12 comment="WireGuard VPN" interface=wireguard1 \
    network=10.xx.xx.12
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=10.128.0.1 gateway=\
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
add action=accept chain=input dst-port=1637 protocol=udp
add comment="WireGuard VPN" dst-address=0.0.0.0/0 gateway=wireguard1
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
    dst-port=33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-name=Europe/xx
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
add dst-address=wireguardIP/32 gateway=ISP gateway
and add wireguard1 to WAN interface list
add address=192.168.88.0/24 comment=defconf dns-server=> 10.128.0.1 > gateway=
192.168.88.1
What kind of DNS is this? Remove it.
Put DNS 1.1.1.1 in /ip dns
Thank you for helping.
I have added suggested lines (ip route, wireguard to WAN list) and changed DNS to 1.1.1.1, does this mean that VPN’s DNS is not needed (10.128.0.1)?
This config is now working. Is everything set correctly? How can I do additional tests? Already tested with https://ipleak.net/ and it seems to be ok.
# 2024-10-05 11:00:05 by RouterOS 7.16
/interface wifi
    .ft-over-ds=yes
    .ft-over-ds=yes
/disk settings
add interface=wireguard1 list=WAN
    "xx" public-key="xx="
    192.168.88.0
    network=10.xx.xx.12
/ip dhcp-client
add address=192.168.88.0/24 comment=defconf dns-server=1.1.1.1 gateway=\
    192.168.88.1
/ip dns static
    invalid
add disabled=yes distance=1 dst-address=10.xx.xx.12/32 gateway=192.168.10.1 \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system note
/tool mac-server
Yes, VPN’s DNS is not needed. If everything is ok, then everything works)
Hmmm. Something is still off.
https://ipleak.net/ - shows ip from VPN,
but
https://whatismyipaddress.com/ - is listing my real IP address.
And if I connect to WiFi, clients are not routed through WireGuard.
now, if I add this, will be opposite. ipleak will show my real IP, but whatismyipaddress will show VPN’s IP
add disabled=no distance=1 dst-address=10.152.91.12/32 gateway=192.168.10.1 \
full setup:
# 2024-10-05 11:29:09 by RouterOS 7.16
add comment="WireGuard VPN" listen-port=51820 mtu=1320 name=wireguard1 \
	private-key="xx"
/interface wifi channel
add band=2ghz-ax disabled=no name=channel2 width=20mhz
add band=5ghz-ax disabled=no name=channel5 width=20mhz
/interface wifi security
add authentication-types=wpa2-psk,wpa3-psk disabled=no name=security passphrase=xx wps=disable
/interface wifi configuration
add channel=channel2 disabled=no name=cfg2 security=security ssid=MT_VPN
add channel=channel5 disabled=no name=cfg5 security=security ssid=MT_VPN
/interface wifi
set [ find default-name=wifi1 ] configuration=cfg5 configuration.mode=ap \
    disabled=no security.ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] configuration=cfg2 configuration.mode=ap \
/disk settings
/interface wireguard peersa
    "xx" public-key=\
    "xx"
    192.168.88.0
    network=10.xx.xx.12
/ip dhcp-client
    192.168.88.1
/ip dns static
    invalid
    invalid
    icmpv6
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
/system note
/tool mac-server
Hi, How is it in case i’m using with this VPN - IP hole and i have 2x DNS over there?
Should i use only Pihole IP and keep the “former” DNS servers or should i add also the one from AirVPN 10.128.0.1 ?
