I’m running an CRS326 with an Chateau LTE12 as an router.
It’s running on a tagged VLAN, and I’m not able to ping the router’s Unicast Global Address when it’s not working, but a simple reboot fixes it? Has anyone else came across this issue and has any ideas as to how to resolve it other than a scheduled reboot of the switch?
The IPv6 issue is on VLAN202.
CRS326 config:
set [ find default-name=ether1 ] comment="Cable Modem"
set [ find default-name=ether15 ] comment="Tik Router" rx-flow-control=auto \
tx-flow-control=auto
set [ find default-name=ether16 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] rx-flow-control=auto tx-flow-control=\
auto
set [ find default-name=sfp-sfpplus2 ] advertise="10M-half,10M-full,100M-half,10\
0M-full,1000M-half,1000M-full,10000M-full,2500M-full,5000M-full" comment=\
"Trunk to Juniper" loop-protect=off rx-flow-control=auto tx-flow-control=\
auto
/interface vlan
add interface=bridge name=MGMT vlan-id=99
add name=LAN
add name=DT
/interface lte apn
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=bridge frame-types=admit-only-vlan-tagged interface=sfp-sfpplus2 \
pvid=10
add bridge=bridge frame-types=admit-only-untagged-and-priority-tagged \
interface=ether1 pvid=200
add bridge=bridge interface=ether17 pvid=10
add bridge=bridge broadcast-flood=no interface=ether10 pvid=10 \
unknown-multicast-flood=no unknown-unicast-flood=no
add bridge=bridge interface=ether9 pvid=10
add bridge=bridge ingress-filtering=no interface=ether15 pvid=10
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether16 pvid=202
add bridge=bridge interface=ether2 pvid=10
set discover-interface-list=all protocol=lldp
/ip settings
set max-neighbor-entries=8192
/interface bridge vlan
add bridge=bridge tagged=sfp-sfpplus2 untagged=ether10,ether17,ether2 vlan-ids=\
10
add bridge=bridge tagged=sfp-sfpplus2,ether15,bridge vlan-ids=99
add bridge=bridge tagged=sfp-sfpplus2,ether15,ether2 untagged=ether1 vlan-ids=\
200
add bridge=bridge tagged=sfp-sfpplus2,ether15 vlan-ids=202
add interface=ether17 list=LAN
add interface=ether10 list=LAN
add interface=ether10 list=DT
/interface ovpn-server server
set auth=sha1,md5
add address=192.168.88.1/24 comment=defconf disabled=yes interface=bridge \
network=192.168.88.0
add address=192.168.99.3/24 interface=MGMT network=192.168.99.0
/ip dhcp-client
add
/ipv6 address
add address=fdaa:99::4 advertise=no interface=MGMT
/ipv6 nd
set [ find default=yes ] advertise-dns=no
/snmp
set enabled=yes location=Hallway
/system clock
set time-zone-name=Europe/Helsinki
/system identity
set name=Hallway-Switch
/system routerboard settings
set boot-os=router-os
LTE12:
add name=bridge protocol-mode=none pvid=99 vlan-filtering=yes
/interface lte
set [ find ] allow-roaming=no band="" disabled=yes name=lte1
/interface wireless
set [ find default-name=wlan1 ] ssid=MikroTik
set [ find default-name=wlan2 ] ssid=MikroTik
/interface vlan
add interface=bridge name=VLAN99 vlan-id=99
add interface=bridge name=VLAN200 vlan-id=200
add interface=bridge name=VLAN202 vlan-id=202
add name=WAN
add name=LAN
/ipv6 pool
add name=pool1 prefix=2001:<snip>:<snip>:a600::/55 prefix-length=55
add bridge=bridge frame-types=admit-only-vlan-tagged interface=ether1 pvid=200
add bridge=bridge disabled=yes interface=ether2 pvid=200
add bridge=bridge tagged=ether1,bridge untagged=ether2 vlan-ids=200
add bridge=bridge tagged=ether1,bridge untagged=ether3 vlan-ids=202
add bridge=bridge tagged=bridge,ether1 vlan-ids=99
add comment=defconf interface=lte1 list=WAN
add comment=defconf interface=VLAN99 list=LAN
add interface=ether5 list=LAN
add address=192.168.99.4/24 interface=VLAN99 network=192.168.99.0
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=\
out,none out-interface-list=WAN
/ipv6 route
add disabled=no dst-address=2001:<snip>:<snip>:a6a0::/60 gateway=\
2001:<snip>:<snip>:a600::2 routing-table=main
/ipv6 address
add address=2001:<snip>:<snip>:a600::1 advertise=no interface=VLAN202
/ipv6 dhcp-client
add add-default-route=yes interface=VLAN200 pool-name=DNA pool-prefix-length=56 \
prefix-hint=::/56 rapid-commit=no request=address,prefix \
use-interface-duid=yes use-peer-dns=no
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
add action=accept chain=input comment="defconf: accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
invalid
add action=drop chain=forward comment="defconf: drop packets with bad src ipv6" \
src-address-list=bad_ipv6
add action=drop chain=forward comment="defconf: drop packets with bad dst ipv6" \
dst-address-list=bad_ipv6
disabled=yes hop-limit=equal:1 protocol=icmpv6
icmpv6
add action=accept chain=forward comment="defconf: accept IKE" dst-port=500,4500 \
protocol=udp
ipsec-ah
ipsec-esp
/system identity
set name=Router
