I tried:
[] change any options and press apply
[] press “regenerate host key”
[] import ssh pubkey to user
[] upgrade to 7.4beta, downgrade again
[] export ssh-host-key
[] export host priv+pub files from another mikrotik and import to this one
I get these errors Couldn’t perform action - feature is not implemented (2)
or error - contact MikroTik support and send a supout file (2)
or #error exporting /ip/ssh
I seem to have the same problem on RB5009 and 7.3.1.
Brand new RB5009, came with 7.1.x, upgraded to 7.3.1, did most of the configuration in Wnbox and Wnbox Terminal. Only encountered this error when configuring /ip/ssh.
/ip/ssh print results in “error - contact MikroTik support and send a supout file (2)”
Found the problem. Here’s how to replicate it.
(from “/system/reset-configuration no-defaults=yes”)
/ip/ssh/set strong-crypto=yes
/ip/ssh/regenerate-host-key
reply n
(seems fine if Y to regenerate-host-key)
MMM MMM KKK TTTTTTTTTTT KKK
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 7.3.1 (c) 1999-2022 https://www.mikrotik.com/
Press F1 for help
Change your password
new password> ********
repeat new password> ********
Password changed
[admin@MikroTik] > /ip/ssh/print
forwarding-enabled: no
always-allow-password-login: no
strong-crypto: no
allow-none-crypto: no
host-key-size: 2048
[admin@MikroTik] > /ip/ssh/set strong-crypto=yes
[admin@MikroTik] > /ip/ssh/regenerate-host-key
This will regenerate current SSH host keys, yes? [y/N]:
N
action cancelled
[admin@MikroTik] >
