RouterOS 7.5 Mangle rules
Hello, I have a problem after upgrading to OS7.5. I have 2 WANs on my router and I want to force multiple networks to connect to WAN2 while WAN1 is used as the primary.
At first I ran into the problem that in the new version of the OS it is impossible to add table routing by creating a mangle rule. Routing table must be created in advance in the menu Routing - Tables.
I created some Mangle rules like
Created a new route for mangle rules.
And when I turn on the rules, I encounter a DNS error on the computer, which I forcibly send to WAN2
In version RouterOS6.4, these rules worked correctly for me and DNS was taken from the Mikrotik itself.
But in 7.5 this does not happen.
Until I manually specify the WAN2 DNS on the computer that I forcibly redirect to WAN2, the sites do not work.
And the local address specified by the computer becomes inaccessible from the same subnet to other computers.
As if the port is directly redirected to WAN2.
Like VLAN.
How to use mangle rules correctly in this scheme and tell him to use DNS Mikrotik?
DNS at me are specified manually.
My mikrotik is a local DNS server.
Allow remote request enabled
I tried to add DNS WAN2 manually as an additional one - it did not solve the problem.
Be grateful for advice.
Thanks in advance.
Try the easier route ( pun intended) no mangling!!!
Wan1 Route distance=X ( primary )
Wan2 Route distance=X+1 (Secondary )
Have four subnets A,B,C,D where B and C must go to WAN2
Also subnet B must be able to access subnet D and NOT get routed out wan 2 for everything…
/routing table add fib name=useWAN2
add dst-address=0.0.0.0/0 gwy=ISP2 gateway IP routing-table=useWAN2
/routing rules
add src-address=subnetC action=lookup table=useWAN2
add dst-address=subnetD src-address=subnetB action=lookup table=main
add src-address=subnetB action=lookup table=useWAN2
Note: if you never want subnets B,C to use WAN1 in case WAN2 goes down then
change action to action=lookup-only-in-table
It’s solve my problem.
Thank you!
